06-15-2020, 06:52 PM | #1 |
Rep 99
*solved*
Greetings!
I am getting a 191C02 code, which ista is saying is "Fuel tank ventilation system, second inlet point: malfunction." That I can't seem to get to go away. Some context. I originally had 3 codes. 191C02 190F08 "fuel tank ventilation system: malfunction" And 195014 "differential pressure sensor, tank vent valve, signal permanently stuck" And SAE code P0440 which is generic for evap small leak detected. So I bought a new gas cap as mine had slight cracking on rubber seal, I also bought a new vent valve, and unhooked the line to the small Venturi (second Inlet point) and blew compressed air through it to check for obstructions as instructed by ABL from ISTA. I have a new venturi coming as a last resort but I did feel vacuum from the sensor port when I blew air through so I'm guessing it's not going to help. My question is, what else can cause the second inlet fault? Am I missing something? I have gone through the entire car for cracked lines and holes, re checked all connections and made sure all snap connections were on all the way. I can reset it but within 40 miles it's back again, just the 191C02 by itself. Any ideas or relevant experiences would be appreciated. Thanks! Sean |
06-30-2020, 06:48 PM | #3 |
Rep 99
Ok! I got it. So I replaced the Tank ventilation valve which got rid of 2 of the codes, but the second inlet one kept persisting. Even though it felt free of obstruction, and I couldn't find any leaks I changed the Venturi that hooks to the tank vent valve line and second inlet sensor, and 180 miles so far without issue.
In case anyone else runs into this, hope it helps!! |
VipinLJ1944.50 |
09-17-2020, 02:00 PM | #4 | |
Rep 1
09-17-2020, 03:30 PM | #5 | ||
Rep 99
Was about 65$, that is the bmw number so just Make sure that's the one for your car and get it from your place of choice. Hopefully that does it for you! It was driving me crazy too! |
08-27-2021, 04:57 AM | #6 | |
Rep 2
Hi, can you please tell me what exactly you use OEM parts / number I have the same problem as you, I still get the error message 190F08 "fuel tank ventilation system: malfunction" I've already exchanged PN: 13907601515 - https://www.google.com/search?q=1390...hrome&ie=UTF-8 PN: 13907636145 - https://www.google.com/search?q=1390...4dUDCA8&uact=5 I don't know what next else to replace. Thanks so much for the help |
08-27-2021, 08:08 AM | #7 |
Rep 99
13907601515 is what solved it for me, what's puzzling us it looked fine, and was free of obstructions, but that part totally solved it for me.
I would try checking every connection in those series of lines, look very close at them all, even a small split can cause an issue. Also maybe the switch itself is bad (the one that connects to the Venturi on the picture attached) Hope this helps! |
09-13-2021, 01:31 AM | #8 | |
Rep 22
09-13-2021, 04:33 AM | #9 | ||
Rep 99
04-18-2022, 03:14 AM | #10 | |
Rep 5
You said you changed the “venturi that hooks to the vent valve line and the second inlet sensor” which one is that exactly. I have the same code 191C02 and my cel keeps popping up after i clear it about 20-30 miles. I have already replaced gas cap and dtml pump. This would probably help me |
04-21-2022, 06:21 PM | #11 | ||
Rep 99
10-05-2022, 07:33 PM | #12 | |
Rep 119
10-05-2022, 07:36 PM | #13 | ||
Rep 99
03-05-2023, 09:33 PM | #14 | |
Rep 1
04-16-2023, 09:17 PM | #15 |
Rep 4
Bmw b46 engine code P0446 & P11C4
Hey just wondering if anyone else has had these two codes come up? I replace the breather valve & gas cap. Also checked my engine for cracks or leaks. I couldn’t find anything. Can anybody help please.
03-29-2024, 05:57 PM | #16 | |
Rep 3
03-30-2024, 07:57 AM | #17 |
Rep 95
04-04-2024, 06:18 PM | #18 | |
Rep 3
04-04-2024, 06:20 PM | #19 | |
Rep 3
