BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Clutch delay valve on F30 found.
      04-23-2019, 12:33 PM   #89
MacklinUSOB
Drives: f30 328i 6MT Sport
Originally Posted by Tchao View Post
Im pretty sure he means through the slave. For some reason normal older bmw slave bleeding procedures didn't work on my F30. Had to do the syringe method as well.
Right yeah I meant the bleeder nipple on the slave. I am going to just got for the syringe method then. Cheers
Add 5 horsepower for every M logo
328i RWD | Sportline | CRed on MW | 6MT | Bootmod3 STG 1 | MPE | GPlus FMIC | KW V2 | F80 LCA/TS | APEX SM-10 | R-S4 | Hawk HP+ | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      06-16-2019, 08:53 PM   #90
wellvrsd
Drives: M2, Many e30's, 330ci, 335d
I wanted to thank everyone who contributed to this thread, it was my primary source of information going after the CDV on my M2. I am so much happier with the car now, and I can't thank you guys enough.
I did a writeup on the experience with some pics and thoughts that I haven't seen elsewhere, so I thought I'd post a link here for future reference.
https://f87.bimmerpost.com/forums/sh....php?t=1625114
      08-19-2019, 02:08 AM   #91
Jimmy-320msport
Drives: e87 120i sport,f30 320i msport
My car is going in for a new clutch and flywheel soon and im gonna get the garage to do this while its in
      09-04-2019, 06:04 PM   #92
codestar
Drives: 2014 435i xdrive
How did it go?
I'm doing the same thing next week. What clutch are you replacing it with? I bought a new slave and i'm just going to remove the CDV beforehand and get them to swap it in when it's all apart getting the clutch
      09-13-2019, 12:23 AM   #93
codestar
I bought a new slave cyl and yanked the cdv and rubbwr gasket out. Got it installed with my new clutch and DMF. Seems to be running great but I'll be taking it easy for a few 100km before really testing
Nugget311.50
kern4172024.50
      10-09-2019, 01:43 PM   #94
pkiledj
Drives: '15 335i 6MT xDrive M-Adaptive
@codestar , thanks for the genius obvious not so obvious idea of just buying a new clutch slave cylinder. I was hesitant to do this mod because removing the old slave cylinder is beyond my pay grade. But I can definitely remove a rubber thingy and the metal washer thingy. Here is a simple way to remove them: just thread a screw in there and pull. I posted a new thread on this but I also wanted to reply here. No drilling required.
kern4172024.50
      10-15-2019, 01:18 PM   #95
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
So I'm going to try this soon. I have 2 brake flush jobs to do and figure this would be a nice way to use up the remaining fluid.
A few questions:
1. Is it possible to remove the components without removing the slave cylinder? Just stick a screw in there and pull out the washer and the rubber grommet?
2. How much fluid did you guys end up using to bleed the system? It'll likely be a 1 man job for me unless I can convince the wife to hop in while the car is in the air.
3. I'll clamp the feed line, but any other tips/tricks to minimize air getting into the slave?
Instagram @kern417
      10-18-2019, 03:19 PM   #96
pkiledj
Just picked up the car yesterday. The clutch pedal seems to stiffen up after driving for a few minutes. Is this normal? I can't tell if the the pedal feel is normal when it stiffens up or if the pedal feel is normal before stiffening up. It's not super-stiff. When I say stiff, it's more of a springy feel, as opposed to when I just start driving it feels softer.
      10-19-2019, 01:30 AM   #97
codestar
A few questions:
Unfortunately I can't be more help here-- I had it done by the mechanic when I had my clutch replaced, but good luck with the install!
kern4172024.50
      10-19-2019, 01:32 AM   #98
codestar
Not too sure what you mean by that, since I got my spec clutch at the same time that changed my clutch feel so much I don't know the difference between the parts haha
      10-19-2019, 07:45 AM   #99
kern417
Cheapskate
If it changes from stiff to soft/springy while you're driving, then there is probably air in the lines. It should be consistent.
Instagram @kern417
      10-19-2019, 02:37 PM   #100
pkiledj
It's going the other way, soft to stiff/springy. The engagement point is also changing from low to high. It's very minimal. I'm hoping it self-bleeds and becomes consistent. Thoughts?
      10-20-2019, 09:17 AM   #101
kern417
Cheapskate
Doesn't hurt to wait, but at the end of the day, it shouldn't change. At some point it needs to be bled more, whether the bubbles worth themselves out or you do it manually.
