BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > WAGNERTUNING Radiator Kit BMW F-Series B58 Engine
      10-30-2018, 05:44 AM   #45
TWIN-SCROLL
Drives: 440i xDrive Gran Coupé MPPSK
Got my car back and testing it at the moment of writing...
      10-30-2018, 09:20 AM   #46
mike@x-ph.com
mike@x-ph.com's Avatar
https://x-ph.com/sale/
Phone number 702-494-9435
      10-31-2018, 11:59 AM   #47
B58
B58's Avatar
558
Drives: 922 Turbo
Looks good. I don't see why this shouldn't help.
2024 X3 M40i
2014 BMW M5
      11-04-2018, 04:25 PM   #48
TWIN-SCROLL
Street driving : not so much difference to be honest. Real test will be track but worse case scenario it will not be before May next year for me.
So, to what I found so far.
My usual trip from home to the exit of the highway almost made me reach the temperature of 100°C where I felt safe to go in Sport+. Now I feel I've reached it slower but it can be because of weather getting cooler.
First time I drove it on the highway in Sport+, I was surprised because after reaching temperature of around 110°C, coolant temp then quickly dropped, even under 90°C (I've reached 89°C actually).
Driving like usual the following days in the city, nothing much changed BUT spirited driving on the highway today, it dropped to 90°C.
So my conclusion is yes, a bigger radiator is of course helping getting coller but in this case it helps getting cooler FASTER.
BUT ! Now I think I may have an issue and maybe you guys can help me get around it.
Since installation, I have an intermittent though rather periodically often motor noise (at first it sounded to me like a phone call from an other car, no kidding !) Opening engine bay I can hear distinctly this noise in the vicinity of the coolant tank.
Could it be cooling pump OVERWORKING because of of the mucho extra coolant ?
I believe my shop but the right amount, I even told them it was more than 17 liters but I will book with them an other just in case to have a look.
Do you think it could damage the pump or reduce it's work life ? Is there a way to replace it with a stronger model ?
Cheers.
jalx16.50
      11-05-2018, 12:35 PM   #49
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
Why are you measuring engine coolant temps when you've upgraded the capacity of the water-to-air cooling circuit?
      11-05-2018, 05:43 PM   #50
TWIN-SCROLL
I read water temperature on the M Performance steering wheel with screen, you make me doubt but are you sure it is only engine water temperature I'm reading ?
      11-05-2018, 08:08 PM   #51
BLACK HAWK DOWN
BLACK HAWK DOWN's Avatar
Drives: 16' AW 340i xDrive
Isn't it one radiator that does double duty, Engine and Water to Air Intercooler?
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
      11-06-2018, 02:04 AM   #52
TWIN-SCROLL
No it's not, engine cooling circuit have it's own radiator behind charge air coolant radiator.
Maybe I was reading engine temp all the while, silly me !
By the way, if you look at realoem, you can see that there is 3 different variations of cooling system, one without, one with 1 (my car I suppose) and one with 2 small auxiliary radiators.
I still feel that oem water pump for charge air cooling circuit is now too small for the task and it's overworking with twice the amount of liquid to pump.
      11-06-2018, 05:24 PM   #53
NISFAN
NISFAN's Avatar
Drives: BMW M2
Amount of coolant will not labour pump more.
Wow, what a ridiculously large cooler, the intercooler now has more coolant in it than the engine radiator? Pointless mod right there.
      11-07-2018, 01:40 AM   #54
TWIN-SCROLL
Pretty harsh comment there.
It is the same as putting a bigger air-air intercooler but in the case of B58, charge air intercooler is integrated in the intake manifold so the only way to actually do something was to but a bigger water radiator.
Will check my issue with the shop when I come back from business trip.
      11-10-2018, 02:26 PM   #55
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
Definitely just engine coolant temp on the wheel.
The 3rd variation is for the newer cars fitted with the petrol particulate filter (PPF)
As stated above the pump will not suffer with more volume.
I'm inclined to agree and disagree. The radiator portion of the water-air system has been increased in terms of raw surface area and should lend itself to a degree of improved heat transfer capabilities. The additional volume however I suspect will make very little difference once the water-air circuit is up to temperature. The time it takes to reach that temp will likely increase marginally.
