01-07-2024, 05:14 PM | #1 |
Rep 1,382
Which are the correct bearing bolts
About to use the official bearing repair kit to stop suspension clicking (comes about after making suspension changes).
I need to undo the bearing which means I will need to replace the bolts as they're all torque to yield.. however I cannot for the life of me figure out which are the correct ones. 31206872920 - M12X1.25X45 31206783065 - M12X1,5X45-10.9 I did work this out a while ago but I have since forgot! Basically BMW switched the thread pitch on their bearings mid production. My car is a March 2015 435i F32.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
01-08-2024, 09:18 AM | #2 | |
Rep 1,370
01-09-2024, 02:35 PM | #3 | |
Rep 3,947
RealOEM does list it correctly based on the part number of the actual wheel bearing. However, it takes a bit of interpretation skill to figure it out. You can actually cross reference your findings with the OE wheel bearings on FCPEuro. There will be a disclaimer that tells you the correct bolt part numbers for the bearing part number. |
01-10-2024, 06:35 PM | #5 |
Rep 3,947
01-17-2024, 04:37 PM | #7 | |
Rep 1,382
The repair kit is made for people having a clicking noise under load turning. It usually comes about the second you adjust ride height. What happens is corrosion builds up between the bearing face and hub face, you have to sand it down and then apply the repair adhesive to prevent any further corrosion before refitting your old bearing. This was released after the teflon discs only provided a mid-term solution to the clicking noise.
2015 435i - 401whp
