BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Engine: please post your experience, including problems / resolutions
      05-23-2019, 10:24 PM   #419
Araemo
Drives: 2017 340iX 6MT
Originally Posted by B58 View Post
B58 vanos and timing is much more advanced then the previous bmw models. I wouldn't worry too much about it and lose sleep over your engine having to come out in the future lol. There are N54's with 150,000 miles that never suffered such an issue with vanos and timing chains. I'm not sure what there is to service a timing chain? I don't recall a chain stretching or snapping like timing belts and I'm sure the chain tensioners are very modern and much more advanced.
Timing chains 'are lifetime parts' that stretch and need replaced eventually, in general. Then again, there's a LONG history of timing chain tensioner problems with all sorts of cars.. where the tensioner is what breaks rather than the chain, and when you're that deep, the extra $$$ of parts to replace the chain is just being smart, since it's a small fraction of the total cost of the job.
Originally Posted by G.Newt View Post
Yup.
That's just the vanos bits, not the whole timing chain. I don't think it'd be possible to do the timing chain without removing either the engine or transmission, since it's on that side of the engine.
      05-26-2019, 07:01 AM   #420
fun240i
Drives: BMW 2017 M240i
Originally Posted by fun240i View Post
'17 240 17k miles....this may be a dealer issue....but noticed for first time coolant a bit low a month after a 5k 12 month service...low coolant warning...checked large reservoir stone cold engine...below min mark but coolant visible.....overflow tank correct level....taking back to dealer for a check.
this minor blip aside.....bmw got this motor exactly right....smooth as silk.
Dealer replaced driver side radiator that had pinhole that could have been caused by excessive road debris left behind in construction zone by FDOT several months prior
      05-29-2019, 05:04 PM   #421
BuffaloSoldierH
Drives: 2016 340i 6MT
iDrive constantly restarting/freezing
Some times I start the car and the screen is black unless I hold the power button to reset it. Recently it started just now having volume as if it were frozen then it resets itself. Not sure what the hell is going on
      05-30-2019, 08:33 AM   #422
PKthePM
Australia
45
Drives: BMW 440i F32
Squeaky door on my F32 440i and fortunately nothing else.
Edit: And squeaky sidemirrors when they roll in.
On a side note, was looking at some coding apps on Play Store, specifically Bimmercode and Carly.
They have some cool features but reaching out to get some help on this as I don't wanna mess anything up.
Are these apps trustworthy?
Do these void the warranty?
Any personal experience, tips and guidance would be much appreciated.
I couldn't find another thread on this topic so posting a new one.
cheers.
      05-30-2019, 11:04 AM   #423
sewhelan9
sewhelan9's Avatar
Drives: 2018 440i Gran Coupe
cheers.
I have used Bimmercode and been very happy with it. Easy and straightforward to use. There is a separate forum dedicated to coding and lots of info here: https://f30.bimmerpost.com/forums/fo...play.php?f=429
2018 440i Gran Coupe (F36), Glacier Silver/Black Dakota, M Performance and Track Handling Package, MHD Stage 2 and xHP Stage 3 flash tunes, Dinan Shockware and mid-pipe, HJS high-flow cat, AP Intake, RW Carbon duck bill spoiler and rear diffuser
PKthePM45.00
      05-30-2019, 12:02 PM   #424
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Originally Posted by Musashi View Post
It is being rolled out quietly, as we speak, in select 2020 models. Googling B58TU1 will reveal some sources, though not the German ones. It is indeed a corrected block design for the 380+Hp, including resolving stupid things like chain and belt unreliability (a previous 300$ job now involving full engine removal).
https://www.autoevolution.com/news/b...ps-129912.html
https://www.bmwblog.com/2018/10/31/b...88-horsepower/
these changes tell me that, considering the lengthy recall lists (just 100 recalls = millions $) BMW engineers in Munich scrambled realizing that the common sense worse scenario issues turned out the norm. Shredded turbos, fail chain, fail piston, fail bearings, fail cylinder all = full engine replacement. Each time BMW lovers floored it, they proved the cautionary folks right, and engineers wrong. They got power right, but not life cycle management (hey even Ferrari missed that this year in F1). The idea of reversing the chain and belt location to bring vibration to center of car mass, as well as - stupidly- keep it cleaner, turned out hubris as any troubleshooting now involved hoisting the engine. Solution? redesign that with 30 less moving parts in TU1.
as if not enough, thermal issues plagued the engine deck, and even the less powerful N55 got hot enough to warm up overnight my garage at 0 Celsius. Solution? redesign the deck, crankshaft bearings AND pistons and cylinders, metallurgically better alloys, thicker walls in critical punch hole location (is it Honda in F1?) and thermal improvements with smarter cooling per stroke. suddenly, the engine can handle 350 bar...
when did they actually do that for the N54 and N55? it has not happened actually. The B58 release coincided with MB swooping by BMW, Audi as well surpassing it in sales, etc. Cause and effect.
either case , those that tuned up the B58 rapidly discovered issues that were almost unheard off on the prev gens. Smooth as butter, fast, but piss poor reliable.
