BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > CIC or NBT
      09-03-2019, 02:44 PM   #1
Gidimba
Drives: BMW 320i (F30) 11/2013
CIC or NBT
Hi all,
I have a 2014 F30 (320i) with the base audio sustem.
No telematics and no amp.
From the VIN lookup the car was manufactured 11/2013.
I am trying to understand what system I have. Is it CIC or NBT.
I found many references claiming that F30 from 2012 to 2015 had NBT (also called CIC High)
But when I check all images of how the UI looks it looks like the CIC syatem.
I also noticed my SW version is not standard so its realy hard to figure it out.
Can anyone help to figure this out?
      09-03-2019, 06:28 PM   #2
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
You have CIC
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      09-03-2019, 10:56 PM   #3
jus711
Drives: '17 F36 440i xDrive GC
Be careful, I have a 2013 F30 with Business Nav and everything I looked at suggested I had CIC and I ordered a CIC CarPlay unit and it turns out I had NBT. The difference is a 6 pin connector to the screen that instead of a 4 pin. CIC high is NBT.
aps335.50
      09-04-2019, 12:06 AM   #4
Gidimba
My car is a European car manufactured 11 2013
      09-04-2019, 02:01 AM   #5
IK6SPEED
Drives: BMW M3 / AH3
Do you have this option (or something similar) in you VIN Lookup?
S6VAA CICZusteuerung
      09-04-2019, 03:49 PM   #6
Gidimba
Hi,
I have S6VBA as an option
      09-04-2019, 10:24 PM   #7
IK6SPEED
Hi,
And what does it say that is under description?
      09-05-2019, 12:52 AM   #8
jus711
Originally Posted by IK6SPEED View Post
The only USA MY 2013 F30 (manufactured prior to 7/2013) that are supposed to have NBT are the AH3.
European units with a NAV built anytime in 2013 are also NBT.
In EU, where OP is, they do not use US Model Year designation.
USA model year 2014 (after 7/2013 build) with no Navigation/base units are still CIC.
What was your actual build date?
My build date was 11/2012
      09-05-2019, 05:40 AM   #9
Gidimba
It says “S6VBA CCC allocation”
I decided the best way to go is to physically see what is written on the HU.
so it says L7 Entry and ENTRY CB
in layman's terms what does this mean?
      09-05-2019, 11:04 AM   #10
IK6SPEED
Appears to be CIC.
      09-05-2019, 11:35 AM   #11
ooshnoo
ooshnoo's Avatar
2018 BMW X5  [0.00]
It says "S6VBA CCC allocation"
Appears to be CIC.
I knew it!
___________________
2018 F15 M-Sport
IK6SPEED4488.00
      09-05-2019, 02:09 PM   #12
Gidimba
Appears to be CIC.
Bummer 😞
Thanks for the clarification.
      09-06-2019, 07:39 AM   #13
jus711
Errr...no
CIC High does NOT mean NBT
The high refers to the size of the unit.
The base unit with CD and no Nav is short.
The CIC HIGH is CIC and it is HIGH containing the CD and the NAV unit
Not according to BimmerTech or BMW but ok, all I know is that if you have what I have-including a “CIC High” HU as it says on my unit, then you have a 6 pin out to the screen that carries power and that’s considered NBT for these aftermarket units and I think that’s what OP was concerned about.
https://f30.bimmerpost.com/forums/at...hmentid=746636
aps335.50
      09-06-2019, 01:52 PM   #14
P320iVic
Drives: BMW 320i xDrive
Help please
Hello All,
I am having the same issue Identifying my head unit. It is a 2015 BMW 320i xDrive, but I think the dealer my have replaced the head unit. I purchased a Nav. NBT unit and control knob, with the newer 8.8" screen.
      09-07-2019, 04:04 PM   #15
DarkIrata
DarkIrata's Avatar
Drives: BMW 320i (F31), 2015
Originally Posted by P320iVic View Post
Hello All,
Can you make a picture of the current hu screen? And if you got navigation, which one?
      09-08-2019, 09:31 AM   #16
P320iVic
I do not have NAV. on the current unit in the car. I have a new HU with nav that I will bw installing, if I can ever get the software.
      09-13-2019, 06:57 AM   #17
Dean80
Drives: BMW F30 320D ED
The GUI would seem to show you have CIC - the red outline selection box is CIC
      09-22-2019, 08:54 AM   #18
shawnsheridan
shawnsheridan's Avatar
You do not have NBT. You have ENTRYNAV Head Unit, used for cars with 606 Business Nav not 609 Pro Nav.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      10-26-2019, 03:13 AM   #19
Gidimba
Appears to be CIC.
Thanx,
So I checked and have a 6pin display cable.
I also have an aftermarket reverse camera and I checked the model of the unit and it claims its an adaptor for NBT.
So I want to get a CarPlay adaptor and I don't want to end up getting the wrong one.
If for the CarPlay the important part is the display connector then maybe its NBT?
2014 F30 320i
H
