02-08-2019, 01:13 AM | #419 | |
Rep 6
02-08-2019, 08:06 AM | #421 |
Rep 1,237
Drives: M2 Competition
Carly needs its own, a dedicated one.
For Bimmercode and many other apps i can highly recommend the Veepeak BLE
02-08-2019, 11:06 PM | #422 |
Rep 388
Thinking about purchasing bimmer code. Will this affect my factory warranty ? Also does coding your have the potential to mess something up. I wouldn't do coding in expert mode just in normal mode.
02-09-2019, 01:49 AM | #423 |
Rep 14,115
Drives: G82 M4C X-Drive
The risk is low but there is a risk especially if you use a WiFi adapter. Get a Bluetooth adapter and don't skip any of the steps. I've coded 3 of my own bimmers and haven't had any issues with warranty. If you brick the car, you can supposedly restore from a backup on the app. I'm guessing worst comes to worst you just have the car towed to the dealer and they will reflash it. It's software so there shouldnt be permanent damage even if you mess it up.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
02-09-2019, 09:07 AM | #424 |
Rep 1,237
You can't programm ECU's with BimmerCode. You can only code „options", nothing more.
Sure if you go completely mad you could code things that certain parts of the car migjt no longer work as expected, but its highly unlikely to destroy anything and have to be towed.. Just do one thing at the time, enter flight mode while coding and make sure both car and phone have enough power left in the batteries. Then it's 99'9% safe.
02-10-2019, 01:03 PM | #425 | |
Rep 6
02-10-2019, 05:54 PM | #426 | |
Rep 388
02-28-2019, 07:43 AM | #427 | |
Rep 910
TWO TOP TIPS Looking at some of the problems people are getting with Bimmercode, that is the rare but serious "my car has been wrecked and the dealer had to reprogramme" problems, there is a consistent theme. It has little to do with whether basic or expert mode has been used , although expert mode is best left for people who understand the concept behind fdl coding. The reason things may go badly wrong with Bimmercode and why they cannot then be fixed is due to two underlying factors, firstly that Wi-fi or bluetooth is used rather than an Enet cable , this is a less stable communication route. Top Tip one is to make sure you use airplane mode (no calls, texts etc) and only enable the function (Bluetooth or wireless) your obd dongle uses. I prefer not to use bimmercode with a wieless dongle (it is too vunerable to interference, I use the Bluetooth version as it has limited range and less risk of external interference) similarily I would rather not use a mobile phone to code as there are background functions working even in flight mode, Any interruption in coding , whether due to incoming call, app software updates, text message etc can corrupt read or write data. I use an iPad without 3G/sim, I disable wireless and use Bluetooth., I close all other apps on the device before opening Bimmercode. Also during coding, with the iPad, I put my mobile phone in flight mode and leave away from the car. This is due to the risk of it accidentally connecting to the car during coding. Jmciver advises you clip in driver seat belt to stop auto “shutoff” of the ignition after approx 7 minutes. Ensuring read or write data is not corrupted is critical when you consider underlying factor two. The second and probably main underlying problem with Bimmercode is failure by users to understand how the coding process works,. Bimmercode reads the ecu, it uses this "read" to create the back-up and after you make coding changes it uses the modified "read" data to write back to the ecu. If the read data is corrupted, Bimmercode may continue working but your back-up and write (coding) would both be corrupted. This may effectively "brick" the ecu requiring dealer rebuild. Top tip Two - I always read the ecu I want to code, find changes then I exit the ecu and disconnect Bimmercode. Only then will I connect back again and code. This "read ecu twice" process effectively doubles your chance of having a safe (non corrupted) back-up which can be used to restore if things go wrong. [Please note this only works for the iOS version of the app, at the time of writing the android app only stores one back-up. You can however manually rename the back-up and the app will then create another]. If you are very nervous there is nothing to stop you doing this even if you already have a back-up from previous successful coding. Each time the ecu is read it will create a back-up. I exit Bimmercode after the very first ecu read in case there is app instability, it removes the slight risk there is a wider app problem which could be carried into the second read. Never pick up Bimmercode for the first time, read an ecu and code. You will only have one "read/back-up" and if it is corrupted you could end up begging E-sys coders for help. Last edited by MJE60; 04-08-2019 at 10:39 AM.. Reason: Additional point - thanks jmciver |
03-02-2019, 07:00 PM | #428 |
Rep 25
Hey guys, I got iCarpro and bought the full version of bimmercode and I tried coding a couple of things including light indicator when locking and it didn't seem to work. also tried getting the speed display but all it did was remove my gas range and now theres nothing there. I tried restoring the code with the backup feature but literally nothing happened.HELP PLEASE
03-02-2019, 07:33 PM | #429 |
Rep 2,957
I just used it today for the first time. Took about 30-40 minutes and coded everything I needed to (except 3 to 5 blinks for turn signal).
