10-18-2019, 02:45 PM | #1 |
Rep 90
Boost Leak Test/Dyno in SoCal?
I'm not hitting target boost, and boost is slow. I have a 2013 335 with a PS2, billet port injection manifold, all supporting mods. I did the install work myself, and have had no other issues except for the under boost/drivetrain malfunction from slow boost response. In the log attached you can see it slowly climb to about 15 psi, target is 22 psi.
I just recently replaced all o-rings and tightened clamps.. a) I would like to find a shop in the LA area that can help boost leak test/source the issue. b) I'm also looking for a shop that has experience with running these cars on the dyno Any info/advice helps. I tried to make an adapter with 3D printer to pressurize the system. I had air leaks at the trans/pcv connection points. |
