07-16-2018, 04:21 PM | #1 |
Rep 20
ACS Springs Upgrade F30 330d
Car is a F30 330d Luxury, SE stock springs. This is kind of thread has probably been done to death but..
Everybody by now knows the wallowing drive of the stock F30 and ACS springs seemed the most most popular upgrade. After a nervous encounter on the motorway doing higher speeds, where the car wafted from right to left, I felt it was the right time. In the moment it felt as if though I had no control over the car and its scary to even think what could have happened. I was going for it purely for handling reasons, and couldnt really care less about the lowering aspect of the springs. Another reason why I went for ACS they lower the car the least out of most competing brands. Phoned up Lorcan and a date was set. I arranged to fit the springs through the Rossiters authorised garage Autoleys, which is about a 10 minture drive away. The actual day went really well, hospitality from Lorcan and his team was second to none. Very friendly and the coffee was on tap which always helps! Just want to say thanks again. Shout out to Ian from Autoleys also, he knows his stuff. Took around 4 hours to install and this included new bump stops I decided to change over at the time. Car had done 70,000 + miles at this point and it couldn’t really hurt to change them over. Once the springs were fitted what can I say, if you have been mulling over this go for it. You will not regret it one bit. Car handles mostly the same at lower speeds, except maybe you feel at bit more of the road. The car however really came into itself at higher speeds and when cornering. No more wallowing car felt more planted and actually drove in the direction you wanted it too. When cornering you have more confidence in what the car is doing and there is no uncertainty in what the car might do, this alone was worth it for me. And this is just from the springs alone. I do plan on going for the full set up with the shocks, when funds allow and the current stock ones give in and cant even begin to imagine what difference that will make. Can not recommend this upgrade enough |
07-16-2018, 05:19 PM | #2 | |
Rep 2,271
Have you just bought your car or did you do the 70,000 on the original springs and then decide to change?
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
07-17-2018, 12:36 AM | #3 |
Rep 1,470
Having just done a 350 mile round trip on 90% motorway in my F31 330d xDrive I really can't fathom where all of this negativity against the so called awful handling on stock suspension comes from.
07-17-2018, 01:12 AM | #4 |
Rep 20
Drove about 10k miles since purchase before deciding to go for the springs
07-17-2018, 01:14 AM | #5 |
Rep 20
Comming from an e90 there is a massive difference for me personally. I guess it comes down to what you find acceptable. Having driven a 335d xdrive for a while I can say the same for the stock set up on that also.
07-17-2018, 05:30 AM | #6 |
Rep 609
Drives: F31 330D xDrive MPPK ACS
Try and drive it quickly on a B road
F31 Mineral Grey 330d Xdrive, ACS, Adaptive, MPPK.
Gone but not forgotten: 1967 Triumph GT6 Mk1 (6 pot 2 litre widowmaker) 1966 Triumph TR4A (4 pot 2.2 litre, huge torque, lovely car) 2004 Audi TT 3.2 DSG Quattro (weak springs & nose heavy) 2006 VW Golf GTI (brilliant on good tyres) |
07-17-2018, 06:21 AM | #8 |
Rep 922
The motorway isn't enough to give you a good feel of what the suspension really lacks. You need to try it out on a B road and then you understand.
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
07-17-2018, 07:32 AM | #9 | |
Rep 1,470
At 32 with 2 kids I think my days of thrashing my car around B roads are done. I can make quick enough progress in an enjoyable manner with my car as it is. |
07-17-2018, 07:47 AM | #10 |
Rep 3,967
Is the SE suspension really that bad on an F30 compared to an E90? I never found the handling that bad even on the twisties with an E90 SE.
07-17-2018, 07:56 AM | #11 |
Rep 1,470
07-17-2018, 08:33 AM | #13 |
Rep 20
07-17-2018, 08:56 AM | #14 | |
MATYAL
Rep 80
it would be good to know how much you payed for it all as i really want to get this done but has the be the right price... |
07-17-2018, 10:58 AM | #15 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
The springs including fitting at ours or another good independent comes to around £700 inc vat and wheel alignment etc. We've sold around 2000 sets in the UK now (90% for xDrive cars) so clearly a significant number of 3 and 4 series drivers feel they are worth it.
07-17-2018, 02:19 PM | #16 | ||
Rep 2,271
As many have said before and I now agree.... It's how the car should of left the factory. Also consider spacers.... Just for the visual enhancements alone!
IG: project540ix
07-17-2018, 02:31 PM | #17 |
MATYAL
Rep 80
I was quoted end of last year just over £600. I would have thought maybe it would get cheeper but i guess not :
I want to get it done as i am keeping the car but too much Monies!!! |
07-17-2018, 04:15 PM | #20 | |
Rep 3,216
But the OP does say that they were doing 'higher speeds'. I suspect it's more that a case of excessive speed, lack of attentiveness, and an over-correction being far more to blame than the suspension setup. |
07-17-2018, 04:36 PM | #21 |
Rep 20
Instead of assuming what I meant let me explain. By higher speeds, I mean b roads and motorway driving, basically anything other than in town driving. If a small bump or uneveness in the road can cause you to change direction I would call that lacking.
07-17-2018, 04:46 PM | #22 | |
Rep 3,967
This is why I asked the question .. is it really so much worse on the F30 (I've never driven an F30 with SE suspension)... it appears that it is. |
