03-10-2019, 08:32 PM | #1 |
Rep 73
Whining noise at higher rpm
Hi, I know this is a topic that is discussed often, but there is a high pitched whine in my 2013 328i xdrive at higher rpm around 5k in like 2nd and 3rd year. The car also has a bm3 stage 1 tune and an injen intake if that makes a difference. Does anyone have any idea what it might be?
[IMG][/IMG] |
03-11-2019, 09:17 AM | #2 |
Rep 2,665
I'd switch back to stock intake - purely based on all the threads I've read of members with BM3 switching back to stock intake.
Is an upgraded intake a supporting mod on any of the BM3 maps? |
03-11-2019, 03:40 PM | #3 | |
Rep 73
03-12-2019, 09:19 AM | #4 |
Rep 3,679
Its not, and I second that suggestion. Once you start doing actual tuning beyond boost controllers or simple piggybacks, aftermarket intakes can start messing things up. Not sure why, but it's a pretty popular trend. I'd imagine that it's because a good bit of tuning is based off the MAF readings, and if the MAF's location is different along the intake tract than it is stock, I could see that being an issue. Not sure that it's the cause of this particular problem, but it's a good suggestion nonetheless...
03-13-2019, 01:43 PM | #5 | |
Rep 73
I put back the stock air box, and it you could still hear the sound a little but not as loud and whiny. Maybe it's just the turbo spooling more due to the higher peak boost it reaches at wot (at the higher rpm range) ? Could it possibly be a boost leak at the charge pipe/intercooler connection. Also I checked out the turbo while the intake was off, and everything seems to be fine, no shaft play and the blades look fine. It's driving me crazy, I know there is some little thing that changed |
03-13-2019, 02:11 PM | #6 |
Rep 184
Drives: F30 N26
You know what it probably is... your Turbo Inlet Pipe... ( the pipe that connects from the intake, to the turbo... just trying to be as specific as possible ) It might have cracked. Mine broke at the tightening nut and I vaguely remember hearing this before I swapped over to the MST TIP.
-2013 F30 328i xDrive Melbourne Red- Injen CAI | GFB DV+ | FTP CP & TP | CW DP | G-Plus Oil Cooler | Mishimoto CC | VSRF FMIC | BM3 Stg 2| H&R Rear Sway Bar | H&R SS & Bilstein B8 | Carbon Fiber Dealibobs | 525 LPFP | Soon to come upgraded HPFP (B58TU) and Navardi Tune |
03-13-2019, 02:21 PM | #7 | |
Rep 73
I've had an issue with it popping out before and I'm able to just pull it out of the turbo...does that mean it's broken? |
03-13-2019, 02:28 PM | #8 | |
Rep 184
Drives: F30 N26
03-13-2019, 02:39 PM | #9 | ||
Rep 73
I probably will have to. Is having a broken inlet damaging to the turbo? As long as it stays in and it's not driven hard right? |
03-14-2019, 01:28 AM | #10 |
Rep 184
Drives: F30 N26
[QUOTE=cedaj;24511644][QUOTE=LordRuxpin;24511597]I cant say for sure, I would assume in some capacity yes, because large particles can find it's way into the turbo, thus your engine.... So, yea.. no bueno.
