06-14-2019, 07:06 PM | #67 |
Rep 45
Sorry to hear about the GPS issues. How is the sound quality?
06-15-2019, 01:20 AM | #68 |
Rep 4
06-18-2019, 03:30 PM | #69 | |
Rep 439
07-27-2019, 08:59 AM | #70 |
Rep 14
Drives: 2015 BMW 328i xDrive
I tried installing the Bimmertech CarPlay MMI plus and I seemed to have followed everything in the tutorial from kies and bimmertech's new video but for some reason. My iDrive is gone and the screen is just lines and blurriness. I can see the iDrive is in the background cause the image changes as I rummage through with the touch controller.
But if I hold 8 or menu, CarPlay pops up clearly. I have no audio or mic apparently either. Dose anybody know what I'm doing wrong? -BMW 328i xdrive 2015 with navigation |
07-27-2019, 09:05 AM | #71 | |
Rep 1,686
Drives: 2014 428i and 2018 X5
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
SteveChao0.00 |
08-16-2019, 03:37 PM | #72 |
Rep 109
so i ordered the bimmertech carplay mmi plus for my 2015 F36 NBT anyone encounter carplay issues with the audio playing right side for front and rear and nothing for the left side for front and rear? also, backup cameras, front bumper cameras and side mirror cameras are showing no signals. waze is god aweful. very laggy and cant set waze for face north. i've contact bimmertech for support. |
08-20-2019, 11:44 AM | #74 | |
Rep 31
08-25-2019, 10:35 AM | #75 |
Rep 8
I installed the bimmer tech CarPlay MMI plus yesterday in my 2016 F10. I’ve experienced the same GPS lag and inaccurate positioning as you all. I’ve sent an email to bimmer tech support in hopes they can help fix this. I like the interface and the sound is good through my HK stock system. If the GPS is unusable there’s no point. I’ll share my experience
08-27-2019, 08:48 PM | #76 | |
Rep 45
08-29-2019, 03:39 PM | #77 |
Rep 248
Where does everybody route the USB cable for this?
Anybody try going for an OEM look instead of a cable just sticking out of some crevice? |
09-07-2019, 11:04 PM | #78 |
Rep 703
Any updates to those having issues? I'm considering this for android auto in my 2017 340i.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
09-08-2019, 01:01 PM | #79 |
Rep 1
UnknownBeing I ended up routing a lighting cable through one of the cup holders to this mount: https://joli.design
I used this post for instructions on how to get to the cup holders: https://f80.bimmerpost.com/forums/sh...&postcount=210 That being said, it turns out that location has weak GPS signal and I'm looking for a good solution (I don't think it's the MMI Plus' fault, but wish it tied in to the car's GPS antenna). |
09-10-2019, 09:17 PM | #80 | |
Rep 8
If i stow the phone in the arm rest the GPS improves but still is hit or miss. I don't know if the GPS issue impacts Androids |
09-23-2019, 07:00 PM | #81 | |
Rep 45
09-24-2019, 05:43 PM | #82 |
Rep 4
To those having GPS issues, by any chance are you the owner of iphone 8? If so then the bimmertech mmi plus is not the issue, iphone 8 is.
I've been using the bimmertech mmi plus with my old iphone SE and it works very very well. I've swapped my iphone 8 twice and still same very poor localisation. Also reason why I did not notice that obvious issue on iphone 8 before is because I did not pay attention and with iphone being on a big screen this can't be ignored. I've now tested iphone 8 without plugging it onto the mmi and the GPS issue is there as well. |
09-25-2019, 12:22 AM | #83 |
Rep 681
I get an LCI trim that has the hole for USB when your car is optioned with EBT. If you dig around on RealOEM, you can find the one that matches your interior. I had to modify the plug from the MMI for it to fit but it looks OEM. Unfortunately, I haven't had the same experience with the MMI so it'll likely come out since I use it for android auto and it's not that great of an experience.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
09-25-2019, 02:30 AM | #84 | |
Rep 4
That way when entering the car nothing to plug! |
09-26-2019, 04:06 AM | #85 | |
Rep 31
09-26-2019, 07:42 PM | #86 | |
Rep 681
Plus Android Auto was really designed around touch interface so using the wheel to get around isn't the most intuitive.
2006 997.1 C4S |
09-27-2019, 03:27 AM | #87 | |
Rep 31
Not sure why your sound quality is poor. Can bluetooth be used instead? |
09-27-2019, 10:33 AM | #88 | |
Rep 681
Dark mode doesn't work regardless of phone settings. Trust me, I've tried all the dev options and workarounds. It simply doesn't work. The box also should know when the car goes into night mode as android auto can autodim based on headlight settings.
2006 997.1 C4S |
