01-14-2021, 07:27 AM | #47 |
Rep 56
Another issue occurred..
The mechanic told me everything is fine, engine running fine but.... When he drove it once it was all good and on the second run (after shutdown and starting) he got an error code - no signal from camshaft position sensor. Any thoughts? |
01-18-2021, 02:58 PM | #50 |
Rep 46
01-20-2021, 12:12 PM | #52 |
Rep 46
01-24-2021, 04:36 PM | #54 |
Rep 176
01-26-2021, 08:39 AM | #55 | |
Rep 56
As of now I'm still in the break in procedure. Logging every drive, having 1 or 2 misfires at the most which is ok. Btw, what app should i use with vlinker adapter to log or see raw data ? I'm using torque but i prefer something more modern or up to date. |
01-26-2021, 09:03 AM | #56 | |
Rep 183
01-26-2021, 09:20 AM | #58 |
Rep 183
well ideally you shouldn't be getting any misfires at all. In 60k kms of driving, I've never had a single misfire in my car. Misfires are not good for the engine. You can blow pistons, bend rods etc. Did your mechanic tell you why you are getting misfires?
01-26-2021, 09:27 AM | #59 |
Rep 56
He told me it's common when it's still not warm enough and shouldn't be a problem. Because I'm still in engine break in I'm not pushing it more then 3k rpm, so no wot.
In a week or 2 I'll change oil and will do a log to see how it runs. |
01-26-2021, 12:26 PM | #60 | |
Rep 7,606
01-26-2021, 12:46 PM | #61 |
Rep 56
I have bm3 but i need my laptop for it (and I'm looking for something casual on a daily basis). I'm using vlinker Bluetooth adapter, it can not be synced to bm3. I'll look into bimmerlink, bimmercode for example doesn't have logging option.
01-26-2021, 02:36 PM | #62 |
Rep 7,606
BM3 has phone apps now, at least for flashing. I am a MHD user myself so not sure of their logging capabilities.
01-27-2021, 02:14 PM | #66 |
Rep 7,606
