BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 6MT clutch issues from a start
      10-16-2019, 05:00 PM   #1
therealm3
Drives: F30 340 MSport
Hello,
I am having an issue with my new to me 2016 340 with a manual. This is my second manual F30, previous was a 2014 335, and have had a long line of manual bmws prior to this. Been driving with three pedals for 20+ Years. So with that said please save the learn to drive comments. Hahahha
My problem is the clutch will shudder/chatter as I take off from a stop in first gear, but only after it has been driven for awhile. When it is cold it is smooth and I barley have to give it any gas to get going. After awhile though it starts to shudder with the same input and I have to add more rpm or start to slip it a tiny bit so the car rolls and then push the clutch in all the way and let it out like normal. If I have been in traffic for a long time it's brutal. To get it not to chatter I have to slip it a ton with 1500+ rpm and I don't like doing that cause it's causing unnecessary wear and heating the clutch up that much more. Shifts into higher gears once moving are fine. It doesn't slip and is smooth.
Anyone else have similar characteristics? My last f30 didn't do this so I am wondering if maybe the previous owner wasn't so nice to the car. It is a CPO so I can take it to the dealer but I know this is going to be an uphill battle because it is fine when cold. And they don't tend to spend a lot of time looking into issues.
      10-16-2019, 07:01 PM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
If it's not mounts then maybe bleed the clutch line. You may have an air bubble.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
https://www.facebook.com/newfinishcolumbia
http://www.instagram.com/newfinishcolumbia
      10-16-2019, 07:39 PM   #3
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
I also have a 2014 335i and I get that too. I've found that avoiding unnecessarily heating up the clutch helps a lot. Other than that, just revving it to about 2k, releasing the throttle, then releasing the clutch while engine revs seems to avoid this problem.
      10-17-2019, 01:30 AM   #4
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
1701
Drives: 340 6MT
My car has been driven so gently. I hear a slight chatter hear and there. Isn't it a dual mass fly wheel ?
      10-17-2019, 02:41 AM   #5
rak299
Drives: 2018 340i xdrive F30 6MT
My first thought is throw-out bearing
      10-17-2019, 10:44 AM   #6
therealm3
Interesting points about the throw out bearing. Hadn't thought about that. Maybe as it heats up it it sticking a bit. My thoughts were the friction material on the clutch grabs more as it is hotter like a high temp brake pad. I dunno. It's super annoying though and I am not excited about dealing with the "can't replicate the issue" back and forth with the dealer.
      10-17-2019, 10:58 AM   #7
Beek
Beek's Avatar
Drives: Most folks crazy.
Call service dept, explain problem and ask if when you bring it in they could go for a ride while it’s hot?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter.
      10-17-2019, 01:09 PM   #8
nawfoo
nawfoo's Avatar
Drives: 2015 335i M-Sport 6 MT
My car does that after its been driven for over an hour and going up the drive way.
      10-17-2019, 02:45 PM   #9
Solidjake
\_(ツ)_/
Solidjake's Avatar
Poland
490
Drives: '13 328i Msport 6MT
Mine does the same. It's a lot better in comfort over sport mode. Just need to add a little more gas and try to remember the bite point to reduce the chatter
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Intake/Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      10-17-2019, 06:00 PM   #10
yeg440i
yeg440i's Avatar
Drives: 2017 440i 6MT with MPPSK
2006 BMW 330i  [0.00]
2017 BMW 440i Coupe  [0.00]
2007 BMW 335i  [0.00]
I've had this on my car since I got it new & I always just attributed it to being the normal operation of the clutch. The car is at 42,000 kilometres now. I'm going to try & get around to deleting my clutch delay valve before winter & see if that helps anything, a lot of people have said it improves the driving experience quite a bit.
2017 440i 6MT Alpine White over Coral Red Leather 2007 335i 6MT Black Sapphire Metallic over Terra Brown Leather
2006 330i 6MT Arctic Metallic over Ivory White Leather (SOLD)
      10-17-2019, 07:38 PM   #11
pc83
Drives: 328i M-Sport
Have this on my 328i and 135i before that. Typically after a long drive and especially after a lot of start and stop traffic. I suspect the clutch gets too hot with hotspots and causes the judder.
      10-17-2019, 10:43 PM   #12
therealm3
Hmmm. This is the first clutch I have had that behaved this way. Had other issues in the past, but not this. I feel a little better that others struggle with it too, but bums me out cause it's less likely I will get a fix out of the dealer. It sucks cause the engagement when it's cold is so smooth and requires very little throttle.
      10-18-2019, 09:31 AM   #13
celsdogg
E4 Mafia
Drives: E30, E36/5, F22, F30
I have this same exact issue on my m235i. but not at all on my wife's 335i (currently 55k). my m235i has been like this since I got it at 14k, currently at 34k.
Squad - E30 325i MT | E36/5 318ti MT | F22 M235i MT | F30 335i MT
KIA - E30 325i AT | E46 325i MT
      10-18-2019, 03:40 PM   #14
apascutia
apascutia's Avatar
51
Drives: 2012 Bmw 328i
My 2012 328i does this too. It's very strange. It doesn't happen on every drive, but I'd say it happens a few times a week when I daily drive it. It was much more noticeable when the weather was hot and humid. I took a trip to SC back in May with it, and it would do it right when I started driving it in the morning. I'm at the point where I'm blaming it on the clutch getting warm, however, it doesn't happen that often when I'm in rush hour traffic. As you can tell, it's confusing
      10-20-2019, 09:50 AM   #15
Joemann892
Drives: 2009 335d
I have a 2016 340i and my car does this mainly in sport mode after about an hour of driving as well. I've driven cars with a 6 puck kevlar clutch and the only thing I can say is it's reminiscent of that, so maybe it just means when the clutch material gets hot it just becomes super sticky. It is rather annoying tho when it first starts because then u need to recalibrate and add some gas on takeoff.
      10-21-2019, 04:26 PM   #16
Bmwman325
Drives: 2015 MG CR 335 XI 6SP
I experience the same after a lot of stop and go driving. Like others have stated, just revving up to 2000 rpms and slowly rolling out is how I get past the issue.
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
      10-22-2019, 03:30 PM   #17
SpecialK
Drives: 2012 335i
Same issue here. My research says that the dual mass flywheel is most likely out of spec. My 335 is at 98,000 miles, and and the clutch still holds strong, so I see no need to change it.
If the chatter gets to the point where the car is undrivable, then I'll look at changing the whole assembly. For now, I'm focusing on suspension noise and catching up on maintenance.
