BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > Smog test
      03-03-2021, 02:02 PM   #23
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Originally Posted by cchriss View Post
Hey, I'm a little confused on what to do. I'm the first owner of my 2013 328i and this year is going to be the first time I'm taking her in for a smog check.
I'm running Stage 2 BM3 FBO 75k miles
So, in order to pass smog in CA. I would need to swap my Hi Flow ER Downpipe with the stock & also flash the car back to stock & also lock the dme. Then drive over to smog place to test?
Originally Posted by Hiflyer731 View Post
I just did smog and they do a visual inspection along with a sensor check. If your tune is blocking a CEL then it will pick that up and you will fail. A tune alone won't cause a failure. If you do have to flash back to stock be sure to drive 100 miles or so before you get the test as the sensors reset after a reflash and it takes time for them to get to the "ready" state.
what he said...
I have a BM3 stage 1 with everything stock including stock downpipe. According to my OBD2 reader.... All my sensor are at the ready and running correctly. This should pass but...I might reflash back to stock just to be sure.
      03-03-2021, 04:33 PM   #24
Hiflyer731
Drives: 2016 340i
The car I just did the SMOG has a tune but is otherwise stock and passed no problem.
      03-03-2021, 07:44 PM   #25
Gen13 F36
Gen13 F36's Avatar
What tune bro?
      03-04-2021, 09:19 AM   #26
Hiflyer731
Drives: 2016 340i
What tune bro?
It's a Mazda with with an ecu reflash tune. No turbo.
      03-04-2021, 10:05 AM   #27
NewCarGuy335i
NewCarGuy335i's Avatar
Drives: Black Sapphire 335i
No need to lock the dme, just drive the car for about 60-100 miles cruising speeds and city driving to reset the sensors, then you should be good to test.
