BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Steering rack thrust piece
      08-27-2018, 08:17 AM   #1
KGB_123_99
Drives: '17 330ix M-Sport
Hi folks,
The dealer is replacing the thrust piece in my steering assembly because I have a clunk when turning the steering wheel with the engine off.
Now this is not my area of expertise and this is the first time I actually hear about this piece. What I found online is that is pushes the rack against the pinion (is that right?).
My question is, do I need an alignment after this procedure? Dealer says no and it kind of makes sense but I want to be sure.
Thanks!
      08-27-2018, 08:37 AM   #2
F3rst0rder
Drives: 2015 335xi
If an alignment were required I would imagine the dealer would have said something or if replacing under warranty would be addressing it during repair. I can only imagine a ďthrustĒ piece must be part of the steering shaft (possibly like a pillow bearing) which should not require an alignment. I donít know specifically a rack component that pushes the rack against the pinion that I have ever seen
      08-27-2018, 08:48 AM   #3
obert
obert's Avatar
Drives: 2013 328i
Off topic but I had the same issue and they replaced the whole steering rack and did an alignment. Had my car for two weeks.
      08-27-2018, 09:03 AM   #4
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
My dealer also replaced my entire steering rack with a supposed updated/improves rack which also meant that they needed to update the software on the car. They also did a 4 wheel alignment.
      08-27-2018, 09:12 AM   #5
F3rst0rder
Drives: 2015 335xi
Funny. Iíve had a front end steering clunk and the dealership tells me they canít figure it out. Interesting to see so many people getting steering racks
      08-27-2018, 09:16 AM   #6
KGB_123_99
If the new thrust piece doesn't sort out my clunk, they will replace the entire rack as well.
However, supposedly it's just one piece which causes the problem. If that's the case, replacing the whole rack seems like overkill.
      10-02-2018, 08:54 AM   #7
adpack82
Scotland
Drives: F30 330D M sport
Originally Posted by KGB_123_99 View Post
Hi folks,
Thanks!
I'm told by the dealer, mine needs the same part (thrust piece), I ordered it myself from BMW parts, although it's on back order from Germany. Hopefully easy enough to fit, though I can't find much info online.
It only cost me about £28, so a lot cheaper for BMW, than replacing a steering rack.
Only time will tell if it fixes the issue.
      10-13-2019, 11:33 AM   #8
JamesStam
Drives: 2015 BMW 320ed
Which website exactly did you order the repair kit from?
      10-13-2019, 02:16 PM   #9
IK6SPEED
IK6SPEED's Avatar
Drives: BMW M3 / AH3
Any Dealer or site that sells OEM parts.
Stable: F80 / AH3
Past: F80 ZCP / F22 M235i / E89 35is
      10-13-2019, 10:02 PM   #10
pdegene
Respect My Authoritah
pdegene's Avatar
Drives: 2014 335i M-Sport
Did this fix your problem, OP?
2014 335xi M-Sport 6MT: Estoril Blue II, BM3 Stage 2, Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC, M-Sport Brakes.
      10-20-2019, 12:34 AM   #11
2015BMW328IXDRIVE
Drives: 2015 328i Xdrive
Hi folks,
Thanks!
Do you need to grease the new bushing when reinstalling?
      10-20-2019, 09:52 AM   #12
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
There are two very well documented problems with the racks. One is the thrust bearing, the other is corroded bolts that attach the steering motor to the rack. Both are warranty items.
https://f30.bimmerpost.com/forums/sh....php?t=1603926
https://f30.bimmerpost.com/forums/sh....php?t=1469927
