05-18-2016, 07:25 AM | #45 | |
Rep 3,664
Seriously...... Front ARB - Same as standard across F20 range. Interestingly, same as 435i GC too. ARB Swing Support - common part across a lot of F20/30 Rear ARB - For m135/235i models only ARB Swing Support - common part across a lot of F20/30 Dampers seem model specific (no spring rate info) Front Brakes - Caliper and disks are common across F20/F30's Rear Brakes - Caliper is 135/235i specific - Disk is common across F20/F30's Differential - 135/235i models only Gearbox - 135/235/ - also same part as 6 Series (petrol) and 7 Series (petrol) Steering Rack - common across F20/F30 range So to summarise; in what makes the M235i "special" is......... Rear ARB, Dampers and BADGES.... lots and lots of M Badges .
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
05-18-2016, 07:46 AM | #46 |
Rep 5,681
05-18-2016, 08:08 AM | #47 | |
Rep 4,516
JB4 "opens up" the upper rev range more so than EWG N55 as B58 is holding more boost longer higher up the rev range than N55. I have Jb4 stg 2 on ewg M135i and the difference up top is noticeable between switching JB4 off and on to one of its absolute maps. B58 will be even more of a scorcher no doubt....
Current '22 X3M LCI.. |
