BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > M240i
      05-18-2016, 07:25 AM   #45
Rukka
Rukka's Avatar
2647
Drives: M4 Comp
Originally Posted by dopper99 View Post
Basic question, but what is the difference between the M135/M140i (ie the M Lite version of the car) and other normal M Sport versions of the 1 series?
Is it better springs, dampers, ARBs?
Seriously......
Front ARB - Same as standard across F20 range. Interestingly, same as 435i GC too.
ARB Swing Support - common part across a lot of F20/30
Rear ARB - For m135/235i models only
Dampers seem model specific (no spring rate info)
Front Brakes - Caliper and disks are common across F20/F30's
Rear Brakes - Caliper is 135/235i specific - Disk is common across F20/F30's
Differential - 135/235i models only
Gearbox - 135/235/ - also same part as 6 Series (petrol) and 7 Series (petrol)
Steering Rack - common across F20/F30 range
So to summarise; in what makes the M235i "special" is.........
Rear ARB, Dampers and BADGES.... lots and lots of M Badges
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87
      05-18-2016, 07:46 AM   #46
JNW1
Drives: F56 Mini Cooper S
And perhaps most important of all, what resides under the bonnet (which is just about to get better still!).
      05-18-2016, 08:08 AM   #47
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Originally Posted by WeaverBeaver View Post
Probably software setting an artificial ceiling so as not to step directly on the M2's toes, with torque dropping off slightly sooner or higher peak revs in the M2 - maybe leaving room for MPPK?
Some baseline by the Jb4 guys during beta testing Jb4 on B58, it seems the comment is more or less correct.
JB4 "opens up" the upper rev range more so than EWG N55 as B58 is holding more boost longer higher up the rev range than N55.
I have Jb4 stg 2 on ewg M135i and the difference up top is noticeable between switching JB4 off and on to one of its absolute maps. B58 will be even more of a scorcher no doubt....
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
