BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Should I get lowered springs
proTUNING Freaks
      05-27-2020, 09:35 PM   #1
jake2106
Drives: BMW F30 330i Msport
Hey guys, I'm thinking about getting lowered springs for my 2015 330i Msport, I read that getting lowered springs can put alot of stress on your stock dampeners and I'm just wondering if lowering it 10 mm would be that bad. Also is anyone able to tell me if my car has the adaptive dampeners (it feels like it does but I don't know for certain).
      05-27-2020, 09:56 PM   #2
exE36M3
BMW CCA Member
exE36M3's Avatar
365
Drives: 2015 435i M Sport
Stock shocks can generally take an inch or less in lowering.
So look for that spec when doing your research.
As far as adaptive shocks, you'll have a toggle button near your shifter that says something like sport, comfort, eco. You'll also see when you tip that switch info SPORT, the main screen on your console will show "SPORT and show an image of an engine, transmission and your shocks."
You can also take your VIN and enter it onto this site...
https://www.mdecoder.com/
There's a section called WHEELS AND DRIVE
If you have the adaptive suspension, you will see code S2VF Adaptive M Chasis
      05-28-2020, 02:28 PM   #3
alohasurftoad
Drives: 428i gran coupe
Eibach Pro-Kit. get the mildest drop. not sure of the part number.
exE36M3364.50
johnung1955.50
      06-02-2020, 11:05 AM   #4
cfm56d7b
jake2106 are you looking for purely cosmetic results (lowered stance) or improved suspension behavior?
      06-02-2020, 04:45 PM   #5
kpgray
GasCompressor
kpgray's Avatar
Drives: 2019 440i M-Sport Coupe
+1
2019 BMW 440i M-Sport Coupe Individual
Smoked Topaz Metallic / Opel Extended Merino
Wife's Ride: 2018 Jaguar E-Pace S
      06-02-2020, 09:48 PM   #6
jh_f30
jh_f30's Avatar
1255
Drives: 2013 335i Sportline Auto RWD
I don't have EDC but when I switch modes, it still shows the graphic with suspension highlighted. Pretty sure they didn't differentiate that screen between cars that do and don't have EDC.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      06-02-2020, 10:27 PM   #7
johnung
How many miles on your car? A 2015 may already be close to needing new shocks anyway. Save half of the labor by doing shocks and springs at the same time.
You are RWD, correct?
      06-02-2020, 10:47 PM   #8
johnung
I'm not seeing listings for 330i in 2015, but there are 330i springs listed for 2017 330i. Attached are Eibach and H&R spring part numbers. I suggest Koni Yellow or Bilstein B8 Shocks.
      06-04-2020, 01:31 PM   #9
thompsac25
Stance to make her dance
thompsac25's Avatar
Drives: 2013 e92 M3
H&R Sport Springs w/ Bilstein B8 struts.
Combo is pretty awesome. Conservative drop, OEM+ ride quality.
Did a full install series on my channel:
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2013 AW e92 M3 6MT ZCP M Performance, Eisenmann Race, Macht Schnell, BayOptiks, BPM Sport, RW Carbon, AEuroPlug, iND, KW, aFe, Forgestar
2014 MG on Coral Red F30 335i MSport, MPPK, JHP Dynamics, Gates Innovations, 437M's, LCI Blacklines, iND, Bilstein B8, H&R Sport Springs, ARM, BM3, MST, TurboSmart
      06-06-2020, 10:34 AM   #10
3.0hyeah
3.0hyeah's Avatar
Drives: 2015 F31 X-Drive
My '15 had 63k on it, the shocks weren't blown or anything but there is definitely a progressive decay in their effectiveness.
+2 on the prokit. Mild drop, probably ok with stock dampers although you are right, if you're going to do springs just do it right and overhaul. Love the prokit so far.
johnung1955.50
adaptive dampers, dampeners, lowered, lowering, springs
