08-23-2019, 11:14 PM | #1 |
Rep 1,827
Rattle from engine bay under light throttle - N55
Hey guys!
I wasn't sure if I should post this here or in the N55 thread, but I figured it might get more traction here. Recently, I've noticed a rattle when I'm driving slowly under light throttle. Actually, driving slowly might be an overstatement, I'd call it creeping. It's most noticeable when I'm creeping through a drive-thru, and there's a wall next to me to resonate the sound. I know wastegate rattle was a common issue in N54s and somewhat in early N55s (which mine kind of is, PWG), but I heard that wastegate rattle is most common on startup, and oftentimes goes away after the car is at operating temp? I don't get any startup rattle, and it persists even when the engine is hot. Once I get past around 5mph, it goes away, and it's most prominent only when I'm in gear, creeping forward (maybe in reverse to, haven't really checked). So basically, only when it's under load. There's only the faintest hint of the rattle when I lightly rev in Park or Neutral. Any one experience similar? Could it actually be wastegate rattle? And if not, any thoughts on what it might be? Any and all insights will be appreciated. Thanks! For reference: 2013 335i automatic Tuned with mostly FBO (no FMIC yet, but I'm leaning towards it) High mileage commuter/daily driver (115k+ miles)
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
08-25-2019, 07:28 PM | #2 |
Rep 253
Sounds like the belt tensioner, a common failure point on these engines. Super cheap part and easy DIY. I did mine after noticing the exact symptoms you mentioned and doing some research. There's some DIYs on YouTube. I'm cheap so I got the non-OEM replacement and it's been great so far Bapmic 11288604266 Serpentine Belt Tensioner for BMW F30 F10 F01 F02 https://www.amazon.com/dp/B01MZZS3O9..._PTYyDbTJ88NJ8
One way to test if it's that is to turn AC on, it should become audible then. Otherwise it may just be normal injector noise, it's loud on these DI engines, it's most definitely not wastegate rattle. |
jh_f301306.00 |
08-25-2019, 07:55 PM | #3 | |
Rep 1,827
08-25-2019, 09:45 PM | #4 | ||
Rep 253
Jake From State Farm54.00 |
08-25-2019, 10:13 PM | #5 | |||
Rep 1,827
09-12-2019, 03:17 PM | #6 |
Rep 1,827
UPDATE:
Just replaced the belt tensioner (again) and it seems to have fixed the issue. As I mentioned, I last replaced it less than a year ago at 102k miles. I started really noticing the rattle probably at around 114-115k miles. So I got a lifespan of around 12-13k miles. Now, my tensioner wasn't loose or jiggling at idle, which it was when I replaced it the first time last December, so I probably could've gotten more miles out of it. I was just really annoyed by the rattle. In any case, the first time, I ordered it off Amazon for the fast & free Prime shipping. This time I ordered it from FCP Euro, so in case I need to replace it again in the next year, I can do a warranty replacement. Just a note for anyone looking to replace their tensioner, it might be worthwhile to get it from FCP in case you have similar issues in a similarly short amount of time/miles. Reference: part # 11288604266
01-13-2020, 07:46 PM | #7 | |
Rep 27
I know this is an old thread but just wanted to confirm, did the rattle you mentioned go away after replacing it with the new parts? I have the same issue and my ocd is acting up. I have the kit in my fcp euro cart ready to go. Thanks. |
01-13-2020, 10:42 PM | #8 | ||
Rep 1,827
01-14-2020, 10:00 AM | #9 | |||
Rep 27
03-03-2020, 08:38 AM | #11 | |
Rep 1,827
I haven't watched it personally, but Bryan's vids are generally pretty good. You can cross-reference with this: https://www.newtis.info/tisv2/a/en/f...ement/EXLFoWGh
04-11-2020, 09:18 AM | #13 |
Rep 1,827
If you have the right tools, I'd say 3-4. Definitely need a breaker bar to "re-cock" the tensioner.
