05-04-2013, 07:02 PM | #3499 |
Rep 144
Those who coded to have your windows roll up/down with the key fob and with the engine off, does your window Lock still work ? I noticed today that my window lock doesn't work, when I locked it, my passengers were able to roll the window up and down. I'm not sure if it has anything to do with coding
05-04-2013, 07:14 PM | #3500 | |
Rep 144
05-04-2013, 07:20 PM | #3501 | |
Rep 1,130
Drives: '16 340i AW MSport
I used some large head pliers to rip it out with lots of force, it's like wtf??? |
05-04-2013, 07:28 PM | #3502 |
Rep 169
Code:
MAPPING_TAGFAHRL_H_L_OUTPUT off sl_l MAPPING_TAGFAHRL_H_R_OUTPUT off ls_r MAPPING_UNIVERSAL_6_OUTPUT off sl_2_l MAPPING_UNIVERSAL_7_OUTPUT off sl_2_r I tried changing these values. As noted in the Google spreadsheet, the inner (MAPPING_UNIVERSAL_X_OUTPUT) parameters don't work after 48.2. I just verified this. Yes, DRL only works with outer tail lights. Any idea how to enable inner lights? May be a different parameter? Also, are the tail light PWM levels adjustable? The tail lights kind of suck...can't see them properly during the day. They fade in comparison with Audi LEDs. |
05-04-2013, 11:11 PM | #3503 | |
Rep 1,892
Are you saying that the lock no longer works for the rear door windows? I don't have that coded on my car, but if you can confirm that the switch no longer locks out the rears, I'll code it on my car and see if I get the same behavior. |
05-04-2013, 11:16 PM | #3504 | |
Rep 1,892
I can attest to 10nelyboi's being almost impossible to remove. The OBD-II part of his cable is pretty small and we tried for about 10 minutes to get it out with no success. My cable (open ended bought from amazon) has an OBI-II plug that is pretty big and with a good grip. It comes out with only a bit of a tug. I've seen other posts where people reported the same difficulty removing the plug. |
05-04-2013, 11:31 PM | #3505 | |
Rep 1,892
Did you see the 2 lines below the ones you mentioned in the spreadsheet? REM / 3063 / MAPPING_UNIVERSAL_6_PWM_LEVEL_1 REM / 3063 / MAPPING_UNIVERSAL_7_PWM_LEVEL_1 It says to change the werte values from 00 to 64 (100). I have not tried that yet, so I don't know if it works or not. It's not clear if the MAPPING_UNIVERSAL_6_OUTPUT and MAPPING_UNIVERSAL_7_OUTPUT also need to be coded or not. If you do go and experiment, please let us know if it works or not! I'd assume that the power level for the tail lights is already at 100% (64x), but it's hard to tell as there are so many light settings in REM. |
05-05-2013, 12:27 AM | #3506 |
Rep 1,130
I want to disable the fogs turning on for both turning and reverse, basically I don't want the fogs to illuminate ever.
is this the way to do it? All 6 of these options? it seems like this is just for turning, is there a seperate option for reverse? Code:
Fogs on while turning p1 Yes Fembody 3073 C_CLC_ENA F30disable F30enable Fogs when turning Fogs on while turning p2 Yes Fembody 3073 C_BLC_ENA F30disable F30enable continued Fogs on while turning p3 Yes Fembody 3066 KL_ENABLE_LI KL_Aus KL_Ein continued Fogs on while turning p4 Yes Fembody 3073 KL_ENABLE_RE KL_Aus KL_Ein continued Fogs on while turning p5 Yes Fembody 3062 MAPPING_abbiegel_L_output Off nsw_l continued Fogs on while turning p6 Yes Fembody 3062 MAPPING_abbiegel_R_output Off nsw_r continued |
05-05-2013, 12:36 AM | #3507 | |
Rep 169
05-05-2013, 02:43 AM | #3508 | ||
Rep 144
I was able to roll the rear windows up/down using the master switches at the driver side after locking it. I'm not sure if the rear passengers are able to roll it up/down or not. I will have to try it and let you know. I just had my windows tinted so I don't want to mess with it too much. |
05-05-2013, 03:10 AM | #3509 | |
Rep 169
Code:
REM > 3062 > MAPPING_TAGAHRL_H_L_OUTPUT = sl_l REM > 3062 > MAPPING_TAGAHRL_H_R_OUTPUT = sl_r REM > 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l REM > 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r REM > 3063 > MAPPING_UNIVERSAL_6_PWM_LEVEL_1 = werte=64 REM > 3063 > MAPPING_UNIVERSAL_7_PWM_LEVEL_1 = werte=64 Thanks Frogman for the suggestion |
05-05-2013, 04:14 AM | #3510 | |
Rep 169
05-05-2013, 07:11 AM | #3511 |
Rep 30
Hi Shawn,
Sorry will have to ask for a favour from you again - one of my friends is having a Chinese F10, built in 2013 and is having some small issues with the memory of aircon. He said that the settings of his aircon won't be saved after power off and restart the car. He did some coding by changing the FDL settings under IHKA, item OFF_MEMORY to aktiv, which, supposingly should solve the problem but apparently no, at least not for the F10 built in 2013. As I understand you are a F10 owner, do you by any chance have any suggestion on this? Many thanks in advanced, much appreciated. |
05-05-2013, 08:11 AM | #3512 | |
Rep 40,765
I think he should try coding MEMORY_UMLUFT=aktiv, which is "Always Remember Air Recirculating", and see if that works.
05-05-2013, 08:17 AM | #3513 | |
Rep 30
It is nice to have you around here |
05-05-2013, 08:27 AM | #3514 |
Rep 383
Shawn- my F30 build date is Dec 2011 (MY2012). I started coding this past October and have been using the software versions from October. Any reason I would need the newer versions (only if dealer upgrades me, etc.)? Can you pm me a link? Thanks.
05-05-2013, 08:39 AM | #3515 | |
Rep 40,765
If you want the latest, which requires E-Sys 3.22.5, and you currently have E-Sys 3.18.4, then you are going to have to also buy a new patch / token for E-Sys 3.22.5, which you may not want to do if you do not have to. If you do though, send me a PM, and I will point you in the right direction.
05-05-2013, 08:55 AM | #3516 |
Rep 1,130
So anyone know how to disable fog lights completely? from illuminating when reversing and turning?
05-05-2013, 09:13 AM | #3517 | |
Rep 69
Taking into account that I don't need the cable to stay permanently on, I trimmed my cable that the "T" shape is no more stopped on exit (removing the plastic bond between that area and the rest of the connector did the job). It makes the connection less strong, but I never had any issue to remove my cables while it is enough for proper coding. |
05-05-2013, 09:46 AM | #3518 | |
Rep 1,892
05-05-2013, 10:12 AM | #3519 |
Rep 1,130
05-05-2013, 12:16 PM | #3520 | |
Rep 169
I also tried reverting these settings back to default values. No DRL tail lights. Then I enabled again to confirm. These definitely are the settings for my f30. |
