BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Check this topic out you want/need BMW diagnostic/programming software!
      10-17-2016, 01:07 PM   #111
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
2004 BMW 120i  [0.00]
Thumbs up
Originally Posted by rghelase2001 View Post
Hi, I encounter issues in making ISTA-D 4.01.22 working (thanks again for the links)..
I receive the "Failed to start ISTA. Please make sure your ISTA configuration is valid. In doubt reset any non standard ISTA configuration and reinstall ISTA."
I receive this on XP 32bit and 7 32bit fresh install.
I followed the following steps:
-unpack the ISTA 4.01.22.7z and move the Rheingold folder in C:\
-installed Java
-installed BMW Standard Tools (for Adiabas).
-installed .Net Framework
-installed vcredist
-unpack the 7z files for EN and Other (all except DE and RU files), and copy them in the SQLiteDBs folder, in the Rheingold folder.
-installed vs90_piaredist
- run RCleaner V4.4, then reboot.
- run ISTA-D Reg Fix x86.reg
-run ISTAGUI.exe, and receive the error above.
The exact same procedure I run both on Windows XP 32bit and 7 32bit.
Please help
Did you installed all vcredist versions? 2005, 2008, 2010, 2012, 2013, 2015? for x86. Also both .net frameworks... and Ediabas?
Download C++ 2013 Distributable 32bit version via Microsoft website and also run ISTAGUI as Administrator.
There is a chance that something is missing from your system. That's why the error comes up. Maybe it will work by running as an admin.
rghelase2001 install C++ 2013 distrib 32 bit. It will work.
      10-17-2016, 01:44 PM   #112
rghelase2001
Romania
Drives: F11 520dA DU41299
Many thanks for the info.
I reinstalled everything all over again, including the C++ Redistribuitable 32bit pack from M$ site, and run ISTAGui as Admin, and it is working!!!
From the last pack you sent me, 4.0.22, I see there is ISTA-D and PszData.
Do I need everything else for coding (such as ISTA-P?)
I am asking since I see in the previous pack, 4.0.21, there is also a ISTA-P pack in it..
Please, can you please PM me with the E-SYS latest working version, for F10/F11? Many thanks.
      10-17-2016, 01:50 PM   #113
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
PM incoming.
No, you don't need to unpack the PSDZ archive unless you're planning to program via ISTA-D.
Make sure you have ENET cable for ESYS coding.
      10-17-2016, 09:04 PM   #114
afranke
Drives: 2013 ActiveHybrid 3
Heyo, can I get me a download link? Can this be installed on the same system as e-sys?
      10-18-2016, 01:45 AM   #115
montuno
Drives: 320D
Hello!
Can I get the link please?
Thanks in advance!
      10-18-2016, 04:35 AM   #116
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Yes and yes
Originally Posted by montuno View Post
Hello!
Thanks in advance!
Yes. Sent.
      10-18-2016, 11:27 AM   #117
S4NoMore
S4NoMore's Avatar
Drives: 11 335i 6MT, 91 318i, 15 X3d
2015 BMW X3  [0.00]
1991 BMW 318i  [4.33]
2011 BMW 335i  [0.00]
Is there an instruction overview for what to do after downloading everything? I'm not sure what the next step is.
Can anyone confirm whether it's possible to run something like this using Wine with the latest Ubuntu operating system?
      10-18-2016, 11:45 AM   #118
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
You'll see instructions on the website that I'll PM you.
You can't run this from Linux.
      10-18-2016, 03:43 PM   #119
ahoroba
Member
ahoroba's Avatar
Drives: 2016 BMW 320i xDrive
Hi!
I would appreciate a PM link for Rheingold, ISTA+, ISTA-D/P and E-SYS for F30.
Thanks in advance.
      10-18-2016, 03:52 PM   #120
IllLojik
IllLojik's Avatar
Drives: //'12 F30 328i\\
Send a message via AIM to IllLojik Send a message via MSN to IllLojik Send a message via Yahoo to IllLojik
PM Please. Thanks. This is awesome
I has no mods
      10-18-2016, 04:08 PM   #121
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Originally Posted by ahoroba View Post
Hi!
Thanks in advance.
I can't send you private messages yet. Send me one when you can!
Sent!
      10-18-2016, 07:24 PM   #122
ahoroba
Member
ahoroba's Avatar
Originally Posted by kretzu View Post
I can't send you private messages yet. Send me one when you can! [...]
PM sent to you, as per your request. Thank you in advance.
      10-18-2016, 08:53 PM   #123
wildjeff
Drives: 2016 340i
I'm interested in a link as well, thank you
      10-19-2016, 04:40 AM   #124
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Link sent!
Link sent!
      10-19-2016, 07:54 AM   #125
ahoroba
Member
ahoroba's Avatar
Link sent!
Link sent!
Got it. Thanks a lot!
kretzu1496.50
      10-21-2016, 10:00 AM   #126
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
I'd like a link for everything as well, thanks!
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      10-21-2016, 10:46 AM   #127
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Sent!
      10-21-2016, 04:59 PM   #128
HenryX
Drives: 2013 335i
I'd like a link. Thanks.
      10-22-2016, 03:44 AM   #129
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Sure. Sent!
      10-22-2016, 04:30 AM   #130
randyc
Drives: F30 328i MSport
Hi Mate, would like to get a copy of the software! Sent you a PM
      10-22-2016, 04:42 AM   #131
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Sent!
      10-24-2016, 08:11 AM   #132
kretzu
King ♕
kretzu's Avatar
Romania
1497
Drives: E87 120i
Thumbs up How to connect ISTA+/Rheingold to your BMW
Update.
Everyone will get by default a how to connect with your BMW tutorial (link) in PM.
For everyone else that is reading this topic, you may check the tutorial here.
diagnostic, ista-d, ista-p, rheingold, software
