09-25-2017, 02:06 PM | #89 | |
Rep 525
I'm not planning on hooking my car up to anything and was thinking to simply drain/replace the oil/pan/filter then do the leveling procedure. |
10-03-2017, 01:55 PM | #90 | |
Rep 230
Where the temperature is important - viscosity. When it is too cold, it may not fill components properly. |
12-23-2017, 04:38 PM | #91 |
Rep 6
question about fluid replacement
I have been reading this thread with interest as I am about to service the trans on my 2014 328 GT. His is the fluid repalcaed, is a pump used or is it gravity fed from up top? Thanks!
12-23-2017, 04:48 PM | #92 | |
Rep 3,947
I used this: https://www.motiveproducts.com/colle...-1-gallon-tank |
02-28-2018, 10:29 AM | #93 |
Rep 4
There is an alternative to either the BMW or the ZF ATF. Liqui-Moly's Top Tec 1800 ATF was specifically formulated for the ZF 6HP19/26/32 AND the 8HP45/55/70/90 transmissions. You can order it from Napa in the US for $11.49/liter I've attached link to the info sheet on Liqui-Moly's website and also pasted the URL from Napa.
https://pim.liqui-moly.de/pidoc/P000...00-41.0-en.pdf https://www.napaonline.com/en/p/AOCLM20032
Some make things happen
Some watch things happen The remainder have no clue what happens |
03-13-2018, 08:59 AM | #94 | |
Rep 26
I'm also thinking I will do the rear differential at the same time, anyone have a recommendation for what to use there? |
08-09-2018, 08:31 PM | #95 |
Rep 316
what is the consensus on this? Have most of you forgone the computer re-calibration? And who actually waited until the temps came down before topping up?
08-11-2018, 09:19 AM | #96 | |
Rep 10,351
When the ATF gets replaced maybe twice in the vehicles lifetime there's zero justification for not using OE (eg ZF) fluid. Saving $40 isn't worth it
"Drive more, worry less. "
scostu1623.00 |
08-12-2018, 03:18 PM | #97 |
E46 Fanatic
41
Rep 152
Full ATF exchange on GA8HP45Z
Just completed a full ATF exchange on the wife’s 2013 X1 sDrive2.8i. This was not simply a 4.5 quart drain and fill. The old fluid was pumping out of the ATF cooler pressure line into a large catch container while new fluid was pumped into the fill port on the AT by an electric oil pump. Luckily both fluid rates were about the same.
Here are the steps I followed: - Put the car up on four jackstands so it was level and high enough for me to crawl under and work. Set the parking brake to prevent rear wheel turn. - Cracked open the fill plug at the rear right of the AT. - Opened the drain plug on the AT pan and drained the ATF into a container. - Replaced the AT pan with a new one and torqued the bolts to spec. Bought the kit (including new bolts) at FCP Euro. https://www.fcpeuro.com/products/bmw...zf-24118612901 - Removed the fill plug and pumped new Valvoline MaxLife Multi-Vehicle ATF in until it started dripping out. It states it’s ZF LifeGuard 8 compatible. https://sharena21.springcm.com/Publi...2-ac162d889bd1 https://www.walmart.com/ip/Valvoline...allon/15125768 - Disconnected the pressure line at the ATF cooler and pushed a 9/16” OD PCV hose into that line and routed it into a large catch container. It fit snug enough, but I also wrapped some duct tape around the connection for good measure. Capped off the open ATF cooler port. - A helper started the engine, ran it up to 2k RPM for about 5 seconds to fill the TC, then let it idle while moving the AT gear selector into R, D, 1, 2, 3, etc. All this was happening while I used this electric oil pump with one line in the new ATF jug and the other line held in the AT fill port. https://www.ebay.com/itm/12V-Motor-O...-/161813526114 - Another helper kept an eye on the old fluid draining out in case it started to bubble due to the ATF sump going empty. They also let us know when the fluid looked clean and new. - It took about 1 minute to empty a 1-gallon ATF jug into the AT. Then the helper would shut off the engine while I swapped out for a fresh ATF jug. - We did this three times for a total of three 1-gallon jugs before the fluid coming out the ATF cooler line looked new. - Reconnected the ATF cooler line. - Made sure the ATF was warm enough and then followed the ISTA top-off procedure. - Torqued the fill plug and cleaned up all connections. Job done! Total cost: about $200 3 gallons of Valvoline MaxLife Multi-Vehicle ATF from Walmart @ $18 each 1 AT filter kit from FCP Euro @ $150 1 electric oil pump with lines from ebay: $20 Last edited by Bali; 08-12-2018 at 07:53 PM.. |
08-12-2018, 08:48 PM | #98 | |
Rep 799
08-13-2018, 12:37 AM | #99 |
E46 Fanatic
41
Rep 152
08-13-2018, 09:09 AM | #100 | |
Rep 716
Did you reset the transmission adaptation using a scantool? |
08-13-2018, 09:16 AM | #101 | |
Rep 716
08-13-2018, 04:17 PM | #102 |
Rep 884
I'm at 75,000 miles and am terrified of having the fluid changed on my 8HP45. Every place I go to (including the local dealer) tells me they are happy to perform the service but will take zero responsibility for an issues post fluid replacement i.e. clutch packs start to slip etc.
