      04-11-2013, 01:22 PM   #3235
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
663
Drives: 2020 G20 320i M Sport
No. There is no FSC Code for 6AL.
I'm still having trouble finding the right combination of SALAPA codes to make this work. The only problem is getting the Bluetooth Data profile to show up when I pair a phone to my car. I do see the BMW Live and Internet options under BMW assist but it will ask me to contact my dealer to activate data transfer via bluetooh.
When I pair my phone, I only get Telephone, Audio, Office and Additional Telephone.
Maybe I just need to find European F30 VIN that has a native 6NK and add the relevant SALAPA codes to my VO.
      04-11-2013, 01:29 PM   #3236
vithy
Drives: 2016 F30 328xi
I think you can add that later very easily.
I have included the PDF that shows what is included with the Combox upgrade. My car already has USB/AUX connector, do i have to get another one?
      04-11-2013, 01:57 PM   #3237
shawnsheridan
shawnsheridan's Avatar
If you already have 6FL (USB/AUX in the armrest), then no.
      04-11-2013, 02:12 PM   #3238
vithy
is that different from slandered one the car comes with?
      04-11-2013, 02:32 PM   #3239
shawnsheridan
Not usually, but if you wanted to be sure, why wouldn't you just check your vehicle options list, and verify you have 6FL, rather than leave it for chance?
      04-11-2013, 03:29 PM   #3240
steve@codemybimmer
Hong Kong
663
Just stumbled across this one ebay and it's seems like a steal but there's barely any info on it. I'm thinking about just buying it so I can play around with this and see if I can code my car's VIN to it since it's dirt cheap.
If I was to plug this in and remove my CIC Head Unit, will I be able to see HU_NBT on my list of ECU's? Also I'm not sure if I need a specific NBT Head Unit for the F30 - are they all the same? I can probably buy the PnP adapter from Bimmerretrofit to get the Nav and Voice control working.
Seems like I can use my existing 8.8" screen and CIC controller for this.
http://www.ebay.com/itm/HARMAN-AUTO-...7b93a0&vxp=mtr
      04-11-2013, 03:38 PM   #3241
shawnsheridan
All North American NBT units should be alike, but NBT Units for Europe and Asia will be different due to the FM, DAB, and Sat Radio Tuner differences.
Beyond the NBT Unit istelf and the CAN Filter for Navigation and Voice Recognition Activation, I do not think it is Plug-N-Play to install as the Pinouts are different from CIC, and you will also need additional FSC Codes for BMW Apps and Sat Radio imported and activated into it if you want those features. Lastly, the car cannot be ISTA/P programmed with NBT installed, so you will need to swap back in your CIC unit for any dealer programming.
      04-11-2013, 07:45 PM   #3242
vithy
How do I check that Shawn?
      04-11-2013, 08:29 PM   #3243
shawnsheridan
http://bmwvin.com/
      04-12-2013, 06:37 AM   #3244
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
If you simply swapped Gear Shifters, then no Coding is needed.
If you switched from non SAT to SAT, including new Steering Wheel with paddle shifters, then you need to replace 205 with 2TB in your VO, and code the car.
What is the point of swapping the gear shifters? Just for looks?
      04-12-2013, 06:39 AM   #3245
shawnsheridan
It looks and feels better given the shape is different. The Wheel with Paddles is next though.
      04-12-2013, 09:16 AM   #3246
cedchung
Mauritius
64
Ok thanks, now can the car be coded to retrofit SAT? That is to get the faster shifting
      04-12-2013, 09:45 AM   #3247
shawnsheridan
The car can be coded to add 2TB; however, I have yet to see anyone confirm if "faster shifting" associated with SAT is a matter of simply coding SAT, or if in fact EGS has different firmware to go with it.
I think too it may matter what the starting point is in terms of SPort, M-Sport, Adaptive Drive, etc.
      04-12-2013, 11:35 AM   #3248
4.8 E70
Montenegro
24
Drives: Alpina B7
Can someone tell me if I have the BT streaming or will I need to enable it via coding ? Last 7 of VIN - F477013
Thanks !
      04-12-2013, 03:41 PM   #3249
shawnsheridan
Thanks !
You have 6NL, so you have BT Streaming without coding.
      04-12-2013, 08:39 PM   #3250
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Shawn,
1) Is there an updated "F30 Cheatsheet" with options and how to etc? The first post has an old one from 2012?
2) What are my coding options for the following:
- Changing comfort mode to have stiffer steering wheel of sport, but Comfort shifting points?
- Setting Sport mode as default, I know it can be done, but is there a guide for things that aren't on the cheat sheet or do I just rummage through this thread?
      04-12-2013, 08:49 PM   #3251
shawnsheridan
Originally Posted by kromix View Post
Shawn,
Try looking here:
https://docs.google.com/spreadsheet/...Ia3ZmbUE#gid=0
I don't think either of those is codeable.
      04-12-2013, 08:56 PM   #3252
kromix
kromix's Avatar
Try looking here:
Ahh nice google doc much better....
According to a poster in another thread:
Enable Macro FDS in the HU_CIC and you can have sport steering without sport drivetrain in sport mode. Mine is manual so i don't know the effects on auto.
is that wrong? Seems to match up with google doc:
Configure sport mode Yes HU CIC 3000 Macro_fds popup_only popup_and_config you can configure the sport mode in idrive
Have you tried this option to be able to comment?
      04-12-2013, 09:15 PM   #3253
shawnsheridan
No I haven't. I have an F10 M-Sport, that stays in Sport Mode, but I set it manually every time.
      04-12-2013, 09:20 PM   #3254
kromix
kromix's Avatar
Ahh Ok i'll try that setting when I get my car, seems to be the right option i'm looking for, can't wait, Car is on a ship en route to the VPC
      04-12-2013, 10:05 PM   #3255
vithy
Hi,
I got a quote from bimmerretrofit for a Combox retrofit. They Sent me a quote with the bellow information. My F30 320i comes with Non-Nav. Just a basic iDrive with 6NH option.
According to the bellow info "Navigation map Satellite View" is shown. Does this mean i get Navigation option? Sort of confused... I have included the attachment.
Combox Media Retrofit for F-Series BMW Vehicles - $539
Features of the Combox Media retrofit:
- Album art covers (over USB port in the armrest)
- Bluetooth Audio - Office menu (for iPhone only Contacts are currently available, other phones can have text messages, Calendar, Tasks, Emails, etc.)
- Navigation map Satellite View
- New version of the Voice Control powered by Nuance including One-Shot Destination Entry feature
- Internet and BMW Live* (Optional. Please check the available options)
It may be required to have your CIC head unit internal software updated to the latest version for the Combox compatibility. Check with one of our specialists if you unsure about your CIC software version.
      04-12-2013, 10:38 PM   #3256
zibawal
Drives: 2012 X5D
Hi,
Does your car come with Navigation?
Bmwretrofit tell me that I shall need navigation before unleash the Blutooth audio function?
