02-28-2021, 08:05 PM | #1 |
Rep 15
Drives: 2013 F30 335iX
DIY Coolant Change (2013 335ix)
Hey, I am looking to do a coolant flush on my 2013 335ix and was wondering what the best method is to do so. Is pulling the hose at the water pump under the vehicle my best bet? Are there any specific steps that I should know about before doing it myself? This will be the first time I am doing it. The vehicle has about 50k km on it.
02-28-2021, 09:33 PM | #2 |
Rep 943
Drives: F30 328i Msport
look for the lowest coolant hose and disconnect it, it should get rid of most of the fluid, then refill. There is a procedure to purge air afterwards from the system that is documented on youtube (look it up, pretty simple to do).
03-01-2021, 11:10 AM | #5 |
Rep 15
I have to change the oil filter housing gaskets, so I thought it may be a good idea to change the coolant while I am at it. But if its to soon then I might just top off the system
03-01-2021, 01:05 PM | #6 |
Rep 16,081
In that case I'd be inclined to change it. Anti-freeze isn't expensive, so if you have to go to the trouble of disconnecting a hose to remove some of it you might as well remove all of it.
03-01-2021, 02:59 PM | #7 |
Rep 15
ok ya fair enough. I saw somewhere that its recommended a 60/40 coolant to distilled water ratio for colder temperatures. Should I go with that or do a 50/50 mixture?
03-01-2021, 10:03 PM | #10 |
Rep 15
Haha sometimes in the winter its -22F up here, but ya like you said its not to often. I should be fine with 50/50. I appreciate the help
03-03-2021, 06:19 PM | #12 |
Rep 14
I pulled the hose at the water pump, used 50/50 (<2gal needed), then initiated the bleed procedure (I also have a 2013 335):
Close cap on coolant expansion tank and perform the following steps: 1. Connect battery charger/power supply. 2. Switch on ignition. 3. Switch on low-beam headlight. 4. Driving experience switch must not be in ECO PRO position. 5. Set heater to MAX temperature and turn fan to lowest speed. 6. Press accelerator pedal for 10 seconds to floor until pump runs. Procedure takes approximately 12 minutes. (Electric coolant pump turns OFF after approx. 12 minutes). 7. Fill coolant expansion tank to MAX level. 8. Check cooling system for leaks. 9. Remove ignition key and wait approximately 3 minutes before repeating cooling system bleeding procedure, if necessary. 10. When bleeding procedure is complete, close coolant expansion tank cap until marks on cap and tank arrows line up |
03-03-2021, 09:21 PM | #13 |
Rep 15
03-03-2021, 09:28 PM | #14 | |
Rep 15
03-03-2021, 09:44 PM | #15 | |
Rep 716
After looking the minimum temperature recorded in Toronto: The coldest minimum temperature of −33 °C (−27.4 °F) was recorded on January 10, 1859. You are OK with 50/50 https://en.wikipedia.org/wiki/List_o...ures_in_Canada https://en.wikipedia.org/wiki/U.S._s...ature_extremes Last edited by montr; 03-04-2021 at 10:28 AM.. Reason: Min Temperature Record |
CPRO7231.50 |
