BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3: Direct ENET cable support for iOS/Android (BETA)
      07-23-2020, 01:08 PM   #23
CntryClub007
CntryClub007's Avatar
Drives: 2016 340i | 2013 X5-35i
Originally Posted by Ifellapart View Post
Originally Posted by CntryClub007 View Post
iOS seems pretty solid, Android needs some work.
When you say needs some work, can you be more specific? Is it not stable enough to the point you might brick your ECU? or is it more of a User Interface issue?
I would say user interface, seems somewhat laggy, have to do the WiFi work around, as it only supports one network connection at a time.
I don't know if those things could lead to the flash being bricked. I don't know if you can truly brick a DME or if you would just reflash over it. Don't really feel like finding out either, so I'll stick with iOS on this one.
      07-29-2020, 03:05 AM   #24
RMMAGA
Drives: 120i
just flashed using android beta, the flash seems OK, and it was faster then using my PC,
Using my 4G connection it seems to work OK to download the map without change any phone settings, I think my phone automatically detects there is no internet on the Ethernet adapter, and connects the APP to 4G (Samsung phone)
also the Ethernet setting are the same as XHP trans flasher so if you can use XHP and bootmod with same cable and Ethernet adapter setup, that is nice
however the dash didn't look like it was reading the correct values, see below, the reading in the dash do not make any sense
      07-29-2020, 06:58 AM   #25
trescuarenta
Drives: BMW 340i xDrive
I also tried logging with the phone and the logs looked very odd, dont think that is functioning properly at this moment.
      07-29-2020, 10:55 AM   #26
N420i
Drives: 2016 420i lightly modded
I logged with an Android tablet and had no problem, logs looked normal. Same crappy timing and everything else perfect as expected
      08-03-2020, 02:13 PM   #27
trescuarenta
Maybe because mine was logged on the dyno.. will have to try again.
BMW 340i xDrive Melbourne Red | 613 WHP 830 WNM | Pure 800 - HCP E30 Tune | Instagram: daddy.340
      08-04-2020, 06:49 PM   #28
fLatLinE-
Drives: 2016 BMW 340xi
Any news on when this will officially be on the Apple store? Seems like the public beta is now closed.
      08-05-2020, 04:40 AM   #29
Stu101
Drives: Bmw
I have asked bm3 this awaiting a response. Apple only seem to take a few days to approve apps so hopefully will be very soon
bm3, bootmod3
