09-18-2022, 06:32 AM | #1 |
Rep 1
330e Fuel Pump Problems
Hi have a problem with my 2016 F30 330E
on 2 100 mile trips got drive train malfunction on the m6 both times only on the return leg, drove fine going in the morning and both times after 90ish miles so somethings getting too hot I presume and RAC recovery said it was the LPFP in the fuel tank, just wondering if anybody else has had this problem and whats it going to cost? codes below Thanks System Type: ENGINE SYSTEM TEST/VALUES Name: B48 - DME 8.4.1H N20 - MOTRONIC MEVD 17.24 N20 - MOTRONIC MEVD 17.29 N26 - MOTRONIC MEVD 17.29 DTC: 11B018,Electrical fuel pump, control unit fuel pump: speed missing or not identified DTC: 110001,Cylinder injection disconnection: too low pressure in high-pressure system DTC: 11A002,Fuel high pressure, plausibility: pressure too low DTC: 120408,Boost pressure regulation: disconnection as a consequence reaction DTC: 118401,Mixture control , mixture too lean: large deviation DTC: 128B01,Lambda sensor before catalytic converter: false air identified DTC: 11A031,Low pressure fuel system, electric fuel pump: Pressure too low |
