08-21-2018, 02:04 PM | #23 | |
Rep 409
Thank you, Reg. Did you apply the Ceramic in sunlight, shade, in-garage?
2015 335i X-drive, Black Sapphire Metallic, M Sport package LOADED. MPE/VRSF Charge Pipe/BM3 Stage 1 93 Octane
08-22-2018, 03:47 PM | #24 | |
Rep 53
Drives: BMW 328i, X3 M40i
Garage List 2018 BMW X3 M40i [0.00]
2003 BMW Z4 [0.00] 2006 BMW 325i [0.00] 2008 Acura MDX [0.00] 2013 BMW 328i [0.00] |
The hydrophobic properties might be better on ceramic coating but for me I don't see significant benefit. Using sealant regularly will achieve very similar result. Dirt will still accumulate on the surface regardless what professional grade coating you have. The negative of ceramic coating is not able to easy "reset" using DA polishing. If I have scratches on clear coat, I can easily polish it and reset my paint surface. For me, I do 2 buckets cash wash every week or two, apply sealant(multiple layers) every 6 months and do paint repair/DA polish every year. With ceramic coating, you need to use very aggressive pad and polish to cut through it. It will be tough to resurface the coating because of its hardness. And it is not cheap to reapply ceramic coating after each repair. Again, no matter how hard it is, it will has scratches eventually. |
08-27-2018, 02:35 PM | #25 |
Rep 65
08-30-2018, 12:28 PM | #27 |
Rep 1,033
To maintain the coating, you should add CarPro Reset to your regimen. I'm also using CarPro Reload on top of the coating, but another member showed insane results with CarPro Gliss.
08-30-2018, 08:56 PM | #28 |
Rep 2,180
Where does it end!?!
kern4174442.00 |
08-31-2018, 08:43 AM | #29 |
Colonol Forbin
208
Rep 338
I also use Reset as it is a safe PH balanced soap to wash the car with after it is coated. I hit it with Reload every 6 months or so.
I haven't tried Gliss but also heard great things. |
09-27-2018, 10:20 AM | #32 |
Rep 814
10-16-2018, 04:20 PM | #33 |
Rep 46
10-16-2018, 08:00 PM | #34 | |
Rep 65
I'm still impressed with the ceramic all this time later. I just sprayed it off today and the paint still feels/looks great. |
