08-23-2019, 11:20 AM | #1 |
Rep 1,282
E85
I accidentally pumped 6 gallons of E85. I usually only pump 3.5 gallons with no issues. Could I mess something up due to this?
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
08-23-2019, 11:36 AM | #3 |
Rep 1,282
Ewg
08-23-2019, 12:00 PM | #4 |
Rep 190,750
Do not drive the aggressively and you will be fine.
08-27-2019, 02:48 PM | #5 |
Rep 288
08-27-2019, 03:20 PM | #6 |
Rep 190,750
Depends on your map, check with your tuner
08-28-2019, 08:04 AM | #7 |
Rep 1,499
with the bm3 E30 map you can safely run 4.25 gals of E85 with 11.75 gals of 93 octane to give you a true E30 blend if you have a strong HPFP. At 6 and 10 respectively, you are at an E38 blend. Just drive conservatively until you burn an 1/8 of a tank and top off with 93.
09-17-2019, 09:46 PM | #9 |
Rep 7,598
What gas are you mixing it with and what tune/map are you running?
I believe his calculations above assume you are mixing E85 that contains 85% ethanol with 93 that contains 10% ethanol, and you fill completely to 16 gallons total with nothing else. Unless you have an ethanol sensor you dont really know what %E you are getting from the pump... I know my local E85 station states 55-83% on the pump for E85. I run it in my 3000gt because i just have the tune a bit rich and dont need a precise E content, but don't know if i will ever run a E map in my 335 without an ethanol sensor. |
