03-12-2021, 12:10 PM | #23 | |
Rep 7,597
Also, i am fully aware of the ZF recommendations. It actually used to be 100,000km, so about 62k miles, but it was recently changed to 150,000km in the most recent guidance posted. Again, i have the actual documentation (see attached PDF below); I'm not just putting my opinion here, i am presenting real information. As noted, different driving conditions may warrant a shorter interval as indicated in the attached PDF. |
03-12-2021, 12:18 PM | #24 |
Rep 188
Drives: '14 BMW 640i Gran Coupe Msport
I ordered the kit from FCPeuro for $180 for my ‘14 f06 640i. I’m currently at 68,000 miles. I’ll be doing a doing drain and refill. Will report my findings on Monday!
03-12-2021, 05:20 PM | #25 |
Rep 270
I wish we or Blackstone kept a repository of fresh fluid for comparative purposes.
I will be sending my ATF for analysis once I get it done
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
sspade2464.50 |
03-12-2021, 07:26 PM | #26 |
Rep 5,457
Drives: F30
FWIW...
Blackstone has gone on record saying they dont believe servicing modern, lifetime fill auto transmissions is a necessity. This is assuming normal duty throughout the lifetime of the vehicle. Not abuse. I put a lot of weight in that considering they "do this shit for a living." Cant wait to see the results. |
03-14-2021, 11:57 AM | #27 | |
Rep 886
"Transmission oils are mainly used as a hydraulic fluid to shift the gears though an ingenious invention called the valve body. This is like a circuit board that uses oil rather than electricity, and apparently the cleanliness of the oil doesn't much affect its operation. Sure the oil also lubricates the gears, but as far as an oil's jobs go, that's one of the easiest things for it to do. The oil really doesn't even have to be very clean to do that job well. So if the cleanliness of the oil isn't that critical, then lifetime transmission oils start to make sense. What kills transmissions? It has been our experience that what kills most transmissions is heat. If the oil gets too hot it actually loses its viscosity and is no longer able to lubricate properly, which in turn causes more heat and eventually a total failure. What's the number-one cause of the oil becoming too hot? Oil volume lost due to a leak. With less oil circulating through the system, the remaining oil is stretched thinner (so to speak) and gets hot faster. It's a vicious cycle, one to avoid if possible. So in closing, if you have a "lifetime transmission oil," rest easy — there is probably no need to worry about changing it. You'll likely get sick of looking at the vehicle before the tranny dies. However, if you notice your transmission starting to leak oil, that's the time you'll want to have it fixed because its lifetime will quickly expire if you don't. Just be sure they put the right oil back in!" |
03-14-2021, 12:38 PM | #28 | ||
Rep 5,392
I've read that ZF the manufacturer of this automatic transmission for BMW and other makes, recommends AT service at 60k miles/100k kilometers. With a Stage2 tune I decided to service my transmission at 40K miles with a ZF kit from FCP Euro. Can't get any better than a ZF Kit. My Indy mechanic required me to leave it overnight so they could do it first thing in the morning for best chance of draining as much original fluid as possible. During the procedure my transmission took 5.75 liters of ZF fluid. |
03-14-2021, 06:35 PM | #29 | |||
Rep 886
03-14-2021, 07:30 PM | #30 | |
Rep 3,946
03-14-2021, 07:56 PM | #31 | ||
Rep 5,392
03-15-2021, 07:44 AM | #32 | |
Rep 3,946
Draining the transmission takes 10 mins. And it's completely done within 5 mins of you removing the transmission oil pan. |
johnung4526.50 |
03-15-2021, 11:04 AM | #33 |
David
786
Rep 2,010
Lots of people with passive aggressive comments that are mad they never changed their fluid and trying to justify it. Might as well follow BMWs 10k mile OCI since you're all such perfect drivers that never exceed the bounds of "normal operation".
No fluid is lifetime, maybe if you get off the lot and never get off the highway for 200k miles. Your transmission uses friction material to operate, and generates heat, nothing is forever. I'd rather have peace of mind and follow what ZF says, end of story.
LA1Z24356.00 |
03-15-2021, 03:45 PM | #34 | |
Rep 886
Wgosma806.00 |
03-15-2021, 05:16 PM | #35 | ||
David
786
Rep 2,010
03-19-2021, 06:55 PM | #36 |
Rep 5,457
Drives: F30
@328iX
Let me say it clearer for you: Blackstone has gone on record saying they dont believe changing the oil is necessary* on "modern, lifetime fill transmissions." Blackstone is a company that scientifically tests fluids and is certified in doing so. Hopefully it sinks in this time. *under normal operating conditions. |
03-19-2021, 06:59 PM | #37 | |
Rep 5,457
Drives: F30
Wonder why BMW dealerships aren't selling the shit out of this service considering the ZF 8HP is almost in their entire lineup? I've personally been turned away when trying to have this done at Elk Grove BMW. Gave me the old "we'll do it if you want but its not recommended and has caused issues in the past." I was basically ready to hand a dealer in Northern California (with a labor rate of $175/hr) a check and they passed on it. That's gotta be a first! Obviously changing the oil by following the exact procedure provided by ZF isn't a terrible idea. It's just probably not necessary for a majority of BMW owners. |
03-19-2021, 07:31 PM | #38 | ||
David
786
Rep 2,010
Yes if you're high mileage and it's your first change they might advise that. Once again, don't care what blackstone says, not all people are within "normal operating conditions". Let me ask you this? Do you do a 10k OCI? Why or why not? Surely you're such a great driver right? Why not just follow what BMW says? Edit: looking at your posts it's appears you've cut BMW's recommendation in half to 5k mile OCI
03-19-2021, 08:34 PM | #39 |
Rep 234
I did mine at 68k and the fluid was already almost black. I couldn't imagine waiting until 100k+. ZF recommends 60k so BMWs "lifetime" fluid is just a marketing gimmick to reduce maintenance costs. This is why BMW had so many transmission failures back in the days of the gm trannys.
I'm at 73k now and my trans feels fantastic. I plan to stick with the 50-60k recommendation from ZF.
03-19-2021, 09:15 PM | #40 |
Rep 1,604
Exactly this. This is very common across industries. They'd be crazy not to recommend that people change the fluid at certain intervals.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
03-19-2021, 09:18 PM | #41 |
Rep 1,604
With that logic, I suppose there's an epidemic of ZF transmission failures now? Because the vast majority of owners aren't on this forum and most of them are following BMW's maintenance schedule i.e. not changing the trans fluid.
03-19-2021, 09:38 PM | #42 | |
Rep 234
03-20-2021, 07:53 AM | #43 |
Rep 1,604
I am sure BMW must have had trans problems in the past, but that is not a BMW issue, it is a trans manufacturer issue. Doesn't necessarily extrapolate to the newer ZF transmissions just because they are in a BMW.
03-20-2021, 08:13 AM | #44 |
Rep 886
Guys, I'm the OP. Can we all please just take it easy. I didn't create this thread to cause debate on whether the fluid is Lifetime or not.
I've simply created it to share my own experience and also my blackstone analysis; assuming it ever gets here! |
ErkanTR16598.00 |
