BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 335i EWG Pulling Timing
VIBE Motorsports
      11-28-2020, 03:56 PM   #1
SlumpLord3000
Drives: 335i 2014 x Drive Luxury
I have a FBO 335i EWG. Charge, boost, 5" FMIC, DV+, Catless DP. I have replaced spark coils and I replaced Bosch spark plugs with Bosch spark plugs gapped at .03. The timing is all over the place and I think I'm getting micro-knock.
Would NGK 2 step colder @ .024 - .022 would solve my issues?
Also is 0.1/0.2 knock a micro knock?
I didn't do WOT because it's already pulling timing in regular driving.
Any advice is welcome.
Stage 2 - 93
https://www.bootmod3.net/log?id=5fb8...0b43791b7e80c0
https://www.bootmod3.net/log?id=5fb8...0b4379a0d81037
https://www.bootmod3.net/log?id=5fb8...729b32856eb2d4
Stage 2 - 91
https://www.bootmod3.net/log?id=5fbe...90c61927713bab
https://www.bootmod3.net/log?id=5fbe...90c61897db89c6
2014 335i xdrive Luxury |VRSF 5" HD FMIC|VRSF Catless Coated DP|FTP Charge & Boot pipe|DV+|BM3 STG 1|XHP STG 2|Afe Scoop|Match UP 7BMW amp
      11-28-2020, 05:19 PM   #2
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Stage 2 - 93
Stage 2 - 91
None of those logs help tell us anything. You need to do a 4th gear pull starting from 2500 rpms to 6500 rpms. But if you are 6speed Manual trans then do a 3rd gear pull. Do some searching in this forum for logging tips. thejeremyman9 wrote an extensive post on how to log and how to read a log. Please read all the information thats available to you and then post some proper logs for us to give you proper feedback.
      11-29-2020, 07:20 AM   #3
Phantom10R
Drives: 2015 335i, 2015 X3 x35i
Stage 2 - 93
Stage 2 - 91
everything you're seeing is normal. timing is never a consistent thing, its fluid at partial throttle. so during normal driving its going to be all over the place.
so get the thought of something being wrong out of your head and move on to WoT runs and let's take a look then.
2015 335i xDrive 11.76 on stock turbo. (dragy) uphill!
2015 X3 x35i 12.96 catless w/bm3 stage 2 flash
IG: @N55David For pics and updates!
Youtube: @ n55david For videos or Racing etc
      11-29-2020, 08:00 AM   #4
nabil123
Drives: 2013 335i e93
I got nothing
      11-30-2020, 12:18 PM   #5
thejeremyman9
thejeremyman9's Avatar
1945
Drives: 2015 BMW 335i
For OP, here is my thread/post to read:
https://f30.bimmerpost.com/forums/sh....php?t=1732327
Give it a good read through, maybe twice, then come back with 1-3 WOT pulls in 3rd/4th gear as described there.
bm3, bootmod, bootmod3, knock
