08-23-2019, 12:48 PM | #89 |
Rep 1,286
Also, where do list people install the tank? Trunk?
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
08-23-2019, 01:02 PM | #90 |
Rep 1,499
Most installs I have seen mount the tank in the trunk on the side wall. Pump is mounted below the tank under the trunk liner.
08-23-2019, 03:43 PM | #92 |
Rep 1,286
Is it challenging to run the lines from the tank all the way to the engine area?
08-23-2019, 03:53 PM | #93 |
Rep 1,375
Not at all, it's actually pretty simple. It slips behind the trim that runs along the floor board/drivers door(s) area.
08-23-2019, 04:19 PM | #94 | |
Rep 1,286
I might have found someone to install it but won’t know for sure until Monday. If all fails, I’ll have to install it myself although it looks pretty scary.
08-23-2019, 04:42 PM | #95 | ||
Rep 1,375
08-23-2019, 04:45 PM | #96 |
Rep 1,286
I literally fixed that within 5 seconds of first posting it. You must have beat me to it within that time. That’s iPhone spellcheck for you...
08-23-2019, 04:50 PM | #97 | |
Rep 1,375
But yeah. That tank holds the water/methanol or any alcohol mixture for that matter. I use Ethanol instead of methanol. It's really not that bad of an install. Just gotta read the install manual step by step. |
09-06-2019, 07:28 AM | #98 |
Rep 503
Hi guys,
So i just got back to modding my car after spending weeks fixing the boost leak ( bad gaskets), now i'm getting a W/M kit really soon. I just have 1 question: I've read on the forum that people are using the kit for varied purposes, some using it for additional fuel, some using it for cooling. Is there any difference for the setup or just depending on the fluid that you put in the tank? Thank you! |
09-06-2019, 07:33 AM | #99 | |
Rep 1,375
Charge pipe injected kits tend to be used for more of a cooling and fueling combo. Port injected methanol kits are used mainly to add fuel/meth, not so much for cooling. Port injection also ensures the meth is getting evenly distributed. |
09-06-2019, 08:36 AM | #100 | |
Rep 1,286
I found shop that will install any meth kit I bring them and now I’m deciding between the BMS kit and AEM. Might have to call both vendors because I have so many questions. The BMS kit is better I think with JB4 because that’s the controller, but I don’t want to spend money on JB4. AEM already has the nice controller. Might end up getting the AEM kit + BMS stealth tank.
09-06-2019, 08:48 AM | #101 | ||
Rep 1,375
Anywho, I ran the time at the track (11.87@116) I was looking for with the 2H E30 OTS Map. Cooler ambient temps and the meth kit shaved off over 4/10's of a second which is pretty huge in my opinion. I have experience with BMS, AEM, and Snow Performance kits. I tried the JB4 stack and wouldn't put a JB4 on my car again if you paid me so the BMS Kit would be strong no for me. The AEM kit is easy to install and wire. My opinion is this. Install an AEM kit without the kit figured into a custom tune. Use no more than a 50/50 mixture and you'll have a nice octane bump for the shit fuel on the west cost as well as cool intake temps. It's a win win for you guys. |
McLaren720s1476.00 |
09-06-2019, 09:28 AM | #102 | |
Rep 1,286
So you’re saying no custom tune? As long as the meth kit would allow me to run the Stage 2H map well, I’d be very happy. I think the car ran “reasonably” well with it as it is, but the added cooling and octane from the meth kit should hopefully smith out the ignition timings and eliminate knocking.
09-06-2019, 09:30 AM | #103 | ||
Rep 1,375
09-06-2019, 09:32 AM | #104 |
Rep 1,286
Does the AEM controller allow you to chose how much meth you’re spraying and is it throttle and boost dependent?
09-06-2019, 09:36 AM | #105 | |
Rep 1,375
The kit itself won't adjust the water/meth mixture percentage. That is only controlled by the end user in the tank. |
09-06-2019, 09:50 AM | #106 | |
Rep 1,286
09-06-2019, 09:53 AM | #107 | ||
Rep 1,375
So a 5psi starting point would equal 25% spray pressure from the system and ramp up from there. |
09-06-2019, 10:27 AM | #108 |
Rep 1,286
So if you’re spraying 100% at 20psi...is your turbo really hitting 20psi? Is that because you’re running E30? Isn’t that a lot of boost for this turbo? With the Stage 2 91 oct map I’m hitting around 15 psi max ( it was 16.3 max with the Stage 2H map)
09-06-2019, 10:37 AM | #109 | |
Rep 1,375
I believe these stock EWG turbos are stronger than most people know. I mean, most Pure stage 2 people are running mid to low 11's. To run an 11.8 with the stock turbo shows it's pretty strong in my opinion. That's the reason I chose to jump to an F80. I can't justify dropping 3-4K for an upgraded N55 turbo for 0.6-0.8 second faster 1/4 mile times. Tuners are also losing sight of the N55 with the B58 really starting to shine in the tuning development. Just my opinion though. |
ceedawg467.50 |
09-06-2019, 10:52 AM | #110 | |
Rep 1,286
Yeah, I can’t justify getting upgraded turbos myself. The meth kit will be the last power upgrade I make. I may not break into the 11s like you because I won’t be running E30 but it should still be pretty beast. I’m already pretty happy, let alone with the meth and hopefully running that nice Stage 2H map that I’ve been obsessed with ever since I’ve tried it. Also, i plan on keeping the car another 3-4 years or so and don’t want to invest thousands upon thousands of $$$, and then hopefully move on either to a C8 or if my career change takes effect...to my dream car (that’s “somewhat” in the realm of “affordability”)...a McLaren 570s.
