BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 Wastegate rattle :(
      02-19-2019, 12:05 PM   #1
mallorca328
Spain
47
Drives: F30 328i
2012 F30 328i  [0.00]
Is there actually any way to fix it?
      02-19-2019, 12:10 PM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Post of video/sound clip of what you are referring to, please.
      02-19-2019, 01:41 PM   #3
Aldor27
Drives: 2016 EB 340i
2016 BMW 340i  [0.00]
pretty sure Ive heard something like wastegate rattle on my n26 228i.
      02-19-2019, 02:50 PM   #4
Big.Al
Instagram @F82_Al
Big.Al's Avatar
33
Drives: 2017 F82 M4
Same I got waste gate rattle especially when shutting off the car sounds like a fart can
Insta @f82_al
      02-19-2019, 03:02 PM   #5
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
According to BMW they build the turbos to have some wastegate play as soon as engine is off or just turning on (cold). Lot's of owners complained about it and even with a turbo swap, it was good for less than 1K and rattle returned. Now, if you have wastegate play and rattle when you rev the engine after it is fully warmed up than that is an issue. You can always manually adjust the arm a full turn or half a turn in to take the slack out and make the turbo last longer if tight on cash. But you will need a new turbo sooner than later.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
      02-19-2019, 03:20 PM   #6
sspade
sspade's Avatar
Drives: F30
Why would he need a new turbo and not just a new wastegate assembly.
Please explain.
      02-20-2019, 02:56 AM   #7
mallorca328
Spain
47
Drives: F30 328i
This turbo isnt even one year old.
      02-20-2019, 07:13 AM   #8
sspade
sspade's Avatar
Drives: F30
There is no reason to swap entire Turbo assembly for a waste-gate rattle. You would swap the waste gate first.
Don't believe me everything you read on the internet!
      02-26-2019, 02:26 PM   #9
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
Pretty sure over-tightening the actuator arm will also call up an engine light from what the dealer told me.
(In my case) the dealer said actuator couldn't be replaced without the entire turbo so they replaced my turbo on warranty.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      03-04-2019, 02:44 PM   #10
D041987
D041987's Avatar
Please explain.
The wastegate is not actually rattling it is the flapper that is on the inside of the turbo hot (Downpipe) side that is flapping around. This is due to the machined bushing that the arm sits on and moves back and forth. You are required to press fit that bushing/sleeve out if you want to remove or replace the entire flapper arm which requires a turbo removal! Now you can probably have the turbo refreshed and rebuilt by the shop for around $300-400. But since you already have it all off, might as well upgrade to the MHI or Another turbo.... But your call. Personally I would not go with a OEM replacement. I would get it rebuilt, as the shop will put a bushing and arm that is made of better quality and will probably not rattle like the OEM ones do in a few K. BUT OP is under warranty. Go complain to dealership and get BMWNA involved and have them send their tech down to the dealership and do not pick your car up till your turbo is replaced!
This video explains it better: https://www.bing.com/videos/search?q...0&&FORM=VRDGAR
      03-16-2019, 06:43 AM   #11
mallorca328
Spain
47
Drives: F30 328i
Mine is the electronic, not pneumatic
      03-21-2019, 06:05 AM   #12
kobluna
Drives: 320i
Should not matter though. It still got actuator arm and valve itself. I too have electric actuator and got some rattling. But when I try to move the valve axle by hand I feel only very little play in it. So I'm not sure if it's this problem. I would say it's fine and something else is rattling. Do you feel any play on your wastegate axle if trying to move it by hand? Only try with cold engine of course.
      08-14-2020, 05:23 PM   #13
RMachuca3d
RMachuca3d's Avatar
724
Drives: F30 328i Msport
Would this be considered excessive play?
      08-16-2020, 12:56 AM   #14
sqwinny
Drives: 2013 6MT 328i M Sport
Seems standard to me. Same on my ewg n20. No issues
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
      01-02-2023, 08:24 PM   #15
Skarniqo
Skarniqo's Avatar
Drives: BMW 328i
have you done this yourself, i want to tighten it but not sure if itll mess it up
2016 BMW F30 328i | BMS Oil Catch Can |
