BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Intermittent Electrical Issues
      06-11-2019, 01:32 PM   #1
ryantpayton
Drives: 13' 335i xDrive
Hey all, I know this is kinda generic but any help would be greatly appreciated.
My car is acting up, and it seems to be getting worse. I replaced my car battery a couple months ago but I also only drive it maybe 3-4 days a week. Then the rest of the time it's off in the garage.
Issues:
- Backup camera option is grayed out sometimes and won't turn on.
- Heated seats when pressing the button it won't turn on. Sometimes it does but it will turn on to level 3 then get stuck and then eventually turn off.
- Sound won't adjust when using the volume knob. Again will turn up/down intermittently and same for trying to mute. Have to keep pressing the button until it sometimes works/sometimes doesn't.
Retrofits:
Backup Camera
Auto High Beams
Rear PDC
CIC->NBT
Touch Controller
I have a 2013 BMW F30 335i xDrive
Thanks in advance! And I can post a video if that helps.
      06-12-2019, 12:45 AM   #2
Mikesmith2939
Drives: 2013 320i xdrive
I think you still have an issue with the battery.
Is the replacement the same type as the old one?
Was it coded to the car?
      06-12-2019, 11:43 AM   #3
ryantpayton
The dealership replaced it, I believe they matched it but not sure if they coded it to the car or not.
Do you know what I need to check to see if it's coded to the car? I have access to the coding software.
      06-12-2019, 11:54 AM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's not coded, it's registered. Not the same thing. Your iDrive might have a record of it. An OBD diagnostic tool might be able to tell as well, especially if it's one that has the ability to register batteries. If it was me I'd be using my OBD diagnostic to find fault codes.
      06-14-2019, 06:40 PM   #5
ryantpayton
I can give that a shot. I wouldn't think it would throw codes but I havent tried so 😋
      06-14-2019, 09:24 PM   #6
Billfitz
Billfitz's Avatar
Unhappy
With all the sensors on an F30 anything that could possibly happen will throw a code. If you fart it will throw a code for that.
