07-09-2018, 05:59 PM | #1 |
Rep 190,807
WAGNERTUNING Radiator Kit BMW F-Series B58 Engine
The 3.0 Liter B58B30M0 turbo engine of the specified BMW models is equipped with an indirect charge-air cooling circuit. So the cooling of the charged air is not realized by the ambient air as cooling medium (as usual), but made with its own cooling water circuit. A reduction of the temperature of the cooling water is directly equated with an improved cooling performance of the charged air. This is exactly where the advantages of the WAGNERTUNING upgrade radiator comes into play. The new developed competition racing core of the WAGNERTUNING high performance radiator increase the radiator volume of the OEM water cooler by a total of 117 %. The calculated ratio between the inner and outer cooling surface generates a maximum heat transfer and allows at the same time enough air flow for the surrounding components (for example the engine radiator) for its own heat exchange. Furthermore, using an increased amount of cooling water, the entire system thermics can be kept at a lower level over a longer period of time. All WAGNERTUNING radiators are equipped with a heat-conductive anti corrosion coating to ensure a lasting cooling effect. The plug & play installation of the system is simple and easy to perform (an installation instruction is included as well). Dimensions OEM radiator: 576 mm x 495 mm x 27 mm V = 7,70 Liter A = 2851 cm² Dimensions WT radiator: 524 mm x 468 mm x 68 mm V = 16,70 Liter A = 2454 cm² Competition - Radiator - Kit for the BMW B58 Engine (M140i, M240i, 340i, 440i)
THIS ITEM CAN ONLY BE USED IN A COMPETITION RACING VEHICLE THAT IS NOT DRIVEN ON PUBLIC ROADS, UNDER CALIFORNIA STATE LAW IT IS NOT LEGAL FOR USE IN ANY OTHER MOTOR VEHICLE!
07-10-2018, 07:52 AM | #4 |
Ridin' thru Atlanna
26
Rep 64
Drives: 2017 340i M Sport Dinan S1
Any legality concerns in other states, or only California? Also, any other advantages offered with this unit in addition to better cooling? Does it weigh less? What is the product price? Thanks.
Current: 2017 F30 340i Mineral Grey/Black Dakota - 8-sp AT - M Sport - Track Handling - Driver's Assistance - Technology - Adaptive M Suspension - Dinan ECU Flash - Dinan FreeFlow Exhaust
Past: 2007 E92 328i Space Grey/Black Leather - Sport - 6-sp Manual 2004 E46 325ci Grey/Grey Leather - Sport - 5-sp Manual |
07-10-2018, 12:06 PM | #5 | |
Rep 190,807
07-10-2018, 05:03 PM | #6 |
Rep 1,457
You’re still the best parts vendor at least from my experience... off topic just thought I would let you know lol
AddictedTo///M217.00 mike@x-ph.com24199.00 |
07-11-2018, 03:59 PM | #7 |
Rep 190,807
Thank you!!
07-12-2018, 05:50 PM | #9 |
Rep 190,807
Thank you for the support!!
07-12-2018, 06:46 PM | #10 |
Rep 559
07-12-2018, 10:40 PM | #11 |
Rep 354
Mike please ask a vendor to produce a 340 radiator rock guard for the generation of cars before it came standard but is not backwards compatible.
07-13-2018, 12:47 PM | #12 |
Rep 190,807
07-13-2018, 12:48 PM | #13 |
Rep 190,807
Will do
07-15-2018, 01:29 PM | #14 |
Rep 10,256
Please add me to the list. In December 2017, BMW made a production change adding radiator guards. B58 equipped vehicles built prior to this date do not have radiator guards.
07-15-2018, 03:17 PM | #15 |
Rep 314
07-16-2018, 12:38 PM | #17 |
Rep 10,256
09-30-2018, 05:44 PM | #18 |
Rep 1,348
I’m sure it helps a lot vs the stock small radiator.
2k15 335i Msport xdrive 6spd
10-03-2018, 09:46 AM | #20 |
Rep 190,807
10-04-2018, 05:06 PM | #21 |
Rep 79
But let's take it with a grain of salt, they may only start production in a dozen of days, I wonder when it will really be available.
Anyway, I think I should post a direct link to the page : http://www.wagner-tuningshop.de/prod...0001002-6.html |