03-02-2019, 10:17 PM | #430 | |
///M SubDriver
1836
Rep 2,783
Drives: 2017 M3, 2020 X7 40i
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
03-03-2019, 01:28 AM | #431 |
Rep 1,909
Didn't know that, I once was in the middle of coding when the message popped up "Idrive will shut down soon" I was absolutely helpless & bricked the car on a 10sec countdown, dash lit up like a xmas tree, lucky for me the backup file saved me & 5mins later all was well....underpants did need changing though
Happy Motoring
Evdok |
MJE60678.00 |
03-03-2019, 03:17 AM | #434 | |
Rep 910
So, your view on a wider debate, better to code with engine running or not? *, For general advice to newbie’s using Bimmercode I would say to make sure your battery has a good charge and plan your coding session so it is slick/quick as possible and code with engine off. However, there is no doubt, a voltage drop, during a coding session can cause significant errors! * - E-sys debate about not coding engine modules (FRM & CAS) with engine running , some are but some are not (F30 at least), nearly all either hook up power supply to battery or carry out general coding with engine running. BIMMERCODE official advice is code with engine off even though there is less access to critical areas (than E-sys) however you need a healthy battery for safe coding. If I am running behind (slow session, rare but happens), I will disconnect, start engine and then code ( Bimmercode) with engine running and have not had a problem. I have connected E-sys and am starting to explore it, due to VO coding, but get the sneaking impression it is more power hungry. Last edited by MJE60; 03-03-2019 at 03:23 AM.. |
03-03-2019, 07:50 AM | #435 | |
///M SubDriver
1836
Rep 2,783
The absolute best power source for any type of coding (or even engine ECU flashing for tuners like BootMod3, etc) is an automotive power supply unit (PSU). They provide steady, regulated current (up to 13 amps IIRC) for power hungry, full car programming sessions that can take several hours. These PSUs are typically reserved for dealers/indy shops because they are expensive and not readily available at the local auto parts store (although there are some DIYs out there to make them). I have never used a PSU before for any coding or engine ECU flashing, nor do I think I will have the need to. There are some that have DIY'ed a full car ECU programming session, just like the dealers do, and will only do that using a PSU. Next in line would be car battery chargers, which sometimes get confused as automotive PSUs. These can provide steady current up to ~5-6 amps or so. However, these are just designed to charge a battery, either not installed in a car or installed in a car with the car off. The current requirement of the car with the ignition on is greater than what a battery charger can provide. So the net effect will be that your battery will still drain if the ignition is on, it will just drain slower since the charger is providing some power. I have used these before as a precaution, but I don't always us them based on how long I will be coding. Last would be using your car battery, which is what I use almost all of the time. Having a fully charged and healthy battery for any coding session, no matter how short, is a definite must. My F80 M3 has one of those gold plated (i.e. very $$) Lithium Iron Phosphate (LiFePo) batteries which is by far the most "stout" car battery I have ever used. I recently did a 50 min coding session (re-coding my car after a dealer visit that updated the software in my car and wiped out my coding) and the battery didn't flinch when I started the engine afterwards. Of course, it took me a while, with shorter coding sessions and other electrical work on my car, before I built up the confidence to do that. I would not attempt that long of a coding session with a regular AGM battery though, at least not without a battery charger connected. FDL coding using E-Sys is not more power hungry than Bimmercode/iCarly. Both require the ignition to be on when reading/writing to a module so the power drain is the same. The WiFi/Bluetooth adapter used by Bimmercode may technically draw some extra power compared to an Enet cable plugged into your laptop for E-Sys, but I would speculate that the power draw is negligible.
MJE60678.00 |
03-03-2019, 08:04 AM | #436 |
///M SubDriver
1836
Rep 2,783
One other nugget specifically for iPhone users that also use CarPlay....
In iDrive disconnect your phone from CarPlay. I have found that if I connect my phone to the Wifi adapter for coding, the car will sometimes re-connect to CarPlay, thus dropping the wifi connection to the wifi adapter for coding. There are a couple of ways you can do this. One is reconnecting your phone to your car the normal Bluetooth way, or you can just delete your phone from the car entirely. I usually just reconnect my phone to the car using standard Bluetooth. Once you disconnect you phone from CarPlay, go into your WiFi settings and either turn off "auto join" for the CarPlay WiFi network or tap "forget this network". Doing this will ensure your iPhone does not try to reconnect to CarPlay, even if you disconnected your phone from CarPlay in iDrive.
MJE60678.00 |
03-17-2019, 11:10 AM | #437 | |
Rep 1
KOMBI - 3007 - DIM_NACHT_EIN - VALUE (WERTE)=FF (dafault is 32 in HEX) You will also have SATNAV constantly in daytime color scheme. |
03-21-2019, 12:21 PM | #438 |
Rep 308
The only good thing abt Carly is the ability for adaptation/reset like the transmission. This would be helpful after doing a t-case or trans fluid change. Even the ability to do a TBA on the phone vice in the car method.
2017 F31 328d xDrive
M Sport M Performance |
03-22-2019, 11:17 AM | #439 |
Combined Applications Group
1059
Rep 680
Quick question.
I want to use bimmercode androit plus thor wifi adapter to enable ASD (M3/4 sound) on my 2018 340xi. I have HK SOund system and the ASD module in the trunk near the amp. My car did not come with MPSSK I find the car sounds like a vacuum cleaner right now and not liking it much, Is it doable?
03-24-2019, 03:04 AM | #440 |
Rep 222
My only issue with using Bimmercode has been that the Bluetooth dongle and Android phone has timed-out on a couple of occasions and I have had to do a restore. No clue why this is happening as the seatbelt is clipped in.
2010 E90 M3
2013 F31 328i Touring M Performance |
