01-05-2014, 03:20 PM | #1145 |
Rep 918
01-05-2014, 05:07 PM | #1146 |
2006 TIME Person Of The Year
9720
Rep 6,445
I don't think I have used a car in the past 15 years that didn't incorporate some method of managing the gas cap.
01-07-2014, 07:03 AM | #1148 |
Rep 12
Apple audio files
I just realized that if you put Apple audio files m4a/m4b ( I am a great audiobook fan ) it works with the sound perfectly and I was surprised to see that on the audiobooks it keeps the point where you last stopped even if remove the USB stick as it is on Apple devices.
01-07-2014, 07:55 AM | #1149 |
Rep 1,153
Works every time but I have size 14 shoes . Actually it failed once...then I realized the key wasn't in my pocket. I use this feature all the time.
2020 M2C 24.04.2020 delivery - Sold 24.08.22
01-08-2014, 04:43 PM | #1150 | |
Rep 884
The ambient light sensor for the headlights and the instrument cluster are different. As you've stated, there are situations where the ambient light conditions cause your headlamps to turn on, but, the instrument cluster remains white. My comment was to illustrate a scenario where the headlight ambient sensor detects insufficient natural light (at night) and turns the headlights on, while the instrument cluster would detect sufficient ambient light (by virtue of shining a flashlight directly at it) and thereby cause the TFT display part of the instrument cluster to remain white. Clear as mud? |
01-08-2014, 04:57 PM | #1151 | |
Law Enforcer
25114
Rep 22,288
Drives: '22 Chalk Gray Porsche C2S
01-08-2014, 05:07 PM | #1152 |
Rep 884
Yep, we're saying the same thing. I was simply stating that a flashlight can be used to manually trigger the IC sensor independent of the headlight sensor, to toggle between Red and White on the TFT display and the HUD display
01-08-2014, 05:10 PM | #1153 |
Rep 884
The cool takeaway is the little things that BMW does to go the extra mile, like the cluster light sensor being independent of the headlight sensor.
01-09-2014, 03:48 PM | #1155 |
Rep 251
Drives: F30 - E92, E90, E46 (Retired)
01-09-2014, 05:38 PM | #1156 |
Rep 918
Not a performance item but pretty cool nonetheless. I finally got around to snooping under the hood and noted the radiator is a "ozone reduction" type of unit. I'm sure somebody will want to change their radiator because of that feature but for me, I think it's a great idea.
01-09-2014, 05:44 PM | #1157 |
Rep 633
That DNA is there for the overhead virtual camera view at night ...
01-14-2014, 08:51 AM | #1158 |
Rep 884
Found another small neat feature. Applies to MY14 vehicles only with NBT and Idrive touch:
The top surface of the I-Drive touchpad can be used to increase or decrease any "bar" level. For eg. when you select the audio tone controls and select "Treble", you can increase or decrease the treble level by simply sliding your finger left or right on the touchpad to increase or decrease the level....you dont have to turn the i-drive knob itself. |
01-14-2014, 09:55 AM | #1159 |
2024 M440i GC (G26)
278
Rep 511
A small item but greatly appreciated. The black mask around the rear view mirror is applied internal to the windshield. This leaves the inner surface smooth so you can attach suction cups for a radar detector or dashcam. This is the first car I've had that has this feature, and it gives me better options for the Valentine 1 mount. Dashcam install is pending in this area as well.
01-14-2014, 10:14 AM | #1160 | |
Excited F34 owner
Rep 148
1) in the middle of the rear 2) doing a straight in-out motion and not a left-right sweeping motion I have sub-standard size-10 shoes and works every time. Love this feature. |
01-15-2014, 10:05 PM | #1162 | |
Rep 371
2014 335i M Sport - Mineral Grey/Coral Red, Nav., Premium, HK, MPE, 8AT. Mods: Macht Schnell Spacers (12mm-front, 15mm-rear) with 403M's, Bilstein B8 Struts/H&R Sport Spring combo, M-Performance black kidney grilles, IND Distribution color-matched reflector inserts and key hole cover.
01-29-2014, 11:51 AM | #1164 |
Rep 3
01-29-2014, 02:44 PM | #1166 | |
Rep 32
