01-11-2017, 09:24 AM | #23 | |
Rep 1,349
Drives: BMW F80 M3
01-12-2017, 03:16 AM | #24 | |
Rep 681
Do you use it on track or for long pull on mountain roads? Or just for some short pulls (2nd-3rd-4th-5th gear and stop)?
BMW M3 G80 Isle of Man
04-29-2017, 01:09 PM | #25 |
Rep 34
Hi, My ZF 8hp45 is slipping at 5th and 6th. Logs show that even after gear change, rpm rises immediately and car does not accelerate much.
Is there any way I can swap in a torque converter that is stronger? Or buy aftermarket clutches? |
04-29-2017, 03:28 PM | #26 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I'd have to open one up to see what interchanges with the higher torque models, how thin we could go with the clutch steels and how much could be taken off of the pistons. But, I could potentially build up clutch packs with increased clutch count and closer tolerances.
I've been wanting to crack into the ZF 8HP anyhow, since it's so ubiquitous. I'll start looking for a spare 8HP45 AWD transmission to develop on. If anybody comes across one for cheap, let me know. Anything under $1000, with transfer case still attached, is a good price.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
04-30-2017, 01:34 PM | #27 | |
Rep 77
Saw your whp and lbft numbers, can you share what mods one would need to get to that level please? |
04-30-2017, 06:54 PM | #28 | |
Rep 709
Then you can start messing with meth, ethanol, and turbo upgrades. Lots of threads on flash tunes, most popular being BM3
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
maxio19.00 |
04-30-2017, 07:03 PM | #29 |
Rep 3,211
Sure, torque converter, clutchpacks, shafts etc can be upgraded
01-25-2018, 07:51 PM | #30 |
Rep 2,357
Who has experienced this? Is the consensus that this is a gearbox safety feature and that the solution (smart thing for longevity) is to run a lower boost target in 6th?
hardparker Polo08816 Darkiedm4 obriennathaniel
(A Dane in China) |
01-25-2018, 08:30 PM | #31 |
299
Rep 531
We'd have to see what clutch sets are engaged in sixth and see if it's a physical limitation. In that case, it may be prudent. Otherwise, I suspect it's a value hiding in the DME somewhere that can be flashed out. Either way, I say edit it to some unattainable value, once found, and lets see what breaks! Then, more clutches!
01-25-2018, 11:35 PM | #32 |
Rep 1,349
Drives: BMW F80 M3
See the technical specs:
https://www.motor.com/newsletters/20...8HP_Tranny.pdf In 6th gear clutches C, D, E are engaged which is said to put more stress on the unit hence bmw limits torque in the ppk for 335 to 400nm in 6th gear (while other gears are 450nm). If there is some torque limiter in the dme why nobody found it after 5 years of being able to flash these? Then again i have not seen of any zf8 speeds blowing up yet... |
01-26-2018, 01:38 AM | #33 |
Rep 488
At least one good thing about the AH3 is we get the GA8P70H (8HP70), so it's max is 700nm (a 250nm increase). Even with that, I can still feel the torque limiter when I hit 6th.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
harkes1077.00 |
01-26-2018, 08:55 AM | #34 | ||
299
Rep 531
Long story short, get to breaking the 8HP45 and I'll whip up a solution for us. I've done similar in the past: http://legacygt.com/forums/showpost....&postcount=129 http://legacygt.com/forums/showthrea...ts-210357.html
Seba77W401.00 |
01-27-2018, 01:36 AM | #35 | |
Rep 1,291
The ActiveHybrid uses a 8p70h transmission rated to 700Nm and i had the same issue with jb4
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
01-29-2018, 03:52 AM | #36 |
Rep 2,357
Halim has promised me something to test for this issue so I'll keep you posted.
01-30-2018, 06:30 PM | #37 |
Rep 2,357
01-30-2018, 07:39 PM | #38 |
Rep 57
I'm sorry if this is a dumb question, just trying to clarify. The 8HP45 handles 450nm of torque as input power from engine which is about ~340 TQ. JB4 Stage2 and some minor mods on 328i pushes 300 or more TQ to wheels, meaning, without drivetrain loss (15% or so) we'd be at that 340-350 "max" base engine TQ.
Are we theoretically exceeding the TQ specs on our trans? I've read in other threads the 8HP45 has a 500nm limit, some others 450nm. I'm confused as I believe to have seen links for both. The 340's with JB4, equipped with the same trans (anything with an inline 6 and turbo with the 8HP45), plus the JB4, it would almost venture into saying they are exceeding way beyond the TQ design of the unit. What's the real story?
Alpine White 328i F30 - JB4 STG2 / VRSF FMIC / CW DP
Torque gets you going, HP keeps you going. |
01-30-2018, 09:00 PM | #39 | |
Rep 488
Page 8: https://www.motor.com/newsletters/20...8HP_Tranny.pdf
02-01-2018, 10:09 AM | #41 | ||
Rep 57
03-19-2019, 08:48 PM | #43 |
Rep 2,357
With xHP out and increased clutch pressure I think there is little need for any mechanical modifications. I am putting ~650 wheel Nm (760 crank Nm) through mine at the moment and has been doing so on and off the past 4 years without issues.
(A Dane in China) |
03-20-2019, 05:15 AM | #44 | |
Rep 109
wouldn't it be better 550Nm in the medium range? for traction and engine/gearbox wear. I am not criticizing just asking thanks. |