Hopefully BMW extends warranty to ALL B58 owners, not the least due to stringent EU and German consumer protection laws. But i have a feeling that they will do swaps quietly and they are trying to release the TU1 quietly as to not reveal the original B58 as a 2 year wonder...
where on earth did you get all those assumptions? where are all of the failures you're talking about? BMW wanted to make more power and reduce emissions, so they made design changes that increased fueling and engine efficiency. none of what's in the articles indicates that there's a reliability issue. it actually mirrors what most automakers are moving towards with turbo manifolds integrated into the head, more radiators, and higher flowing hpfps.
Instagram @kern417
VVlasy32.00
B58295.50
BMWILUVU222.00
B58togo501.00
Swappy156.50
      05-30-2019, 05:48 PM   #425
PKthePM
Australia
45
cheers.
thanks mate.
440MIA15.00
      06-01-2019, 06:38 PM   #426
Jahjaman
Drives: M140i
Thought exactly the same thing.
B58295.50
kern4172027.50
BMWILUVU222.00
      06-03-2019, 11:15 AM   #427
NormanConquest
Drives: 340i
Tech believe was no a properly secure gas cap
Also a recall was performed
      06-03-2019, 11:24 AM   #428
BMWILUVU
Drives: 340ix
Me too.
      06-03-2019, 12:44 PM   #429
NormanConquest
Drives: 340i
Btw anyone know what the sib did? I can't find any info on it.
      06-03-2019, 12:50 PM   #430
440MIA
Drives: 2018 440i Grand Coupe LCI
Read Attached PDF
A Delivery Stop has been issued (effective May 16, 2019) on certain Model Year 2016-2020 BMW vehicles that have been produced between June 19, 2015 and April 17, 2019. A software error within the Digital Motor Electronics (DME) may cause a miscalculation of an onboard diagnostic (OBD) function.
This Delivery Stop includes approximately 88,224 vehicles produced from June 19th, 2015 to April 17th,2019.
PDF:
kern4172027.50
      06-03-2019, 01:03 PM   #431
NormanConquest
Drives: 340i
PDF:
So a software glitch
      06-03-2019, 01:17 PM   #432
440MIA
PDF:
Pretty much. Possible other tweaks as well...
      06-04-2019, 02:55 PM   #433
340idude
Drives: BMW 340i
Does anyone have any knowledge on CPO expiration on higher mile vehicles?
Vehicle has nearly 2 more years of factory warranty left but at 48k now and is a CPO (1yr/unlimited mileage). Does that mean the day I hit 50k my 1yr countdown starts or does that mean when I hit 50k, Im in CPO land (less coverage) but still get the remaining 2yrs of factory warranty and 1yr additional but in the form of CPO coverage/terms.
      06-04-2019, 04:51 PM   #434
bimmer456
Drives: 340i
I was told if you hit 50k before the warranty expires you are in CPO land with CPO coverage and 1 year countdown begins.
      06-14-2019, 08:23 PM   #435
B58
B58's Avatar
296
Drives: 2018 BMW 340i, 2011 BMW 335d
Has anyone had their valve cover replaced due to some internal crack causing smoke out the tail pipe? Apparently this is becoming common on the B58 and quite a few in the dealers are experiencing this issue with smoke out the tail pipe and catless guys will obviously see more smoke. It has something to due with the PCV built inside the valve cover.
| 2018 BMW 340i | M-Sport | Track Handling Package |
| 2011 BMW 335d |
      06-18-2019, 12:47 PM   #436
kern417
Cheapskate
That's somewhat common in general. PCVs are prone to fail. It would be nice if we could run a valve cover to a catch can or something instead of just replacing a component that'll fail again, especially with increased crankcase pressures from tunes and other mods. Just sucks that it's integrated into the valve cover.
Options like the BMS catch can are nice but still rely on the internal PCV to function properly.
Instagram @kern417
      06-19-2019, 12:03 AM   #437
G.Newt
Drives: 340i xDrive 6MT
Has anyone seen these 2 codes? Primarily the first one. The second code, Google says: Fuel tank ventilation system, 2nd inlet point: Malfunction
But really nothing on the first code.
EDIT: taking it into the dealer tomorrow (after flashing back to stock). I cleared the code last night before parking and sure enough, within 5 minutes of driving to work it came back on.
      07-31-2019, 09:36 AM   #438
saa2323
Drives: 2017 340i M Sport
2017 340i with 10K miles.
As for the engine, no issues as of yet.
I did receive a low coolant warning for the turbo radiator. The air temperature was extremely hot that week -- ~100F -- so the issue was attributed to the weather.
For the car:
- Speaky down seal issue which the dealer addressed per the service bulletin.
- The car did throw a back up / side camera warning when in shifting into reverse. The backup camera worked, however, the side cameras didn't. Dealer "reset" the camera system which corrected the issue.
      07-31-2019, 09:47 AM   #439
kern417
Cheapskate
For the car:
Hot weather won't cause a low coolant warning. Check both of your coolant tanks. Only one has a sensor so the other may be low too.
Instagram @kern417
      08-01-2019, 07:13 PM   #440
neonnblack
Drives: 335i 6MT/e46 330xi
44k and no issues especially with the motor.
Only issue i have is while accelerating, there is a tin can ticking type noise. At a stop it's gone, cruising with no real throttle input it's gonna. And it does NOT increase or decrease with rpm.
I'm having massive trouble finding out what it is.
b58
