07-07-2017, 11:05 AM | #1 |
Rep 77
Battery replacement
Hey guys, dealership notified me that I need to replace my battery and they quoted me at $489 (not sure if that includes taxes) any how I've been searching for other people to have done their own replacement but can't find much on it I have a 2013 328i sedan.... was wondering if anyone here has gone with an aftermarket battery my local pep boys is selling Bosch batteries with the coding needed for it for $180 roughly... just wanted to see if anyone's experienced any issues that should make me go with the OEM.
07-07-2017, 12:00 PM | #3 |
Rep 1,503
After you swap your battery you need to have it coded. Before you buy the Bosch, ask your dealer how much they charge for coding to see if the coding charge kills the savings.
07-07-2017, 12:22 PM | #5 |
Rep 77
Well pep boys claim they can code it... I just have no idea if anyone has first hand experience with them and I agree $489 is wayyy too steep
07-07-2017, 12:36 PM | #6 |
Rep 5,990
There are you tube videos showing how to code for a new battery. Leave it to BMW to complicate things unnecessarily. It's to allow the charging system to account for battery age and condition/type that's set in the coding. BMW typically charges around $450 to install and code a battery. Sears and PEP Boys likely sells the gel type battery your car needs, not sure if they code it however. Costs around $180-200 for the battery.
07-07-2017, 12:38 PM | #7 |
Rep 558
About $350 for a new AGM battery. 140 bucks to code? You can code it yourself, or ask a member in this forum to do it for you. I'm not trusting the dudes at Pepboys to code. My experience was they couldn't even align an old Honda Accord steering properly, let alone code a modern BMW. Why not bring your car to a BMW specialty shop?
07-07-2017, 12:41 PM | #8 | |
Rep 5,990
07-07-2017, 12:41 PM | #9 |
Rep 1,503
As batteries age they require a higher current in order to charge. If you put in a new battery while the car thinks it's a 5 year old battery, the car's electronics will overcharge it and ultimately shorten the life.
Rhyzen7.50 |
07-07-2017, 12:41 PM | #10 | |
Rep 6,230
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
I'm not sure I buy Pep Boys claim that they can register it, but it is possible. I'd ask for a very clear explanation of what they mean and how they do it. My BMW independent mechanic registers my batteries, so there's no question it can be done by someone other than the dealership. The time charge to register a battery should be about 1/2 an hour.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
07-07-2017, 12:42 PM | #11 | |
Rep 5,990
tturedraider4967.00 kern4174446.50 |
07-07-2017, 12:46 PM | #12 |
Rep 1,571
I got mine at Batteries Plus and had a BMW Indy shop "register" (code) it for $25. The purpose for the registration (as far as I understand) is to tell the car's electronic monitoring system, which manages/monitors to the battery's usage against the different electrical systems the car has and their draw. If the car doesn't know it has a new battery and its specs, it will think it has original battery with its reduced capacity (wear and tear). There are folks who do not register their batteries with no apparent issue, at least, in the near term, but the car's system may eventually tell them they need to replace the battery before necessary because the car thinks its the original/older battery.
Hope those more knowledgeable will add their thoughts and experiences. And the Dealer charges for the battery and registration is most definitely a rip-off. |
07-07-2017, 12:50 PM | #13 | |
Rep 1,503
Although the batteries don't seem to last any longer than batteries in cars from a decade ago, it's very possible that they would die even sooner without all the smart charging hijinks. There is a reason BMW switched to AGM batteries after all. I'm also a little skeptical of the whole battery registration thing, but it's certainly a fact that my F30 is way more demanding on the battery than my 2002 E46 330i ever was. |
Rhyzen7.50 |
07-07-2017, 12:57 PM | #14 | |
Rep 5,990
07-07-2017, 03:00 PM | #15 | |
Rep 394
The AGM battery in UK will setup back about £250- £300 plus coding at dealer. I personally would not trust a local pep boys word on registering the battery. Cary app can do it but the adapter and full app will set you back over $100. Its better to find a forum member nearby with Carly app and buy them few drinks to code it. But whats worry is how did you kill the battery so soon. These AGM battery survive very long time. Mine is original from Dec 2011 and UK winter really goes hard on the battery. BTW my stock battery is Varta with a BMW logo. |
07-07-2017, 04:36 PM | #16 | ||
Rep 77
It's 165 after a 25% off coupon |
07-07-2017, 06:55 PM | #17 | ||
Rep 16,063
07-07-2017, 08:02 PM | #18 |
Rep 5,990
It looks like it has a 4 year warranty, free replacement. Not sure if there's a pro-rated period after that where you get a discount on a replacement battery. Warranty assuming normal conditions where the battery is being charged regularly, so either trickle charging or driving the car. If Bosch is the OEM supplier it should be fine. Looks within spec, make sure you code new AGM battery when installing. Make sure to keep your receipt in the glove box for warranty claims.
07-08-2017, 02:19 AM | #19 | |
Rep 125
Went to BMW dealer to get it installed, they didn't blink an eye. Said the installation will be a bit under 100€ which is still robbery but, as others said, I'd rather have them code the car and enter it into service history. |
07-08-2017, 04:34 AM | #20 |
Rep 3,946
It's unlikely the dealership would mess up because it's not even "coding". It's using ISTAD and registering the battery.
07-08-2017, 04:44 AM | #21 | |
Rep 3,946
Exide is the OE battery on my car. The Exide part number is FP-AGML5/49. The 94R group size appears to work as well but doesn't have as high of a cold cranking amps or reserve capacity as the 49 group size. |
