05-14-2018, 08:07 AM | #45 | |
Rep 2,118
12-09-2018, 02:57 PM | #46 |
this is the way
18139
Rep 8,518
Coming from an e92, the F3x steering in sport mode does not require anywhere near the amount of force needed to turn the wheel. The e9x steering was far better than the F3x in many ways. It was hydraulic, you could feel the road and there was nothing artificial about it. When you got up to speed it naturally lightened up but not so much that it felt lose. The downside was it was harder to turn at slow speeds, but once you became acclimated it felt normal. In fact when I'd drive other cars I'd hate how lose and free the steering wheel was. Felt like an old mans Cadillac or your moms Camry. Hit a bump and the wheel would jerk left and right upsetting the cars balance and compromising stability. The e9x was far more stable in that respect.
Regarding the F3x prefer the sport steering, but find it annoying that if you configure Sport to 'Chassis' only it also stiffens the adaptive suspension (for cars equipped with it) as well. Don't understand why BMW doesn't give you more options to configure your car the way you like. They don't need to give it dedicated M buttons, but there should be a way configure each individual aspect for every mode (Eco Pro, Comfort, Sport, Sport+) in iDrive. |
12-10-2018, 02:44 PM | #47 |
Rep 463
Also coming from an E90 335i and previous X3, I prefer the tighter steering, yes it's artificial, but beats the comfort steering at least for me.. I drove a friends Mazda3 2015 or '16 don't recall, but a recent one and the steering was more direct than my F30!!
12-10-2018, 08:45 PM | #48 |
Not stock
474
Rep 617
Guys I can't add much here as a new f30 owner, but I am split on the heavy steering - you have to think about the target - BMW nailed it. Obviously race cars feel like heavy steering! Duh! LOL - that said, I dunno, I don't hate it I don't love it. However, if you think the steering in an F30 is bad... go drive an E34 with a steering box. Even one that's rebuilt/tight. It's literally like driving a car with a boat rudder. It's all a matter of perspective. I love my F30 handling and steering comparatively. Not even a contest.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
12-10-2018, 08:47 PM | #49 | |
Not stock
474
Rep 617
12-10-2018, 08:59 PM | #50 |
Rep 5,993
I can put it in sport mode with chassis only setting so I have the heavier steering with comfort throttle response, but find little use for that. I sometimes use sport throttle response with comfort steering, but like you said it is too loose and disconnected, sport steering inspires greater confidence but works best with sport throttle response.
12-15-2018, 10:06 AM | #51 |
Rep 2,118
Do you realize my quote is 6 months old and well before any reviews of the G20? I’m thrilled that BMW has apparently done a much better job with the steering of the new 3 series. As far as fanatical, that’s generous.
02-05-2019, 04:36 PM | #52 |
Rep 14
If I'm understanding correctly, selecting chassis only for Sport mode retains the sport steering but comfort throttle mapping. Is there a way to code the car to use sport steering in both "Comfort" and "Sport" modes?
02-05-2019, 07:06 PM | #53 |
Rep 234
Yup. I recently had the pleasure of attending the 2-day M Performance driving school and in every session the instructors had us set the steering in comfort mode and everything else (throttle & suspension) in Sport+.
02-06-2019, 11:45 AM | #54 |
Rep 132
To Jf F30 re coding using Bimmercode
NO way would I try this myself, but I asked one indie shop if they could recode my adaptive suspension to keep sport steering while in comfort mode. They said "no." It is the oem setting. Are you aware of shops that do this sort of thing? I am in N Virginia. Thanks.
02-06-2019, 12:03 PM | #55 |
Rep 132
gpchamp experience with 2018 F30s at driving school
Sadly, it seems the older 335i cars (say pre-2016 for sure, and maybe even pre-2018) do not allow for the sport steering in comfort mode. I am curious when this flexible setting became available.
BMW parses these things out. I understand the 2015 335i shows individual tire pressures when asked. Mine - same car but 2014- only says - pressure ok or low. No warning when getting lower before it hits the 25 psi point. |
02-06-2019, 07:04 PM | #56 | |
Rep 1,827
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
02-07-2019, 04:17 PM | #57 |
Rep 132
coding forums
Uh - how do I find these forums. Also, any idea if an independent shop will make the changes I want for TMPS readings and steering in comfort?
02-07-2019, 04:43 PM | #58 | |
Rep 16,081
https://f30.bimmerpost.com/forums/fo...play.php?f=429
02-08-2019, 05:33 AM | #59 |
Rep 61
Sport+
Hi all,
I was messing around with Sport Mode and Chassis only and Drive-train only this morning on the way to work, my thoughts are that I don't like the heavier steering as it is just that, heavier and I can see why some prefer the lighter comfort mode as it offers possibly more feedback (although still not a lot of feedback, going to try wider front tyres/spacers when due to see if this helps at all)! I also don't see the need for a more sensitive accelerator pedal, I assume the engine is still in the same state of tune in comfort and Sport/Sport + mode, if anyone can confirm this that would be good? With regards to the AT, does putting the shift lever across to "M/S" have the same affect on the shift points as putting it into Sport Mode? I also like driving with some of the Traction control turned off and put it into Sport+, however I believe you then have to use Sport Steering and Accelerator settings, my concern is that I will spend 90% of the time driving around with Comfort Steering and Accelerator settings and get used to that, and then when I go into Sport+, and need to have complete control of the car via steering and Accelerator inputs, they will have a completely different feeling! So my real question is does anyone know if there is a way of coding Sport+ mode to retain Comfort Steering and Accelerator settings or enabling DTC without going into Sport+? |
02-08-2019, 06:45 AM | #60 | |
Rep 15,858
Moving the shifter to M/S is the full sport programming, Sport mode is more a 'half-way' sport map, depending on the other mode settings. You can drive in Comfort mode and use the DTC function, to benefit from less DSC intervention. You don't need Sport+ to have the same DTC function. |
02-08-2019, 07:51 AM | #61 | |
Rep 61
With the steering I think the biggest issue is that I have jumped out of an E46 into an F30 and really notice the difference, never drove the E90 so can't comment on them but the E46 had such great feedback and was so confidence inspiring! I am hoping the ACS springs on my wishlist help give a more confident feel, which by most accounts they do. |
02-12-2019, 10:02 AM | #62 |
Rep 132
DIY from BillFitz for showing psi on 2014 335Xi
HI BillFitz- I can't sort through all the DIY messages and find the one that makes the simple upgrade to show psi from TPMS instead of dumbed-down go/no go from TPMS. Can you please post that or message me with that specific code instructions? I have the hardware in the car, obviously and don't need hardware info.
Thanks. |
02-12-2019, 10:37 PM | #63 | |
Rep 1,827
09-28-2020, 04:51 AM | #64 | |
Rep 2,357
How did you make it work? I also hate the heavy Sport/Sport+/DSC OFF steering!
(A Dane in China) |
