01-21-2021, 05:49 PM | #1 |
Slow Poke
Rep 15
E85 Splash - Boost Octane Slightly?
Hey guys,
So I was curious. I have 93 octane fuel in my area so I'm running a BM3 Stage 1 93 OTS map. Would there be any negative effects to pumping 1 gallon of E85 and topping the rest of the tank off with 93? (E15) I'm curious if this would have a positive effect on timing advance should the 93 octane fuel in my area be of "lower quality". I plan to datalog this as an experiment but hoping to hear if anyone else was doing this! |
01-22-2021, 07:42 AM | #3 | |
Slow Poke
Rep 15
Do most run the lucas ethanol lubrication fluid with each top off when running E30? I'm going to get some more dragy and BM3 datalogs for the stage 1 93, before and after splashing 1 gal of E85 then I'll probably see how the E30 tune compares |
01-22-2021, 09:45 AM | #4 |
Rep 3,190
You don't need ethanol additives if you are only running E30. That's meant for constant straight E85 use.
tallestmex3.00 |
01-22-2021, 01:08 PM | #5 |
Cheapskate
4455
Rep 4,995
Run logs to see if it's needed. If you have some timing pull then it can definitely help clean it up. If not then there's no need.
tallestmex3.00 |
01-22-2021, 09:40 PM | #6 | |
Slow Poke
Rep 15
Getting some pretty good timing being pulled in the higher gears/higher rpm range on a stage 1 93 BM3 tune. There is 93 here in Miami, but the station I got it from must not be true 93. So might be worthwhile adding one gal of E85 to see if it cleans that up a bit so I can confirm the findings. |
01-22-2021, 09:45 PM | #7 |
Slow Poke
Rep 15
01-22-2021, 09:54 PM | #8 | |
Cheapskate
4455
Rep 4,995
01-23-2021, 07:44 AM | #9 |
DisplacementReplacement
428
Rep 1,117
A little E85 is effective and once you get a taste of it, you'll probably run E30+ if it's readily available...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
tallestmex3.00 |
01-24-2021, 11:31 AM | #10 |
Slow Poke
Rep 15
Hey guys, so I changed the plugs and ran 1.5 gal of E85 and topped off with 93. My 4th gear pull today seemed much cleaner! Not getting any corrections up top!
https://www.bootmod3.net/log?id=600d...0b4320bdf1ebeb |
kern4174454.50 |
01-24-2021, 05:25 PM | #11 | |
Rep 198
2016 340i / M-Sport / Track Handling Package / MPPSK / AA DP / CTS Intake / Bootmod3 e30
