09-06-2021, 05:05 AM | #1 |
Rep 309
Rear right Brake and indictator bulb fault
I've got a random intermittent issue with my rear right brake and indicator bulbs failing. Seems to be happening with increasing regularity now. I assume changing the bulbs won't do a thing as I feel it's something slightly more sinister...
Is this a known, common issue? |
09-06-2021, 07:23 AM | #3 |
Rep 8,093
Faulty earth on the cluster. Wire an extra earth link to the cluster, job jobbed.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
mcscoobs169.00 |
09-15-2021, 07:55 AM | #4 |
Rep 309
So I've taken the cluster out and had a proper look. Looks like the prong has melted into the connector (not sure if pics show it)…. How do I fix this?!
09-15-2021, 08:45 AM | #5 |
Rep 34
My grandfather had the same thing.
A garage wanted to replace the entire unit, but a local specialist advised it just needed a module change or something inside the headlamp unit :-) |
09-15-2021, 08:51 AM | #6 |
Rep 309
Well randomly, I cleaned it up and put it back together, and now it's working perfectly fine... but how?! Very bizarre! I expect it's only a matter of time though