Instagram @kern417
      10-22-2019, 08:20 PM   #102
Lgbgeek
Drives: BMW 328i
Amazing thread and amazing work by everyone involved. I removed my CDV today and thanks to all of you it went like clockwork. I did not remove the slave and instead used a screw to take out the rubber piece. Once it was out, the metal restrictor was just laying in the slave. I hooked the edge of it with my pinky nail and it fell out. The bottom bolt of the slave has to be removed because the line support bracket is held by it. A 6” 3/8 extension with 13 mm deepwell fit the space just right. The hose is rubber (no Teflon or braiding) so it can be clamped to stop fluid loss. I used vice grips at the slave end of the line to keep the most possible fluid in the system. I had 100% succes with zero issues using the pedal to bleed the air. It took 8-10 striokes with the bleeder cracked and the air was gone. I used a traditional brake bleed bottle with a little fluid in the bottom. Im not sure if i was just lucky or what but it bleed like any clutch I’ve ever worked on.
Ive had this car (328i sportline) for just over a year and love most everything about it except for the clutch. The clutch is (was) so terrible that I was thinking about selling the car. To do so would be a huge deal for me as it’s my seventh 3series and I live and breathe BMW. If you’re not happy with your clutch and wondering if removing the restrictor is the right move, I’m confident it is. The clutch now works like a clutch. It’s smooth, predictable, and fun. I’m so happy with the results. I should mention, once the car was on jackstands, the total job took an hour and 15. It was super quick (leave the slave in). Thanks all
akgambino136.00
kern4172024.50
      10-23-2019, 06:51 PM   #103
akgambino
Drives: 2013 F30 335xi M-Sport (PWG)
Originally Posted by Lgbgeek View Post
Amazing thread and amazing work by everyone involved. I removed my CDV today and thanks to all of you it went like clockwork. I did not remove the slave and instead used a screw to take out the rubber piece. Once it was out, the metal restrictor was just laying in the slave. I hooked the edge of it with my pinky nail and it fell out. The bottom bolt of the slave has to be removed because the line support bracket is held by it. A 6" 3/8 extension with 13 mm deepwell fit the space just right. The hose is rubber (no Teflon or braiding) so it can be clamped to stop fluid loss. I used vice grips at the slave end of the line to keep the most possible fluid in the system. I had 100% succes with zero issues using the pedal to bleed the air. It took 8-10 striokes with the bleeder cracked and the air was gone. I used a traditional brake bleed bottle with a little fluid in the bottom. Im not sure if i was just lucky or what but it bleed like any clutch I've ever worked on.
Ive had this car (328i sportline) for just over a year and love most everything about it except for the clutch. The clutch is (was) so terrible that I was thinking about selling the car. To do so would be a huge deal for me as it's my seventh 3series and I live and breathe BMW. If you're not happy with your clutch and wondering if removing the restrictor is the right move, I'm confident it is. The clutch now works like a clutch. It's smooth, predictable, and fun. I'm so happy with the results. I should mention, once the car was on jackstands, the total job took an hour and 15. It was super quick (leave the slave in). Thanks all
Awesome to finally see a good descriptive post in this thread with pictures! Thank you!
Can I bother you to give a bit of a step by Step with a bit more detail on the bleeding method you had success with? That is the one part I have always had the most concern with and has had me hesitant to do this on my car.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct)
      10-24-2019, 08:07 PM   #104
kern417
Cheapskate
Amazing thread and amazing work by everyone involved. I removed my CDV today and thanks to all of you it went like clockwork. I did not remove the slave and instead used a screw to take out the rubber piece. Once it was out, the metal restrictor was just laying in the slave. I hooked the edge of it with my pinky nail and it fell out. The bottom bolt of the slave has to be removed because the line support bracket is held by it. A 6 3/8 extension with 13 mm deepwell fit the space just right. The hose is rubber (no Teflon or braiding) so it can be clamped to stop fluid loss. I used vice grips at the slave end of the line to keep the most possible fluid in the system. I had 100% succes with zero issues using the pedal to bleed the air. It took 8-10 striokes with the bleeder cracked and the air was gone. I used a traditional brake bleed bottle with a little fluid in the bottom. Im not sure if i was just lucky or what but it bleed like any clutch Ive ever worked on.
i figured it could be done without removing the slave. thanks for the confirmation. i think your method is key to keeping the bleeding process simple by not moving too many components.
when i get to mine, i'll try to make a video and post it up.
Instagram @kern417
akgambino136.00