Please give me your honest thoughts. I'm not in a position to pay $5-7K for a replacemy tranny; should things go south. I do intend to keep the vehicle for 10 yrs; so am keen on prolonging the life of the transmission. |
08-13-2018, 06:19 PM | #103 |
Rep 864
Change it - with the ZF Pan & Fluid
When changing the fluid only 5qt are removed and the torque converter holds 2 qts . So 2 qts remain holding the small particles of super fine metals which actually help an older transmission maintain its integrity.
. However - do NOT hook the car up to a flush machine. Do a traditional pan replacement and drain & ask the indy how they will ensure the proper fill using AT oil temp. . I recommend Lifeguard fluid & ZF Pan -- FWIW Change between 60 - 75k is in the good range Last edited by 123Britt; 08-13-2018 at 06:20 PM.. Reason: Spelling |
08-17-2018, 06:59 AM | #104 | |
Rep 10,351
Second, ZF has a 100k mile change interval for normal driving and a "severe service" interval of 45-65k miles. So you're in between that. Third, sometimes neglected AT's develop shift problems after a fluid change (especially when a flush is performed). The shop gets blamed when it's actually in the owner. The units of today adapt on the fly to the new fluid so this issue should occur less and less. What little UOA's there are on ZF fluid show that it can go for 70k miles. Doing a pan drop as recommended by ZF should not cause and issues. Just use ZF fluid and parts.
08-28-2018, 01:23 PM | #105 | |
Rep 5,088
08-28-2018, 02:02 PM | #106 | |
Rep 52
I had mine done at around 80k miles... no issues. Bought everything from FCPEuro. |
08-31-2018, 07:12 AM | #107 | |
Rep 424
F32Fleet3570.00 |
10-29-2018, 08:46 AM | #108 | ||
Rep 884
"We are capable of doing it. I'm assuming my employees are trying to look out for your best interest and don't want something to get worse by changing the fluid. I'm happy to do it just don't want to be liable if the clutches slip or something happens after fluid change that we wouldn't have control of." How does one get comfortable taking this type of risk on an $8K piece of hardware??? Polo08816 performed the fluid change. He's now had his tranny replaced under warranty at 97K miles. Had he not been covered under warranty; he'd be looking at an $8K bill. I'm not saying his tranny failed because he changed the fluid. However, I don't think he can unequivocally say that it didn't fail because of the fluid change, either. |
10-29-2018, 09:36 AM | #109 | |
Rep 3,211
but I guarantee you one thing.. if you don't replace the tranny fluid at reasonable intervals your sludge buildup will guarantee your tranny fails BMW doesn't make these units and even ZF (the manufacturer) suggests every 60k miles on change keep in mind in the good ole dayz tranny oil was changed much much earlier synth oils have improved since BUT are not IMMORTAL caveat: if you've let the tranny go over 90k (which already sounds ridiculous to me) or so without tranny fluid changes.. yes you may be risking some failure the point is to not get to that point |
10-29-2018, 10:11 AM | #110 | ||
Rep 884
It's a total effing crapshoot. The view of the Indy shop is that these trannys fail between 150-200K anyway; whether you change the fluid or not; so why take the risk. |