      11-10-2018, 03:29 PM   #56
kern417
Cheapskate
4450
I think the main thing to consider is that you'd definitely want your intake air temps to be less than that of your engine. Granted, you have a lot less load on the intake cooler. But there's a reason why you see racers put ice in their intercooler tanks. Cool intake charge is the most critical thing for engine performance and health, especially in turbo applications.\
However, I don't feel like I've seen anything that indicates this mod is needed for 99% of the forum members.
      11-10-2018, 09:52 PM   #57
BLACK HAWK DOWN
It isn't.
kern4174449.50
      11-11-2018, 03:41 AM   #58
NISFAN
NISFAN's Avatar
Drives: BMW M2
Good post!
It seems many look at an intercooler the same way they do an engine cooling radiator circuit. It's not, you want it to work completely differently.
In an intercooler you want a very fast responding, efficient cooling system. Bigger is not automatically better. That is why air-air systems are hard to beat, they have an in-line cooler that gets busy when a big boost event occurs, then quickly settles after. You want the system to have as little capacity in it as possible otherwise your intercooler spends a long time being an interheater. A bad thing.
Comparing to air-air systems, the N55 has a frontal area probably only 20-25% of the standard water-air B58 unit. The air -air unit is also probably 4 times deeper to compensate. However in cooler design, the second half of the depth is only about 25-30 percent of additional cooling, a function of lower delta t, and capacity of already heated air to carry heat.
When you consider all the above, you realise that the B58 is fitted with a massive upgrade on the N55, stock. But with conscious consideration to keep the whole mass of coolant down for fast cycling response. Looks to me to be an optimal design.
I honestly can't see how adding 15kg of coolant and radiator to the very nose of the car is a good performance mod. :
Bee Pee1779.00
lpaulodt214.50
      11-11-2018, 12:11 PM   #59
kern417
Cheapskate
4450
Good post!
i think ultimately it's less about cooling the intake air during high load and more about keeping the air consistent. Even with an air to air cooler, adding volume past a certain point doesn't improve cooling but increases pressure drops and other potential downsides (see the Focus RS cooler with a blockoff plate to prevent condensation inside the intake charge path). At least with this system it is literally only improving the cooling capacity by making the coolant a larger heat sink.
      11-19-2018, 02:53 AM   #60
liteprata
Drives: F20
Wouldnt the larger amount of water allow for a more constant temp for a drag race?
Actually i was hoping that the DME, when hacked, would allow us to control the low pressure coolant pump duty cycle as well as the rad fan so that i have more cooling....
      11-19-2018, 11:32 PM   #61
Bmwbeezy
Drives: Stock
Cheers.
Were you able to find a fix for your issue?
      11-21-2018, 06:21 AM   #62
TWIN-SCROLL
Between travelling out of home and being sick, I didn't had time to go back to my shop.
      11-21-2018, 08:35 AM   #63
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Sorry for being obtuse - is this giant radiator JUST for the air/water intercooler? If so - my god, thats large. I would probably have just considered putting a large reservoir in to add capacity.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
      11-28-2018, 12:24 PM   #64
Bmwbeezy
Drives: Stock
Have you had an opportunity to find the issue?
      12-08-2018, 11:06 AM   #65
kern417
Cheapskate
4450
Cheers.
That's not how pumps work. It's fine. It's going to flow the same volume of fluid regardless of how much is in the system. It's not like your fuel pump works harder when your gas tank is full.
      01-22-2019, 03:43 PM   #66
TWIN-SCROLL
GUYS, PROBLEM IS FINALLY SOLVED !
Long story short, my garage found that the culprit was a faulty ground in the electrical system. Took him 2 days to figure it out.
This ground problem lead to the pump noise problem, plus it happened to also trigger the front fan abnormally AND I had a loss in power past 4500RPM too.
Truth be told, I did a dyno run before Christmas and I was too ashamed to report it here... Ground problem also screwed up engine map apparently.
Now it's sorted, I need to find time to test the car more deeply before transmission flash and engine tuning, I have a new tuner in my area who has a franchise of BR-Performance, a well known tuner in Europe.
Stay tuned but I'm so relieved for now !
