09-04-2018, 11:10 AM | #1 |
Rep 397
How to apply Gtechniq C2V3 with a sealant
Hello guys, I plan on using gtechniqs spray ceramic coating for this coming winter. I want to use chemical guys jetseal in conjunction.
Besides the typical paint correction steps are done, all I need to do is apply the sealant let cure/dry and then simply spray and apply the spray ceramic on top? |
09-04-2018, 05:53 PM | #2 |
Rep 138
Drives: 2016 435i ZHP 076
NO, use it the other way around, ceramic coating first then sealant.
If you are going that far with prep, why not use a better ceramic coating?
R T Whitfield
2016 435i ZHP #76 RACE CAR spelled backwards is RACE CAR |
09-04-2018, 06:06 PM | #3 | |
Rep 1,044
Overall, like ZHP noted you want ceramic coating > sealant but I would find a product that is actually a ceramic coating and apply it the same day as you do your wash/prep as now you're most likely going to have to reprep your car. |
09-04-2018, 07:43 PM | #4 |
Rep 397
This article is a nice read. I'm following his ideas on the whole process, still question remains though if the gtech panel wipe is recommended which strips wax and all other surface stuff then why even seal? This is why I am primarily confused.
I think I'm going to go with: Wash Clay Swirl x Ultimate Polish Wash Gtechniq Spray wax Do not put down wax before gtechniq, gtech needs a non slick surface to properly bond with paint. I opted for a spray wax as the last step here bc I am unsure if a regular paste or liquid that requires drying first and then buffing out would strip the gtech layer underneath. Can anyone confirm? https://www.detailedimage.com/Ask-a-...iquid-crystal/ |
X2 Monstah301.00 ZHP076145.00 |
