BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Hood sunken in
      10-19-2019, 09:48 AM   #1
vinzcast21
vinzcast21's Avatar
135
Drives: F30 340i MY2017
Hello guys, I just realized my hood sunk in and it sits just couple mm below the front bumper, making it not flush. the front bumper hadnot been replaced, might be taken on and off but surely its OEM. I attched the pic below from google for reference
is there a way to fix this?
thank you
Mod bug will bite you if you buy a BMW
      10-19-2019, 09:56 AM   #2
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i
2018 GMC Acadia  [0.00]
2014 BMW 428i  [5.00]
You can adjust the hood.
See this thread
https://f30.bimmerpost.com/forums/sh....php?t=1263218
___________________
2014 F32 428i 8AT M-Sport
      10-19-2019, 10:23 PM   #3
OC_F32
OC_F32's Avatar
109
Drives: 2015 428i
Couple of mm would be enough to bug me too, man. Adjusting the hood stops is somewhat quick and simple. But before you go there, I'd check to see how the fenders align with the sides of the hood. If they are plum/even your focus should probably be on the front clip. If the fenders are higher toward the bumper, those stops are likely the fix.
      10-19-2019, 10:24 PM   #4
vinzcast21
vinzcast21's Avatar
135
sides are good and even (checked with ruler). which one is front clip?
      10-19-2019, 10:35 PM   #5
OC_F32
OC_F32's Avatar
109
Drives: 2015 428i
Front clip = your bumper.
Have you inspected the all of the fasteners? Pay special attention to the ones under where the top of the hood connects to the car. On my F32 there's a series of bolts (4-6) that hold the top of the front clip in. I can't remember if there's a weather stripping covering them or not. Anyway, they should have little rubber spacers/grommets attached. Make sure they're all in. Missing ones would drop it a mm or two I'd guess. I can take a pic of mine tomorrow if you need a visual.
      10-20-2019, 08:16 AM   #6
CrumbyButter
CrumbyButter's Avatar
18
Drives: BMW 320i xDrive
This
Try adjusting the bumper cover first.
Also, FYI, I got into a fender bender and bumper cover plus one of my headlights was replaced. That resulted in one side of the cover being slightly lower, which drove me nuts. Fixed by adjusting the headlight to sit higher.
      10-20-2019, 02:29 PM   #7
vinzcast21
vinzcast21's Avatar
135
This
yeah the hood sits lower than bumper as you can see. the bumper cover sits fine and i tried adjusting the middle rubber thing and latches.. I'll just go to dealer and get them fix it I guess
      10-20-2019, 04:03 PM   #8
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Actually I notice this on my F36 too. You have to really be very close to see the difference on mine. But I think this serve a purpose, to defect air or the airflow between the bumper and the hood... just my guess... I'm not an expert on aerodynamics.
Fyi... my F36 never been on an accident.
