BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Wheel setup
      11-15-2019, 10:19 PM   #1
RollinUpF30
Instagram-Rollin Up Detailing
Drives: 2015 328i
Wheel setup
Just picked up some 18” staggered wheels for my 15 328i. Fronts are 18” 8.5 and rear are 18” 9.5. They are 54 et. What size tires can I run without issues having xdrive?
      11-15-2019, 10:40 PM   #2
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
First of all ET 54 will not work... you need to run a minimum of 20 mm spacer up front and 15 mm spacer on the rear. Depends how aggressive you want it.
Stock staggered tire size 225/45 and 255/40 will do fine
      11-16-2019, 08:11 AM   #3
RollinUpF30
Drives: 2015 328i
Thanks. So the only way I can run these wheels is by using spacers?
      11-16-2019, 10:28 AM   #4
chowser51
chowser51's Avatar
Drives: ‘18 F33 430ix B46 BM3s193
Buy the spacers. You can try to mount a wheel but you’ll quickly find it won’t work. The et54 offset will not work without spacers. Our offset is 30 something.
      11-16-2019, 10:41 AM   #5
RollinUpF30
Drives: 2015 328i
Thanks guys. Hopefully it won’t look bad!
      11-16-2019, 11:26 AM   #6
RollinUpF30
Drives: 2015 328i
Nevermind. I was told they are a 54 offset! I just checked the offset myself and they are showing they are 32!
      11-16-2019, 11:27 AM   #7
RollinUpF30
Drives: 2015 328i
I just checked the offset myself which i should have just done in the first place! They are 32 not 54!
      11-16-2019, 01:06 PM   #8
Gen13 F36
Gen13 F36's Avatar
Just to add
Front offset is from +20 to +35 (34 is stock)
Lower means poking out ( need car lower to run some camber)
Rear offset is +30 to +47 (47 is stock)
Lower means poking out ( need car lower to run camber)
      11-19-2019, 12:26 PM   #9
imaple
Drives: BMW F30 320d M Sport
Hi there.
New here.
I am just wanting to get some advice on a wheel setup.
I am looking to buy front 19x8.5 et35 & rear 19x9.5 et40. The car is low and want to know if this is going to be a problem
      11-19-2019, 01:13 PM   #10
Gen13 F36
Gen13 F36's Avatar
Originally Posted by imaple View Post
Hi there.
New here.
Wheels will fit as long as you use proper width and diameter tires.
As for I seen people fit front 245 and 275 rear.( keep in mind total diameter, so correct sidewall especially your car is lowered.) I think 35 /30 on back... but someone might have another opinion
      11-19-2019, 02:07 PM   #11
KDW4him
KDW4him's Avatar
Drives: F30 335i xDrive
Just to add
I thought the "standard" wheels were all 4 the same offset?
2013 335i xDrive Melbourne Red
my first BMW
BMW, you might find better but you can't pay more
