Login
03-06-2018, 10:45 PM | #1 |
![]() ![]() 14
Rep 38
18" Apex wheels fitment for F36?
Hey everybody,
Im looking to get a set of Apex ARC-8's for my 2017 440i GC, but seem to be stumped as far as offsets and other specs go. The specs i was considering running would be 18x9 et42 all around with a 265/35/18 tire. After doing measurements online and comparing them to stock wheels, it looks like the front wheels will be closer to the shock absorber. Does anybody have 18" wheels on an F32/F36 and want to chime in? Looking to make the order for new wheels soon and want to make sure i dont run into fitment issues.
2015 Mineral Grey M4 - Stock
2017 Glacier Silver 440i Gran Coupe - Always broken 2016 Mineral Grey 320i - RIP ![]() ig: @jaxondanel |
03-06-2018, 11:36 PM | #2 |
![]() 53
Rep 241
That wheel spec should fit, but maybe not with that tire size. You don't need 265 width tires on a 9" wide wheel anyway. Try 245/40/18 or 255/40/18 for a better fit and more clearance from the strut. APEX has run 18x9 ET42 with 245/40 in the front of their shop car just fine. Fitment in the rear will be comfortable.
03-07-2018, 07:00 PM | #5 |
![]() ![]() ![]() ![]() 277
Rep 492
Apex will only tell you to run an 'oem' setup. I would just do whatever alohasurftoad says.
I have the arc8 18x8.5 et38 with PSS 255/40/18 all around on the f30. I'm not sure if the fender wells are different with f32/36.. ? There's maybe 1.5mm of clearance between the front wheel and spring perch, but it fits, no rubbing. The rears look like they could fit the nicer et30 concave version with 265.. |
03-09-2018, 05:30 PM | #6 |
Rep 4,784
Posts ![]() |
Happy to help! The 18x9" ET42 is a great square fitment for the F3X chassis. We have tested 245/40-18 tires with no issues. We have had customers run 255/40-18 tires as well, but in some cases it may require a small spacer to clear your suspension (with possibly a touch of negative camber). This is dependent on tire brand/compound and suspension type.
We would not recommend going with 265/35-18 tires as those are a bit aggressive and require quite a bit of work to fit properly. In addition, a 9" wheel would not properly support a 265 tire. 255 is more than enough for the F3X chassis. You can run our 18x9" ET30 wheels, but that will require some negative camber up front and possible fender roll in the rear. Going with a 255/35-18 tire would aid in clearance on that fitment. Check out a customer running the 18x9" ET30 with 255/35 tires here. If you have any further questions, feel free to PM or shoot us an email ![]() -Matt
925-245-0773 /// info@apexraceparts.com
![]() Wheels /// Tires /// Suspension Kits /// Accessories /// Group Buys /// Vehicle-Specific Fitment Guides |
03-14-2018, 04:55 PM | #7 |
![]() ![]() 414
Rep 1,782
If it the same as f30 chassis, 235/245 front and 265/275 will work on 9 or 9.5 et 35/40
I'm running 235/40/19 8.5 et35 front and 265/35/19 9.5 et40. They actually go 2mm away from suspension on the rear. And Im looking actually to go 18" for track use on 285 or 295 drag radials with some Apex ce-7 et58. I use this website calculator. https://www.rimsntires.com/specspro....r%20H2%20wheel
03-15-2018, 08:16 AM | #8 | |
Rep 20
Also, does the F32/F36 have more wheel well space than the F30? Info on the F30 is readily available, but specific info like this is hard to find for the 4 series. |
03-15-2018, 10:56 AM | #9 | |
![]() ![]() 1756
Rep 3,024
using 245/40/18(instead of 255/40) would mitigate all of the risk. 245 is 10mm narrower(obviously), 0.3" less diameter and the tire shoulder will be tucked 5mm further due to the slight stretch on 9". the smaller diameter will increase fenderwell gap, so you might consider lowering if that bothers you. EDIT: http://f30.bimmerpost.com/forums/sho...ghlight=R32DBP if you look at R32DBP's, he has 275's. so 255's in back will not be a problem. the only risk up front where depending on the brand/model(some are beefier than others) of 255(18x9 +30) could possibly rub the fenderwell liner at full lock. i don't think it will but i can't guarantee 100% certainty Last edited by alohasurftoad; 03-15-2018 at 11:22 AM.. |
03-15-2018, 10:03 PM | #10 | |
![]() 53
Rep 241
03-15-2018, 10:37 PM | #11 |
![]() ![]() 1756
Rep 3,024
i said, if the 275 rear is not rubbing then 255 should not rub in the rear. there's people running oem 437m and 513m which are 9" +29 offset on 255's up front. some lowered, some stock height, some rubbed the fenderwell liners at full lock, some have not. it pokes way more than what i'd personally run, just trying to provide info.
03-16-2018, 07:42 AM | #12 |
Rep 20
Very informative, thanks! It sounds like running the concave Apex wheels square is a pipe dream.
YuminNuman276.50 |
03-19-2018, 05:58 PM | #13 | |
![]() ![]() ![]() ![]() ![]() 454
Rep 818
SM-10 18x8.5 et35 (Profile 2) with 245/40/18 PS4S all around
328i RWD | CRed on MW | 6MT | BM3 | MPE | GPlus FMIC | Millway Camber Plates & Monoballs | KW V2 6k/16k Swift Springs | F80 LCA/TS | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
03-20-2018, 09:22 PM | #14 |
Rep 20
apex, fitment, hpde |
