09-17-2020, 04:17 PM | #1 |
Rep 163
AWE Midpipe + Remus Axle Back 340i xdrive anyone?
Wanted to see if anyone has bolted up the AWE Midpipe and Remus Axleback on their 340 or 440. I know the AWE Midpipe install has you cutting 2.25 inches up from the dimple on the stock pipe where the Remus Axleback has you cutting right at the dimple if installed individually. Hoping that these two will be able to just clamp on just fine given the install flexibility of the Remus Axleback.
10-30-2020, 07:36 PM | #2 |
Rep 163
In case anyone is wondering what this combo sounds like. I have a BM3 Stage 1 tune with gts startup roar on and burbles set to ots.
Exhaust bolts up just fine. Took me a bit to get it adjusted correctly since I did it on a couple wheel blocks. There is a short slip sleeve that comes with the midpipe that goes over the ends of the midpipe and stock exhaust that you will need to use. You still slip one end over the AWE Midpipe and then you will slip the Remus axleback over it. The Remus is too wide otherwise over the AWE Midpipe. https://www.youtube.com/watch?v=FnX39yxt1lM |
Avaley732.00 BeamerBoi950.00 |
10-30-2020, 07:53 PM | #3 | |
Rep 636
Drives: f32 430ix & 982 GT4 PDK
clumsyalex22.50 |
10-30-2020, 08:56 PM | #4 |
Rep 163
10-31-2020, 09:51 AM | #5 | |
Rep 190,805
01-24-2021, 12:03 PM | #6 | |
Rep 20
01-24-2021, 09:24 PM | #7 | ||
Rep 163
BeamerBoi950.00 CarlosCapone_4.50 |
01-25-2021, 01:18 PM | #9 |
Rep 163
At the time I ordered it, the Remus mid pipe was back ordered for a few months, but I was able to find the awe midpipe in stock. I think the Remus mid pipe has 2 small resonators too and I wanted a completely non res. I did eventually go with a CTS Catted dp too and have been really happy with the sound.
BeamerBoi950.00 |
07-10-2021, 09:50 PM | #10 | |
Rep 20
07-11-2021, 08:09 PM | #11 | ||
Rep 163
07-11-2021, 09:09 PM | #12 |
Rep 163
Here is a quick video with the DP. I don't think that it really picks up the change in volume of the exhaust, but does give an idea on the sound note. Will try getting some better vids and some on road shots at some point.
BeamerBoi950.00 |
07-14-2021, 11:59 AM | #14 |
Rep 20
Yep this is what I need. Really appreciate you uploading the video man. Would love to hear on road if you ever got some time but, definitely getting the catted DP
07-19-2021, 08:57 AM | #15 |
Rep 269
Had the dinan mid pipe with the Remus axle back, sounded great, but then adding the cg precision downpipe really stepped things up a notch. Only issue I found was drone, was debating actually getting the remus midpipe since it has one resonator. I dunno what catted downpipe anyone else has paired to it, or if they noticed much in the way of drone?
07-19-2021, 11:46 AM | #16 | |
Rep 163
I did at one point also think about getting the Remus mid pipe but it's a little bit pricey. If I did add a resonator, I would probably just buy a resonator and have a shop weld it into one of the mid pipe pieces. But I really do enjoy the way it sounds now. |
07-20-2021, 02:28 PM | #17 |
Rep 1,454
A lot of the drone you might be hearing is the ASD coming from the speakers. I have a 5" catted DP with AWE catback (very aggressive) and disabling ASD removed most of the unwanted cruising sounds. The interior is pretty quiet on the highway and I'm at ~3k rpm at 80mph in my 6-speed.
2022 CT4-V Blackwing 6-speed
leew10283.00 |
07-20-2021, 03:19 PM | #18 | |
Rep 163
Wires1645.50 |
