10-31-2016, 11:26 AM | #45 | ||
Rep 190,805
I just posted the sale thread in the vendors sections, You check that thread for pricing If you guys have any additional questions, please post it on this thread not the one in the vendor section
10-31-2016, 01:25 PM | #46 |
Rep 526
10-31-2016, 01:46 PM | #48 |
Rep 526
10-31-2016, 03:10 PM | #49 |
Rep 369
I'm having trouble finding additional info on the tune......I'm sold on the power but just curious on shift harshness. This my daily and I'm not sure I'd like shifts being harsher in comfort mode (especially)
10-31-2016, 03:51 PM | #50 | |
Rep 498
I understand the stock DME compensates for boost, fuel and timing, but if someone (AA, JB4, Dinan) was able to manipulate the fuel and timing, which seems like nobody can at this point.... the ECU tune gains would be similar to the N54/N55 motors, which as you know were MUCH higher due to them being able to be fully manipulated. The B58 is much stronger motor, with a little larger turbo, yet the tunes are being restricted because of everyone's inability to control the fuel and timing curves independently. Unless I am not understanding correctly. My N54 335i with just a tune and air intake picked up almost 90hp and 80ft lbs on 93 octane a few years back with just a JB3 (at the time). I am hoping that someone is able to ultimately control those parameters to make the tune gains closer the gains I had in the past. I don't know if this will be something that continues to be impossible from all tuners, but I am hoping someone figures it out. None of my statements are made to knock anyone's product, David. Its nothing personal and I mean no ill will by anything I am saying. |
10-31-2016, 10:49 PM | #51 |
enthusiast
116
Rep 221
Please post the dyno with AFR. And need more info how it connects MAP, OBDIi or what? Thanks
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph. |
10-31-2016, 10:59 PM | #52 | |
Rep 190,805
David@ActiveAutowerke813.00 |
11-01-2016, 09:13 AM | #53 | |
Rep 526
No offense taken Assuming we're only running pump fuel, why do you think that the tunes are limited by the lack of fuel and timing control? The AFR is clean and the ECU does an excellent job of running as much timing as safely possible. The B58 with our Active-8 is making pretty much the same power as an N54 with full bolt ons on pump gas only. Full fuel/timing control isn't necessary unless you plan on making quite a bit more power with different fuel or a different turbo. |
11-01-2016, 09:34 AM | #54 | |
Rep 526
It connects to three sensors including crank position on top of the valve cover along with the map sensor on the chargepipe and the tmap on the intake manifold. |
11-01-2016, 11:29 PM | #55 |
enthusiast
116
Rep 221
Thanks.. looks good. I assume detailed installation provided. Mike, Ill reach out tomorrow. I wont be able to run independent dyno until December, however once install will post the daily drivability review.
11-02-2016, 12:44 AM | #56 |
Rep 190,805
11-02-2016, 09:24 AM | #58 |
Team Zissou
3065
Rep 10,197
How does one go about changing the map when new mods are added and new maps are available? Also, can a local dealer (http://store.activeautowerke.com/pages/dealers) make a custom tune for it?
11-02-2016, 02:37 PM | #60 | |
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
11-02-2016, 08:56 PM | #64 |
Rep 190,805
11-02-2016, 08:57 PM | #65 |
Rep 190,805
Congrats!!
