04-10-2019, 03:12 AM | #1 |
N55 435I
Rep 27
Front Plate Mount
Need to mount my front plate on my M-Sport 435i
I want to do it without drilling holes. I ordered a tow hook mounted plate holder, but it covered my PDC. Are there any tow hook mounts that dont cover the PDC? And are there any other ways to mount the front plate without drilling? Thanks. |
04-10-2019, 04:59 AM | #2 |
Rep 303
I used the Skene mount on my 2016 435i M Sport. You do have to drill two small holes, but it’s really just self tapping screws on the underside of the bumper so they don’t show. It’s a really good design in my opinion.
https://skenebrackets.com/ |
04-10-2019, 06:12 AM | #3 | |
Rep 799
This is what use and it works great. Never really liked the look of the tow hook plate.
04-10-2019, 06:33 AM | #4 |
Rep 554
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
04-10-2019, 08:42 AM | #5 |
Rep 227
Drives: 2000 BMW E39 M5
US Mill Works
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
04-10-2019, 09:16 AM | #6 |
Rep 10,256
04-10-2019, 09:19 AM | #7 |
Rep 14,115
Drives: G82 M4C X-Drive
Pedalhaus quick release is the beat solution I've found. The mounting location is flexible and movable. Us Millworks requires disassembly to reposition. Pedalhaus only requires loosening of the adjustment screw. Plus it's very easy to install. When you are done with your inspection, just take it off!
http://www.pedalhaus.com/quickrelease.html One more thing I like about pedalhaus is that it has a curved back which means it creates separation between the plate and the car. US Millworks is flat. You won't be restricted by your bumper contours with the pedalhaus.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
04-10-2019, 11:00 AM | #8 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
US Mill Works! Best quality out there. I've had this for 3 years and no issues.
You can see the gap between the front bumper and tow plate mount. |
04-10-2019, 11:02 AM | #9 |
Rep 5,457
Drives: F30
No you dont. Go without.
Invest in the tow mount and use it only when you have to (ie to get a fix it ticket reversed). Then remove plate again. Ive lived in New York, Virginia and California and never wear a plate. Ive also never gotten a plate ticket. Even when getting a speeding ticket. |
04-10-2019, 11:25 AM | #10 | |
dad bod
387
Rep 382
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
04-10-2019, 11:31 AM | #11 | |
Rep 2,432
Drives: 2021 M2C
04-10-2019, 12:11 PM | #12 |
Rep 2,499
You're fine in suburban areas but enforcement can be brutal in the city or especially near LAX. You usually won't get pulled over for it. CHP usually won't even ticket you if they pull you over for something else. Meter maids will screw you though.
04-10-2019, 02:27 PM | #13 |
Rep 2,432
Drives: 2021 M2C
Well that sucks.
04-11-2019, 02:38 AM | #14 |
N55 435I
Rep 27
I park in a school and the school officer comes to check my car everyday to make sure I have the front plate He already gave me 2 tickets. Otherwise i would just leave it off, before this cop harassed me ive never had a problem.
04-11-2019, 03:29 AM | #15 | |
Rep 14,115
mlev370.00 |
04-11-2019, 09:59 AM | #16 | |
Rep 552
Sounds like you just need something you can throw on when you park, and pull off easily after (aka quick release). I would go with Pedalhaus as jmg said, or the STO N SHO is great which I actually purchased and never installed/needed in LA. |
plate frame, plate holder, plate mount, tow hook license plate holder |
