05-01-2022, 03:53 AM | #89 |
Rep 1,010
Thanks didn't know stock turbo could reach those levels of boost.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
05-01-2022, 03:54 AM | #90 |
Rep 3,877
One of the top catastrophic events as a result of tuning. Not uncommon. Of course it happens even to untuned vehicles but that's very rare, for obvious reasons.
The worst way a turbo can fail.
IMS-340C394.50 |
05-01-2022, 04:00 AM | #91 | |
Rep 1,454
I actually just sold my stock intake manifold to someone who had his broken turbo bits end up in his manifold as well.
2022 CT4-V Blackwing 6-speed
05-01-2022, 04:17 AM | #92 | |
Rep 1,010
I guess you mean the compressor blade, I am surprised BMW didn't put a kind of mesh between the charge pipe and throttle.
05-01-2022, 04:22 AM | #93 |
Rep 3,877
And introduce another potential single failure catastrophic event?
05-01-2022, 04:26 AM | #94 |
Rep 1,010
Why would a static metal mesh fail ? in that case the intercooler fins could also fail
05-01-2022, 04:31 AM | #95 |
Rep 3,877
Rust? Fatigue?
In Engineering it is all about MTBF (Mean time between failure) and probabilities. The probability of turbo failing and more importantly - failing in a way which is catastrophic for the engine, is extremely remote (under stock configuration, that is). Therefore no need for additional protection (which would need its own MTBF assessed and eventually mitigated, plus added manufacturing cost). All those numbers and assessments go down the toilet once we start modifying.
05-01-2022, 05:08 AM | #96 | |
Rep 1,010
I ran 21 psi on MPPSK tune.
05-01-2022, 01:49 PM | #97 | |||
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
05-01-2022, 02:13 PM | #98 |
Rep 1,010
Yeah I've seen this in a couple of cars, stock turbo not able to hit high boost at peak RPM.
05-03-2022, 05:07 PM | #99 |
Rep 677
I have been getting unstable STFT and some timing corrections. Car on flexfuel with DAW, DS2 hpfp and PI controlled by Reflex. Can you guys take a look to see if log has anything obvious? Thanks! btw I'm still tuning.
https://datazap.me/u/alanle/david-re...og=0&data=3-24 |
05-03-2022, 11:48 PM | #100 | |
Rep 1,010
Timing corrections are ok but timing advance is low for a flexfuel tune.
Also boost is low you should be targeting at least 25 psi boost and 15 degrees timing. Quote:
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 05-04-2022 at 02:49 AM.. |
05-04-2022, 12:27 AM | #101 | |
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
05-04-2022, 02:13 PM | #102 | |
Rep 677
05-04-2022, 08:49 PM | #103 |
Rep 2,067
On the subject of "fuel", been looking at this from searching online, wanted to ask the experts here...
Not ideal to do WOT data logging with fuel (in my case, pump gas of Shell 93 octane blend with E10) in the tank that's been ~1 month since last top off, i.e. 1 month old fuel? Too stale to do a proper WOT data logging with? I read that the fuel has "stuffs" mixed in to avoid fuel from going stale? |
ocdx30.00 |
05-05-2022, 02:39 AM | #104 | |
Rep 1,010
Looks like bad throttle mapping, gas pedal 50% while throttle 98%
05-05-2022, 04:28 PM | #105 | |
Rep 677
I reset adaptation but problem still persists https://datazap.me/u/alanle/reflex-v...data=2-3-24-27 |
05-06-2022, 02:34 AM | #106 | |
Rep 1,010
You could try an OTS map and check if the problem disappear.
05-06-2022, 02:51 AM | #107 | |
Rep 1,454
https://www.bootmod3.net/log?id=61ba...90c665b9ebcb45
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 Last edited by G.Newt; 05-06-2022 at 03:00 AM.. |
IMS-340C394.50 |
05-06-2022, 03:00 AM | #109 | |
Rep 1,454
Your WGDC also oscillates up and down, almost mimicking throttle closure. Something isn't right. Your smoke test came up with nothing? Hmmm
05-06-2022, 03:15 AM | #110 | |
Rep 677
