BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > LED headlight control unit module question
Studio RSR
      12-20-2020, 07:18 PM   #1
-KingJames-
Drives: F34 GT
So I got a 2017 F34 330i GT with broken headlights. I am buying new headlight housings, most of the modules are okay so I will be just taking them off the broken headlights and putting them onto the new one, except 1 module which I have to buy a new/used one as well.
My question is, do I have to buy the exact same p/n control unit module as the other headlight or can they be different?
Current p/n: 63117457873
Realoem shows p/n: 63117457875 which ENDED, and replaced by 63117492028 and then replaced by 63118494844.
Do I have to find another 63117457873 or can it be the other 2 replaced p/n's? Or will the headlights not work if two different p/n control unit modules are on each headlight?
      03-02-2021, 04:37 PM   #2
-KingJames-
Drives: F34 GT
Bump...
No one knows? Or how about can used headlight modules be programmed onto a new car/vin?
      03-02-2021, 05:00 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Anytime Realoem shows a part has been superseded the new part is compatible with the old. That's what 'Exchangeable retrospectively' means.
      03-02-2021, 05:09 PM   #4
-KingJames-
Drives: F34 GT
Okay, but the other part is can a used LED headlight module be programmed into a new car/vin? My passenger headlight has the original module, while my driver headlight has the new used module with a different part number.
