08-23-2019, 06:46 AM | #2839 | |
Rep 4,261
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
08-23-2019, 09:25 AM | #2840 | |
Rep 182
Open menu and choose settings Scroll to the bottom. click a few times on version. Developer mode will be activated You have new menu item under the threee dots upper left |
Sparky68683.50 |
08-26-2019, 01:16 PM | #2841 |
Rep 4,261
Brilliant thank you
08-27-2019, 09:51 PM | #2842 |
Rep 18
Hi all, I may have missed this being discussed in the thread but I just installed the Avin Gen 2 in my 2016 435i and have run into an issue. When I press the Voice Command button on the steering wheel, it functions normally but it also launches the Android side Navigation (Waze/Google Maps) app as well.
Waiting on Avin support to respond and thought I'd ask about it here as well. Thanks! |
08-27-2019, 11:12 PM | #2843 | |
Rep 1,048
i also had following MCU issues: * Voice key always start Android Navigation. * Navi Key was not selectable, started always Android Navigation * Tel Key was not selectable, startet always Android Phone * Brightness controll was always on it seems they just reconfigured the MCU to the settings i need, now the features work as i want them but the selection still does not work. Chri |
08-28-2019, 12:37 AM | #2844 | |
Rep 48
08-28-2019, 12:51 AM | #2845 |
Rep 4,261
Bought a new sat nav antenna for my unit and the sat nav is still terrible.
08-29-2019, 06:03 AM | #2846 | |
Rep 2
Connectors
Sorry for bringing up an old post. Regarding the connectors, if the head unit has a NBT connector, the screen OEM screen also has a NBT connector, right? (The purple cable connects the head unit to the screen, right?) Sorry for the question, but right now I don't have the opportunity to check that myself, but I do remember that my head unit has a NBT connector, even though the interface looks like CIC. Thank you for your time! |
08-29-2019, 07:05 AM | #2847 | |
Rep 2
08-30-2019, 08:58 AM | #2848 | |
Rep 18
09-08-2019, 12:53 PM | #2850 |
Rep 10
Be careful of latest Avin CarPlay Dongle update
I have had the Gen2 8.1 display for nearly a year. Everything working as it should and I even had full use of the iDrive control knob in CarPlay (left/right/up/down/select... everything).
I updated the latest firmware AutoPlayBox_2019.05.10.1138.apk (latest available on Avin support as of 9/8/2019) for the white dongle and now the iDrive controller has only left/right working. Select does not work, when I push the knob to the right it jumps two places instead of one. I've already tried the key learning to see if that would do anything but it doesn't. It was very convenient to use the iDrive controller in Carplay and I hope it is fixed soon. Last edited by bstone995; 09-08-2019 at 01:27 PM.. |
09-08-2019, 05:35 PM | #2851 | |
Rep 38
09-10-2019, 12:34 AM | #2852 | |
Rep 40
Settings > More Settings > Apps & Notifications Once you get here, scroll down to where it says show all apps and select it. Find the bluetooth app in the list and select it. Scroll down to the "display over other apps" setting and toggle it off. That should do it! |
09-10-2019, 12:55 AM | #2853 | |
Rep 40
About 2 days ago I removed the center channel speaker cover behind the Avin screen (I think the cover is the same in the M135i?) and mounted my antenna in the empty pocket beside the speaker. I ran the GPS wire down through the same "tunnel" as the speaker wire to the Avin unit. So far the signal has been much improved (tested with gps status app) and the antenna is still hidden. Like I've said in my previous posts, I've been using HUR for nav so i'm getting location data from both the phone and the antenna. Depending on what you're using for navigation your results might be different. Hopefully this helps! |
Sparky68683.50 |
09-10-2019, 01:42 AM | #2854 | |
Rep 38
Best Regards, |
09-10-2019, 06:29 AM | #2855 |
Rep 31
Originally posted in the other thread but probably belongs here
Hi guys, I have a strange problem where my headunit died (Bluetooth, IDrive Radio etc) and didn't come back to like until I removed the HU power splitter for powering the Android screen and plugged the original BMW HU power and optic cable back into the Headunit and then Radio BT and original IDrive screen started working again but this means I can no longer use my Android screen. I requested another power cable from uGode assuming it was the issue but the new cable didn't work either and radio BT and Idrive screen are wtill still not working Does anyone have any idea what the issue could be? Reverted back to removing screen and all Android cables. Cheers! Last edited by seanos10; 09-10-2019 at 06:30 AM.. Reason: wrong thread |
09-10-2019, 01:56 PM | #2856 |
Rep 38
09-11-2019, 04:24 PM | #2857 |
Rep 29
I have an e87 with the latest cic business. My car was made in may 2011, so its one of the last e87's made.
Do I have to run the aux cable to get sound or not? If I have to - is there any way to modify the harness that I don't have to? And also if I have to, is the quality noticeably worse than my stock bmw bluetooth streaming connection for spotify songs at the highest quality? |
09-18-2019, 02:50 AM | #2858 |
Rep 4,261
How do I find out if there is a software upgrade my unit ? I have got this in settings "APPver 20180611-ver1.0.0.0001_1280x480_850"
